查看: 562|回复: 3
EP4CGX150DF896开发板(EPM2210GF256+EPM240M100+PC28F512P30BF+88E1111)PCB文件
发表于 2020-2-27 20:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
7 ]4 O5 X6 z! S
+ T1 O$ s$ M# G9 Z" i$ ]; I( f[allegro15.2][14层] EP4CGX150DF896开发板(EPM2210GF256+EPM240M100+PC28F512P30BF+88E1111)原理图和pcb文件8 s. h4 U; s: J  O" _
8 T& T! K" O3 X+ u( Y
5 X4 O0 a# l. }% P& o  y5 R& [3 m文件描述:* q1 O  b- G+ ^3 s* g# x
1. 作品用途:EP4CGX150DF896开发板: a/ |+ L9 o' r6 f
2. 软件版本:allegro15.22 l% g  ]4 C+ B, G$ ~) |0 f  C& p  U1 ?
3. 层数:14层8 m: u" F3 s& b+ e; {2 x3 i3 m
4. 用到的主要芯片:EPM2210GF256+EPM240M100+PC28F512P30BF+88E1111
, f2 v3 ]3 V" d7 q& s- r5. pcb尺寸: 异形: l9 F5 P: y( X. ^
3 d5 ~# L0 E  o7 }, O7 I
7 S5 L9 Y8 l! x0 @* X  R4 K+ R$ P$ g
作品截图如下:
( F2 u' m( h7 V$ J# Y! a顶层截图:. J( E% {4 o+ P0 b
& A6 u! _/ L6 g( C- h* l底层截图:
  K4 m4 D; ~5 O' G
& d9 \  \+ v; A6 z全层截图:$ N) k2 _; b, n& A; o  D, @5 K
6 F5 T+ ?. B( \+ M- O2 x叠层阻抗信息如下:) w  {" Q9 h# X: V
( b: C2 J2 k! v& K5 x, V
BOM:
- Q5 }" x3 O; ~# u( B, Y+ k
Bill of Material Report (Condensed)
名称类型属性类别数量位号
402CAP_0402_0.1UF0.1uFIC214C1; C2; C6; C12; C13; C14; C15; C16; C19; C20; C23; C27; C28; C32; C33; C34; C42; C44; C69; C70; C71; C72; C73; C74; C76; C82; C83; C85; C86; C87; C89; C90; C91; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C106; C107; C108; C109; C110; C115; C116; C117; C118; C119; C120; C121; C122; C123; C125; C126; C127; C128; C129; C130; C132; C133; C134; C135; C136; C137; C138; C149; C150; C151; C152; C153; C158; C159; C160; C161; C162; C163; C164; C165; C168; C169; C172; C173; C174; C175; C184; C186; C191; C192; C193; C194; C195; C196; C197; C198; C199; C204; C205; C206; C207; C208; C210; C211; C212; C214; C215; C216; C217; C219; C220; C222; C224; C226; C227; C230; C231; C234; C235; C236; C237; C238; C239; C240; C241; C242; C244; C246; C251; C252; C253; C255; C257; C258; C259; C260; C262; C263; C266; C268; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C287; C289; C291; C292; C294; C295; C296; C300; C302; C303; C304; C312; C313; C315; C317; C319; C320; C321; C324; C326; C328; C330; C334; C336; C338; C339; C341; C343; C345; C347; C348; C349; C351; C352; C353; C354; C355; C356; C357; C358; C360; C361; C362; C365; C366; C367; C370; C371; C377; C382; C383; C384; C385; C386; C387; C388; C389; C390
402CAP_0402_0.01UF0.01uFIC23C4; C7; C21; C25; C67; C68; C104; C105; C139; C146; C190; C213; C229; C254; C261; C267; C293; C301; C305; C314; C318; C322; C369
402CAP_0402_4.7NF4.7nFIC9C35; C218; C256; C264; C269; C272; C286; C316; C368
402CAP_0402_1UF1uFIC3C131; C180; C381
402CAP_0402_1500PF1500pFIC1C142
402CAP_0402_10PF10pFIC7C143; C157; C189; C308; C309; C310; C311
402CAP_0402_18PF18pFIC2C154; C170
402CAP_0402_470PF470pFIC1C156
402CAP_0402_220PF220pFIC1C171
402CAP_0402_33NF33nFIC1C185
402CAP_0402_680PF680pFIC1C188
402CAP_0402_DNIDNIIC11C323; C325; C327; C329; C331; C340; C342; C344; C346; C373; C374
402CAP_0402_560PF560pFIC1C363
402CAP_0402_1000PF1000pFIC1C364
402CAP_0402_5600PF5600pFIC1C372
402CAP_0402_3300PF3300pFIC1C375
402BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1IC6L1; L2; L3; L10; L11; L12
402RESISTOR_0402_56.256.2IC21R1; R2; R77; R78; R102; R103; R104; R105; R113; R114; R115; R116; R119; R120; R121; R122; R130; R131; R133; R134; R192
402RESISTOR_0402_100, 1%100, 1%IC30R3; R8; R12; R74; R75; R79; R132; R167; R168; R169; R174; R175; R176; R177; R178; R179; R180; R181; R185; R186; R187; R188; R189; R190; R191; R193; R194; R213; R223; R228
402RESISTOR_0402_10.0K10.0KIC29R4; R5; R6; R7; R9; R10; R11; R50; R53; R76; R106; R151; R154; R156; R161; R173; R183; R214; R215; R217; R218; R219; R220; R225; R226; R227; R230; R237; R242
402RESISTOR_0402_1.00K1.00KIC20R13; R54; R107; R108; R109; R110; R111; R112; R158; R195; R196; R207; R210; R212; R216; R232; R241; R243; R244; R245
402R_0402_1.00K1.00KIC6R14; R17; R18; R21; R22; R45
402RESISTOR_0402_10K10KIC12R15; R19; R23; R24; R25; R26; R32; R44; R47; R199; R200; R201
402RESISTOR_0402_11.5K11.5KIC3R16; R153; R164
402RESISTOR_0402_68.1K68.1KIC1R20
402RESISTOR_0402_1.5K1.5KIC1R27
402RESISTOR_0402_2727IC2R29; R48
402RESISTOR_0402_00IC27R30; R31; R34; R35; R36; R37; R38; R40; R41; R42; R43; R84; R85; R88; R90; R92; R93; R96; R100; R125; R140; R163; R204; R211; R234; R267; R268
402RESISTOR_0402_2.61K2.61KIC1R39
402RESISTOR_0402_4.32K4.32KIC1R46
402RESISTOR_0402_1.37K1.37KIC1R49
402RESISTOR_0402_4.70M4.70MIC1R51
402RESISTOR_0402_590K590KIC1R52
402RESISTOR_0402_3.90K3.90KIC1R55
402RESISTOR_0402_2.20K2.20KIC1R56
402RESISTOR_0402_49.949.9IC19R57; R58; R59; R60; R67; R80; R81; R82; R83; R165; R166; R170; R171; R197; R198; R205; R206; R208; R209
402RESISTOR_0402_4.7K4.7KIC12R61; R62; R63; R64; R65; R70; R71; R123; R148; R250; R259; R260
402RESISTOR_0402_4.99K4.99KIC1R66
402RESISTOR_0402_124124IC2R68; R69
402RESISTOR_0402_84.584.5IC2R72; R73
402RESISTOR_0402_DNIDNIIC14R86; R87; R89; R91; R94; R95; R97; R98; R99; R101; R162; R203; R229; R248
402RESISTOR_0402_5.23K5.23KIC2R117; R147
402RESISTOR_0402_1.50K1.50KIC2R118; R135
402RESISTOR_0402_100K100KIC7R124; R138; R157; R159; R160; R236; R255
402RESISTOR_0402_20.0K20.0KIC4R126; R150; R252; R253
402RES 249K OHM 1% 1/16W 0402_0402249KIC1R127
402RES 261K OHM 1% 1/16W 0402_0402261KIC1R128
402RESISTOR_0402_43.2K43.2KIC2R129; R152
402RESISTOR_0402_3.0K3.0KIC1R136
402RESISTOR_0402_316K316KIC1R139
402RESISTOR_0402_5.49K5.49KIC1R141
402RESISTOR_0402_1.00M1.00MIC1R142
402RESISTOR_0402_1.62K1.62KIC2R143; R247
402RESISTOR_0402_5.36K5.36KIC1R144
402RESISTOR_0402_470470IC1R149
402RESISTOR_0402_3.24K3.24KIC1R155
402RESISTOR_0402_140.0K140.0KIC1R172
402RESISTOR_0402_2.2K2.2KIC1R182
402RESISTOR_0402_2.202.2IC2R184; R231
402R_0402_10.0K10.0KIC1R202
402RESISTOR_0402_2.00K2.00KIC1R221
402RES 24.9 OHM 1% 1/16W 0402_040224.9IC2R222; R224
402RESISTOR_0402_2.55K2.55KIC1R233
402RESISTOR_0402_10.2K10.2KIC1R235
402RESISTOR_0402_2.21K2.21KIC1R246
402RESISTOR_0402_2.87K2.87KIC1R249
402RESISTOR_0402_2.15K2.15KIC2R251; R258
402RESISTOR_0402_5.11K5.11KIC1R254
402RESISTOR_0402_25.5K25.5KIC1R256
402RESISTOR_0402_63.4K63.4KIC1R257
402RESISTOR_0402_220220IC6R261; R262; R263; R264; R265; R266
603CAP_0603_2.2UF2.2uFIC7C10; C17; C64; C65; C203; C335; C376
603CAP_0603_4.7UF4.7uFIC5C11; C38; C41; C49; C55
603CAP_0603_10UF10uFIC1C53
603CAP_0603_330PF330pFIC2C144; C155
603CAP_0603_1UF1uFIC2C270; C307
805CAP_0805_4.7UF4.7uFIC4C3; C8; C202; C337
805CAP_0805_10UF10uFIC27C51; C75; C88; C124; C140; C141; C145; C147; C166; C178; C200; C201; C232; C245; C247; C248; C249; C265; C285; C306; C332; C333; C350; C359; C378; C379; C380
1206CAP_1206_10UF10uFIC15C30; C37; C39; C43; C58; C62; C63; C77; C78; C79; C80; C111; C112; C113; C114
1210CAP_1210_22UF22uFIC2C29; C36
1210CAP_1210_10UF10uFIC2C148; C167
1210CAP_1210_4.7UF4.7uFIC5C221; C223; C225; C288; C290
6032PCAP_SMD_POL_6032P_330UF330uFIC5C61; C81; C183; C187; C297
7343PPCAP_7343P_330UF330uFIC8C5; C9; C18; C26; C46; C48; C66; C84
7343PCAP_SMD_POL_7343P_470UF470uFIC1C92
BCC9688E1111_BCC96_88E111188E1111IC1U21
CAP_PACK_4_1206CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uf x 4IC20CN1; CN2; CN3; CN4; CN5; CN6; CN7; CN8; CN9; CN10; CN11; CN12; CN13; CN14; CN15; CN16; CN17; CN18; CN19; CN20
CAP_SMD_6_3MMPCAP_CAP_SMD_6_3MM_220UF220uFIC1C24
CAP_SMD_8MMPCAP_CAP_SMD_8MM_150UF150uFIC2C54; C56
CONN_39_26_710870247-1051_CONN_39_26_7108_702470247-1051IC1J6
DDR2_84_SPECMT47H16M16_DDR2_84_SPEC_MT47H16MT47H16M16IC4U8; U15; U17; U19
DFM10-EPADLTC3026_DFM10-EPAD_LTC3026LTC3026IC3U40; U42; U53
DFN6-2X2_EPADLT3009XDC_DFN6-2X2_EPAD_LT3009XLT3009xDCIC1U16
DFN6_EPADLTC4357XDCB_DFN6_EPAD_LTC4357XDLTC4357xDCBIC2U48; U52
DFN10_EPADREGULATOR, LT3027_DFN10_EPAD_LTLT3027IC1U41
DIPSWITCH_SMT_OCTAL76SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1IC1SW2
DIPSWITCH_SMT_QUADSPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1IC3SW1; SW4; SW5
DO-214AB_RECTRONDIODE_DO-214AB_RECTRON_FM540FM540IC1D23
DQFN20FXMA108_0_DQFN20_FXLA108FXLA108IC8U28; U29; U35; U36; U37; U38; U46; U49
ECS3525OSC_ALT_ECS3525_ECS-3525-500-BECS-3525-500-BIC1X3
EG2201ASW SLIDE-DPDT_EG2201A_EG2201AEG2201AIC1SW3
F64_10X8PC28FXXXP30B85_F64_10X8_PC28F51PC28F512P30BFIC1U6
F256EPM2210GF256_1_F256_(S1+S2)_EPMEPM2210GF256FBGAIC1U7
F896EP4CGX150DF896_DDR2_SWAP_HSMC_FEP4CGX150DF896_DDR2_Swap_hsmcIC1U10
HDR2X1_2MM1X2_HDR2X1_2MM_HDR2X1HDR2X1IC1J3
HDR2X5_100MIL_SMT2X5_HDR2X5_100MIL_SMT_DNIDNIIC2J15; J16
HDR2X7_100MILHDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7IC1J13
IHLP2525INDUCTOR_IHLP2525_3.3UH3.3uHIC2L8; L9
IND_0805BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1IC1L7
IND_COOPER_DR1050INDUCTOR_IND_COOPER_DR1050_8.2U8.2uHIC1L6
IND_SUSUMU_PCMC_BTYPEINDUCTOR_IND_SUSUMU_PCMC_BTYPE_1.2uHIC1L5
IND_WURTH_74456056INDUCTOR_IND_WURTH_74456056_5.65.6uHIC1L4
LQFP-32FT245BL_LQFP-32_FT245BLFT245BLIC1U4
LUMEX_LED0805LED_LUMEX_LED0805_GREEN_LEDGreen_LEDIC28D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D12; D13; D14; D15; D16; D17; D19; D20; D21; D22; D24; D25; D26; D27; D28; D29; D30; D31
LUMEX_LED0805LED_LUMEX_LED0805_RED_LEDRed_LEDIC1D18
LUMEX_LED1206LED_LUMEX_LED1206_BLUE_LEDBlue_LedIC1D11
M100EPM240M100_M100_EPM240M100EPM240M100IC1U3
MLX_22_23_2021_VRT_HDR_2PCON2_MLX_22_23_2021_MLX_22_23_222_23_2021IC1J8
PCIX-4PORTPCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_SlotIC1J14
PSOP-DGQ10TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQIC2U45; U47
PUSHBUTTON_SMTTS-A02SA-2-S100_PUSHBUTTON_SMT_PB SwitchIC8S1; S2; S3; S4; S5; S6; S7; S8
QFN28-4X4LTC3850XUF_QFN28-4X4_LTC3850XUFLTC3850xUFIC1U50
QFN40LTC3853XUJ_QFN40_LTC3853XUJLTC3853xUJIC1U43
RAPC712CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XIC1J5
RES_PACK_8RES_PACK_8_RES_PACK_8_10K10KIC1RN1
RES_PACK_8RES_PACK_8_RES_PACK_8_5656IC20RN2; RN3; RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21
RJ45HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02EIC1J7
SAMTEC_QSHDP120CUSTOMQSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01IC2J1; J2
SC70-TISN74AVC1T45_SC70-TI_SN74AVC1T45SN74AVC1T45IC7U20; U22; U23; U30; U32; U33; U34
SENSESENSE_PAD_SENSE_SENSE_PADSENSE_PADIC16V1; V2; V3; V4; V47; V48; V49; V50; V51; V52; V53; V54; V55; V56; V57; V58
SM55-OSCOSC_ALT_SM55-OSC_100MHZ100MHzIC1Y1
SMA_LTI-SASF546-P26-X1SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1IC2J9; J10
SMA_LTI-SASF546-P26-X1SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1IC2J11; J12
SO8FDS8880_SO8_FDS8880FDS8880IC2Q1; Q3
SO8SI4816BDY_SO8_SI4816BDY-T1SI4816BDY-T1IC5Q4; Q5; Q6; Q7; Q8
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BIC1U5
SO16_WIDEEPCS128_SO16_WIDE_EPCS128EPCS128IC1U18
SOD323ZENERDIODE_SOD323_CMDSH2_3CMDSH2_3IC9D32; D33; D34; D35; D36; D37; D38; D39; D40
SOT23PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NIC1Q2
SOT23-8MAX3372EEKA_0_SOT23-8_MAX3373MAX3373IC6U9; U14; U24; U27; U31; U39
SOT23-DBVSN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVIC1U11
SSOP28_NARLTC2418_SSOP28_NAR_LTC2418LTC2418IC1U13
STAR_VIAVIA_1_STAR_VIA_VIA_1VIA_1IC42V5; V6; V7; V8; V9; V10; V11; V12; V13; V14; V15; V16; V17; V18; V19; V20; V21; V22; V23; V24; V25; V26; V27; V28; V29; V30; V31; V32; V33; V34; V35; V36; V37; V38; V39; V40; V41; V42; V43; V44; V45; V46
TP_060SQ040T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFIC7TP1; TP2; TP3; TP4; TP5; TP6; TP7
TQFP100PGS832018GT_TQFP100_0_TQFP100P_GGS832018GT_TQFP100IC1U44
TSSOP14MAX3378_0_TSSOP14_MAX3378MAX3378IC2U12; U26
TSSOP14ADG3304_TSSOP14_DNIDNIIC1U51
TSSOP20ICS8543_TSSOP20_ICS8543ICS8543IC1U25
USB2_0-RAUSB_CON_USB2_0-RA_USB CONUSB CONIC1J4
UTQFN10ISL54050_UTQFN10_NLAS4717EPMTR2NLAS4717EPMTR2GIC2U1; U2
WSL2010RESISTOR_WSL2010_0.0030.003IC5R28; R33; R238; R239; R240
WSL2010RESISTOR_WSL2010_.0090.009IC3R137; R145; R146
X2Y_0603CAP_X2Y_X2Y_0603_47NF47nFIC1C22
X2Y_0603CAP_X2Y_X2Y_0603_1UF1uFIC6C31; C177; C181; C209; C228; C250
X2Y_0603CAP_X2Y_X2Y_0603_220NF220nFIC4C40; C50; C176; C182
X2Y_0603CAP_X2Y_X2Y_0603_10NF10nFIC3C45; C233; C271
X2Y_0603CAP_X2Y_X2Y_0603_22NF22nFIC3C47; C57; C243
X2Y_0603CAP_X2Y_X2Y_0603_100NF100nFIC3C52; C59; C60
X2Y_0603CAP_X2Y_X2Y_0603_470NF470nFIC3C179; C298; C299
XTAL_EG2100635L3C3_XTAL_EG2100_125.0MHZ125.0MHzIC1X2
XTAL_HC49CRYSTAL_XTAL_HC49_6.000MHZ6.000MHzIC1Y2
XTAL_PACK_DXTAL_XTAL_PACK_D_25MHZ25MHzIC1X5
XTAL_SG310OSC_ALT_XTAL_SG310_24MHZ24MHzIC1X1
XTAL_SI570SI570_0_XTAL_SI570_100MHZ100MHzIC1X4
附件:
: n8 y7 a( z9 _% b- U原理图和PCB文件如下:
* a% C: M* h1 [* u* o, ?  j
游客,如果您要查看本帖隐藏内容请回复
/ @4 ^4 |3 C. j' O1 z: K% u
) B3 m/ o. i/ [
    2025-11-26 15:07
  • 签到天数: 1280 天
    [LV.10]以坛为家III
    发表于 2020-10-14 06:30 | 只看该作者
    谢谢分享
    “来自电巢APP”
    GMT+8, 2025-11-27 07:02 , Processed in 0.203125 second(s), 27 queries , Gzip On.
