查看: 306|回复: 1
快来了解一下CentOS内核源码的安装方法
发表于 2020-3-20 09:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
# M3 I+ Q: T+ P( v+ K6 \  J3 K" p
不完整的内核源码:
! D0 K1 G% t, c% K  C
% V" A3 e5 F  s/ |6 t安装:
. `6 `* t. f7 w( @# ^, g. N+ e  a     * kernel-devel (both 32- & 64-bit architectures)
$ @) g; `$ D1 o0 m6 x0 @0 h" x     * kernel-xen-devel (both 32- & 64-bit architectures)- }$ @7 U2 G3 w! g) N5 b2 }& t: s6 R
     * kernel-PAE-devel (32-bit architecture only)
/ O# K+ l- C3 b6 x& K2 e7 t0 z4 D0 Z执行:
3 k5 H/ T/ D- N' [# w* y! u1 \ln -s /usr/src/kernels/2.6.18-238.19.1.el5xen-x86_64  /lib/modules/$(uname -r)/build; |, L, `% h7 \% m, d* B
) `& w4 O; Z4 J& {* |# y
" f- ~5 y' I: F8 o* O
完整的内核源码:
8 j5 |5 f/ X) R  Fyum install rpm-build redhat-rpm-config unifdef5 d! s# b( T4 l5 S$ R* M
wget http://vault.centos.org/5.7/upda ... 274.7.1.el5.src.rpm* O1 ]) q/ t: m- [8 ?  T
rpm -Uvh kernel-2.6.18-274.7.1.el5.src.rpm' ?3 |3 w) u9 x% q! g, @
8 N6 {' R! o, d5 _
cd /usr/src/redhat/SPECS2 ^4 d3 t9 z1 N$ Y2 ?0 F
rpmbuild -bp --target=`uname -m` kernel.spec$ D4 G# L* ^4 o
最终源码在/usr/src/redhat/build目录中:/usr/src/redhat/BUILD/kernel-2.6.18/linux-2.6.18-274.7.1.el5.x86_64/
    2019-11-29 15:37
    发表于 2020-3-20 17:39 | 只看该作者
    CentOS内核源码的安装方法
    GMT+8, 2025-11-25 17:35 , Processed in 0.156250 second(s), 24 queries , Gzip On.
