1 T( N8 k0 f1 ~9 r
! z# Z5 s% N2 K: F! F0 {
[allegro15.2][4层]Hi3798MV100核心板(CS0806S+CS2203+SGM8903+MMC10S5+H5TQ4G63MFR)原理图和pcb文件0 {8 h6 |4 }7 M, a/ C2 S6 N
+ l- g- }7 z$ r" B3 v& J8 H, r
" P& ~1 D% u F6 y8 o文件描述:
, b) H) Z8 y. X1. 作品用途:Hi3798MV100核心板! v5 t( ~! Q$ x, d3 {
2. 软件版本:allegro15.29 b. \+ j; I ^- _& r* b; V& V7 O
3. 层数:4层* q" E6 j' c; A5 B1 D4 p
4. 用到的主要芯片:CS0806S+CS2203+SGM8903+MMC10S5+H5TQ4G63MFR + j$ E; M: Z- l: s7 m: ~
5. pcb尺寸: 3405*3480 MIL! U3 @, r, j# Z' c
* S. @# }, j( g, v; v# L( u3 R+ w l# c9 e/ J$ A9 C Z7 `
作品截图如下:( k i- r" _; i) a# h' z7 W B
顶层截图:+ F' w8 @. T4 n$ I$ M3 f
; S: l! R7 E4 G8 D( ]4 `底层截图:
E7 ]+ y$ D: q) G
5 r1 @3 h9 d, r6 X7 D! J
全层截图:
5 {9 ]9 \# i5 ?4 e
+ v" Q; o, x. I4 G; j4 o
叠层阻抗信息如下:5 i6 [* z& y6 B
$ n M: p* q* Z7 KBOM:$ l; W M5 {, l4 [) W6 N8 R* M
| Bill of Material Report (Condensed) | | | | | | | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | | BGA96-32-1609I | BGA96-32-1609I | | IC | 2 | U3; U6 | | BGA169-BGA153-0_5MM | BGA169-BGA153-0_5MM | EMMC | IC | 1 | U22 | | CDTWIFI | CDTWIFI | CDT-CELKF04 | IC | 1 | U2 | | CDTWIFI10 | CDTWIFI10 | NC | IC | 1 | U7 | | DC-002 | DC-002 | NC | IC | 1 | J10 | | DFN2510P10E | DFN2510P10E | CS0806S | IC | 2 | U23; U24 | | HOLE182-142 | HOLE182-142 | M3_HOLE_A | IC | 4 | M20; M21; M22; M23 | | HSC0402 | HSC0402 | 330N | IC | 8 | C22; C31; C32; C33; C135; C248; C250; C255 | | HSCOX-AMC-TM-A | HSCOX-AMC-TM-A | 51_3612_50_H | IC | 2 | J4; J5 | | HSOD323A | HSOD323A | D_A | IC | 4 | D2; D4; D19; D20 | | HSR0402 | HSR0402 | 560 | IC | 2 | R72; R74 | | ID-BOARD | ID-BOARD | PCB_MARKPOINT_A | IC | 6 | ID1; ID2; ID3; ID4; ID5; ID6 | | LED3C-100C | LED3C-100C | 209_3SYGSURC_S530_A3HW | IC | 1 | LED1 | | MICRO_SD8-PUSH | MICRO_SD8-PUSH | 5031820832 | IC | 1 | J21 | | MJ8-RLY | MJ8-RLY | 406533_1 | IC | 1 | J25 | | PWC3-RF-A | PWC3-RF-A | DC_012_HW | IC | 1 | J1 | | RN8-0402 | RN8-0402 | | IC | 1 | U8 | | SAC6666 | SAC6666 | 100UF | IC | 3 | C28; C58; C88 | | SC0402 | SC0402 | 1NF | DISCRETE | 153 | C1; C5; C8; C12; C14; C15; C17; C19; C24; C30; C41; C42; C43; C44; C45; C46; C48; C49; C50; C51; C53; C54; C55; C57; C59; C60; C61; C63; C64; C65; C66; C67; C68; C69; C73; C74; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C89; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C107; C108; C112; C115; C120; C121; C123; C124; C127; C132; C137; C138; C140; C142; C143; C149; C150; C153; C154; C158; C164; C177; C182; C185; C186; C189; C193; C194; C197; C198; C199; C201; C202; C203; C204; C205; C206; C208; C209; C210; C211; C212; C213; C214; C215; C216; C218; C219; C220; C221; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C243; C245; C258; C264; C270; C271; C297; C307; C308; C313; C314; C316; C317; C323; C324; C334; C336; C339; C364; C365; D1; D6 | | SC0603 | SC0603 | 220NF | IC | 41 | C3; C6; C7; C9; C10; C11; C13; C16; C18; C20; C21; C35; C36; C37; C39; C40; C47; C52; C56; C62; C70; C71; C72; C75; C90; C91; C110; C116; C188; C251; C257; C263; C275; C281; C282; C283; C320; C350; C351; C363; C391 | | SC0805 | SC0805 | 22UF | IC | 11 | C2; C4; C25; C26; C27; C29; C38; C111; C114; C315; C319 | | SC1206 | SC1206 | 1NF | IC | 2 | C23; C34 | | SEN3-100C | SEN3-100C | IR | IC | 1 | D3 | | SGM8903 | SGM8903 | DIO2103_SGM8903 | IC | 1 | U5 | | SIP12-2_0MM-1827 | SIP12-2_0MM-1827 | | IC | 1 | J2 | | SIP-1P | SIP-1P | NC | IC | 1 | J3 | | SL0402 | SL0402 | 1NH | IC | 11 | L1; L6; L7; LB1; LB8; LB11; LB12; LB18; LB20; LB31; LB35 | | SL0603 | SL0603 | MGLB1608_030T_LF | IC | 7 | LB2; LB3; LB7; LB14; LB17; LB21; LB22 | | SL0805 | SL0805 | MGLB2012_220T_LF | IC | 1 | LB4 | | SOIC8N | SOIC8N | EA8253_ETA1486_MP1484 | IC | 1 | U14 | | SOP48-20-720B | SOP48-20-720B | NC | IC | 1 | U19 | | SOT23 | SOT23 | D2-3_A | IC | 8 | D9; Q1; Q2; Q4; Q5; Q13; Q14; Q15 | | SOT23-5 | SOT23-5 | NC | IC | 2 | U10; U12 | | SOT23A-6L | SOT23A-6L | CS0806U | IC | 1 | U4 | | SOT23_5 | SOT23_5 | EA8108_SY8089A_ETA3409 | IC | 1 | U15 | | SOT23_6 | SOT23_6 | EA8109_SY8032 | IC | 2 | U11; U13 | | SPSW6-T | SPSW6-T | TMG_533_T_R | IC | 1 | S2 | | SR0402 | SR0402 | 0/NC | DISCRETE | 121 | R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R21; R22; R23; R24; R25; R26; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R66; R67; R68; R70; R71; R73; R75; R78; R79; R80; R81; R82; R83; R84; R85; R87; R88; R89; R90; R91; R92; R93; R95; R96; R98; R99; R100; R101; R102; R104; R105; R110; R118; R135; R136; R140; R144; R145; R146; R151; R152; R153; R154; R155; R156; R173; R176; R177; R178; R183; R186; R187; R188; R189; R193; R194; R202; R203; R212; R215; R229; R268 | | SR0603 | SR0603 | 5.1K | IC | 12 | R1; R19; R20; R27; R28; R76; R77; R86; R149; R179; R210; R267 | | SR0805 | SR0805 | 75 | IC | 4 | R269; R270; R271; R272 | | SR1206 | SR1206 | | IC | 1 | R94 | | STFM16-50-285 | STFM16-50-285 | H1102T | IC | 1 | T2 | | SWPA4020S | SWPA4020S | 3.3UH | IC | 3 | L2; L3; L4 | | SWPA5040S | SWPA5040S | 6.8UH | IC | 1 | L5 | | TFBGA395-32-2323 | TFBGA395-32-2323 | S40V300_19X19 | IC | 1 | U1 | | TSW4-RG-C | TSW4-RG-C | MS-156 | IC | 1 | S1 | | USB3_0_9P_DIP_MAINSUPER | USB3_0_9P_DIP_MAINSUPER | USB3_ATYPE | IC | 1 | J13 | | USB4-1415 | USB4-1415 | SMDUSBA | IC | 1 | J12 | | VAF6-1107 | VAF6-1107 | | IC | 1 | J34 | | WBC0104-49T | WBC0104-49T | SDW12501_4A_HW | IC | 1 | J18 | | WBC0119-20R-A | WBC0119-20R-A | 0 | IC | 1 | J26 | | X288 | X288 | 24MHZ | IC | 1 | X2 | 附件:
# X( ` @8 i. v2 A( d# D原理图和PCB文件如下:, o" v# U. m7 P' {" Y; h6 E
5 Y2 X0 ?/ R! U
: v' p" U7 V& m" G6 t |
