封装设计规范(SMD)
% Z, {0 [7 P2 W* y/ Z3 T
4 P! s4 z- j [3 i: Q、电阻(R)、电容(C)、磁珠(B)、电感(L)、 + [5 z+ O* }$ P' P
(D)........................................................................................2 # s0 Y& W1 p& u+ Y* _* |
、钽电容(TC).................................................................................2
- B4 L: E) b) }* n/ A+ Y: ]、排阻(RA)....................................................................................3
/ s' q+ ^/ e+ Y、电感(L).......................................................................................3 4 i0 t5 {) A4 a. n
、二极管(D)...................................................................................5 & U u2 L- X7 G! u3 d r
、晶体管(SOT)...............................................................................5 / T( ?1 ]$ q) P7 ^
、保险丝(FUSE).............................................................................6
l; t! i/ i" m& @9 b$ C! z、晶振(X).......................................................................................7 8 v2 h8 y" `+ F7 `, V3 s
、翼形小外形IC和小外形封装(SOP)..........................................8
8 L+ @4 f$ `6 c) P、四方扁平封装(QFP)................................................................10 " ?! B6 [. d9 R, k# @
、J型引脚小外型封装(SOJ)........................................................12 # a: V. |2 l+ N' T" a/ `
、塑料有引线芯片载体(PLCC)....................................................13 # n% [- p% n' P' {5 l8 p6 D
、四方无引脚扁平封装(QFN).....................................................13
1 r* d% Y4 i5 k% L4 t、球棚阵列器件(BGA).................................................................14
6 [0 j1 o6 t* O+ q9 `' ~ 2 f! W# I5 j n5 o" t
、电阻(R)、电容(C)、磁珠(B)、电感(L)、ESD(D) 4 Q$ T4 E0 g. A" ~. o9 l
矩形片式元器件焊盘设计
4 V# \* ?4 g5 T! t0 [: j- k、钽电容(TC) ! d6 c& K6 H6 {- Y0 V3 O- a
* U1 g9 }0 l/ d0 ^' x+ C# d4 P3 h6 n8 ?9 d
5 n( x- P& @. |* P. z: s0 nA=Wmax-K - L+ d* W% R6 Q: U: U
3 `& z! H, e5 N1 v/ H
( B4 G( j0 V) R& h; k; HB=Hmax+Tmax-K
, c, D4 M2 q& E# ?/ Q8 cG=Lmax-2Tmax-K
9 [1 I: m. ]$ M L; B3 ~/ GL---元件长度,mm; 7 N- Q7 I' C& j. z3 w
元件宽度,mm;
2 O( ]* N# e0 o6 ]元件焊端宽度,mm;
) w8 M% B$ K- N9 G' P8 Q0 g元件高度,mm;对塑封钽电容器是指焊端高度) $ H4 o0 S% a& D9 B) c7 r+ h
常数,一般取0.25mm. ' V, N0 h# U3 h/ q" C/ |# f. A
、排阻(RA)
" _/ y; i7 V* b( T8 `9 m8 e英制 公制 A(Mil) B(Mil) G(Mil) 0201 0603 12 10 12 0402 1005 20 20 15 0603 1608 38 38 22 0805 2012 51.18 47.24 32.76 1206 3216 70.87 51.18 66.94 1210 3225 100 70 70
/ b# y# H( `0 |6 I( c/ C* G3 T! t5 C; ], L$ w8 X7 s% b
# c4 M1 K' }8 b2 n% W* B: W3 F
+ v0 [+ X' y( ^: y! U5 ~5 I0 Z |
