查看: 338|回复: 2
[AD 15][12层] 三星S5PV210通信主板(SI4423+SN74AVC8T245+TPS2051BDBV )PCB源文件
发表于 2020-2-25 15:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 15][12层] 三星S5PV210通信主板(SI4423+SN74AVC8T245+TPS2051BDBV )PCB源文件
& |" d4 P& E6 v; V$ d0 X1 J; X/ I, K9 ]
; `3 v6 E4 @+ e  g: p$ [* t) Y文件描述4 ]1 f  k; ?: n% H
1. 作品用途:通信主板
7 A# Z# L' L6 @3 n  z  o$ h" s2. 软件版本:AD 154 W9 C$ y/ j3 [2 x/ X3 j
3. 层数:12层板9 X; @- X0 K8 u6 d
4. 用到的主要芯片:SI4423+SN74AVC8T245+TPS2051BDBV
  j! [( i" S: ]( Y5. PCB尺寸:130mm*125mm
9 C+ n" y: d) x. S5 j$ o8 u" {+ s" c+ I( d- C* x+ P
6 ^' Y/ \& ^5 K( P# ?$ q/ ]
作品截图如下:
# D% v" s$ {& f# `. ]7 r) z顶层截图:" r7 o2 g+ T$ @2 A
, j5 t  ~" }8 H) V
底层截图:
, T; w, m( V; p. x' m' h
- X+ M9 z- a' G: c3 B) P+ _全层截图:
" ?0 \- C5 f7 {+ U5 f. Z0 t# o
" l$ a" N) @/ `% w& J- t叠层信息截图如下:8 X- J- L1 Q5 b: b! Z
3 s, H% l9 U* u) o- ^0 [% \
BOM:
, X4 C9 R- s, s
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
BATT_2_RB414-IV02N_RB414_IV02N(BAT1RB414-IV02N
C1005_C1005_1.8NFC1, CB172C1005
C1005_C1005_47PFC2C1005
SMALL CAP_C1005_100NFC3C1005
C1005_C1005_1UFC4C1005
C1005_C1005_1UF/6VC5, C6C1005
C1005_C1608_4.7UF/X5RC7, C8, C9, C10, C11, C13, C17, C18, C19, C20, C21, C22, C23, C25, C26, C27, C28, C29, C30, C31, C32, C33, C43, C44, C52, C53C1608
26
CT2012_0_T2012_10UF/6.3VC14, CTB4, CTB5, CTB8, CTB9, CTB14, CTB15, CTB16, CTB17, CTB18, CTB25, CTB28, CTB29, CTB31, CTB32, CTB35, CTB36, CTB37, CTB38, CTB39, CTB40, CTB41, CTB42, CTB44, CTB46, CTB48, CTB69, CTB71, CTB72T2012
29
C1005_C1005_22PFC16, C35, C36, C37, C38, C39, C40, C41, C42, C49, C56C1005
11
C1005_C1005_100NFC24, C45, C51, C55, CB1, CB2, CB3, CB4, CB5, CB7, CB8, CB9, CB10, CB11, CB12, CB13, CB14, CB15, CB16, CB17, CB19, CB20, CB21, CB22, CB23, CB24, CB25, CB26, CB27, CB28, CB31, CB32, CB33, CB34, CB35, CB36, CB37, CB38, CB39, CB40, CB41, CB42, CB43, CB44, CB45, CB46, CB47, CB50, CB51, CB52, CB55, CB56, CB59, CB60, CB61, CB62, CB63, CB64, CB67, CB68, CB71, CB72, CB73, CB74, CB75, CB76, CB79, CB80, CB83, CB84, CB85, CB86, CB87, CB88, CB91, CB92, CB95, CB96, CB97, CB98, CB99, CB100, CB101, CB102, CB105, CB108, CB109, CB117, CB118, CB120, CB121, CB122, CB123, CB124, CB126, CB127, CB128, CB129, CB130, CB131, CB132, CB133, CB134, CB135, CB137, CB139, CB141, CB142, CB143, CB144, CB145, CB146, CB147, CB148, CB149, CB150, CB151, CB152, CB153, CB161, CB166, CB170C1005
122
C1005_C1005_1NFC34, CB53, CB54, CB57, CB58, CB65, CB66, CB69, CB70, CB77, CB78, CB81, CB82, CB89, CB90, CB93, CB94, CB103, CB104, CB110, CB111, CB116, CB119, CB136, CB138, CB140, CB156, CB157, CB167, CB168C1005
30
C2012_C2012_22UF,6.3VC46, C47, C48C2012
CAP_0_C1005_100NFC50, CT1C1005
C1005_C1005_470PFC54C1005
C3216_1_C3216_2.2UF/50VCB6C3216
C1608_C1608_100NF/C1608CB18, CB30, CB49C1608
C1608_C1005_100NFCB29, CB48C1005
C1005_C1005_2NFCB169C1005
SW-SLIDE2_KHS02_KHS02_KHS02CFG1KHS02
SW-SLIDE2_KHS02_SW-DIP2CFG2KHS02
SW-SLIDE6_KHS06_KHS06_KHS06CFG3, CFG4KHS06
QSE-020-01-L-D-A_0_QSE-020-01-XCON1, CON2QSE-020-01-X-D-A
MD60-19P_1_MD60-19P_MD60-19PCON3MD60-19P
USB_SINGLE_A-TYPE_HOST_2_USB_COCON4USB_CON_A
USB-MINIAB_0_USB_MINI_AB_USB-MICON5USB_MINI_AB
AXK8L20125B_HEADER_0_AXK8L24125CON6AXK8L24125B
AXT634124_AXT634124_AXT634124AWCON7AXT634124
SD_HSMMC_TAISOL_4_156-100100090CON8, CON12, CON13156-1001000901
A3B-10PA-2DSA_2_A4B-5PA-2DSA_A4CON9, CON10, CON11A4B-5PA-2DSA
QSH-030-01-F-D-A_0_QSH-030-01-FCON14QSH-030-01-F-D-A
HIF3F-20PA-2_54DS_HIF3F-20PA-2_CON15HIF3F-20PA-2_54DS
A3B-12PA-2DSA_A3B-12PA-2DSA_A3BCON16A3B-12PA-2DSA
CT2012_T2012_10UF/6.3VCT2, CTB20, CTB22, CTB24T2012
CT2012_0_T2012_10UF/10VCTB1, CTB2, CTB3, CTB6, CTB10, CTB11, CTB12, CTB13, CTB26, CTB27, CTB30, CTB33T2012
12
CT6032_T7343_330UF/16VCTB7T7343
CT2012_0_T2012_1UF/6.3VCTB19, CTB23T2012
CT2012_0_T2012_1UF/6.3V/T2012CTB21T2012
CT2012_0_T2012_10UF/6.3V/T2012CTB34T2012
B320_0_B320_B320AD1B320
FUSE_MICROSMD150-2_FUSE3225_MICF1FUSE3225
BLM18BPG121_BEAD1608_BLM18PG121FB1, FB2, FB3BEAD1608
A2-6PA-2_54DSA-6P-2_54-MALE_A2-J1A2-6PA-2_54DSA
A4B-3PA-2DSA_A4B-3PA-2DSA_A4B-3J2, J3, J5A4B-3PA-2DSA
A2-4PA-2_54DSA-MALE_A2-4PA-2_54J4A2-4PA-2_54DSA
POWER JACK_0_DC-JACK_POWER JACKJACK1DC-JACK
QSS-075-01-F-D-A_4_QSS-075-01-FJB1, JB2QSS-075-01-F-D-A
A4B-2PA-2DSA_A4B-2PA-2DSA_A4B-2JP1, JP2, JP3, JP4, JP5, JP6, JP7, JP8, JP9, JP10, JP11, JP12, JP13, JP14, JP15, JP16, JP17, JP18, JP19, JP20, JP21, JP22, JP23, JP24, JP25, JP26, JP27, JP28, JP29, JP30, JP31, JP32, JP33, JP34, JP35A4B-2PA-2DSA
35
LQH32C_0_COIL_3225_22UH (LQH32CL1COIL_3225
LQH32C_0_COIL_3225_1UH (LQH32CNL2COIL_3225
INDUCTOR_COIL_1005_BLM15HD102SNL3, L4, L5COIL_1005
LQH32C_0_COIL_3225_2.2UH (LQH_1L6, L8, L13COIL_3225
LQH32C_0_COIL_3225_2.2UH (LQH32L9, L10, L11COIL_3225
CDRH6D28_0_CDRH6D28_CDRH6D28 (1L12CDRH6D28
LED-RED_SMD_LED-2012_LED-BLUE (LED1, LED2, LED3LED-2012
LED-RED_SMD_1_LED-2012_LED-REDLED4LED-2012
LED-RED_SMD_1_LED-2012_LED-GREELED5LED-2012
CON60_GF056_GF056-60S-LSS-P2000M1GF056-60S-LSS-P2000
MTH_P1_D0.6X12_TH3_2S6_0_GNDMTH1, MTH2, MTH3, MTH4TH3_2S6_0
OSCILLATOR_SMD_SCO-103_SCO-103_OSC1SCO-103
MOSFET P DGS_2_SOT23_FDV301NQ1SOT23
IRF4905/TO_0_SOT23_SI2333DSQ2, Q3, Q4, Q5SOT23
NDC7002N_SOT23-6_NDC7002NQ-1SOT23-6
R1005_0_R1005_100KR1, R3, R5, R26, R82, R84, R86, R93, R96, R108, R127, R128, R129, R130, R131, R138, R140, R147, R159, R161, R173, R268, R270, R271, R272, R273, R274, R275, R277R1005
29
R1005_0_R1005_0R2, R7, R9, R10, R11, R12, R19, R20, R23, R24, R27, R34, R35, R49, R53, R54, R58, R59, R62, R64, R85, R95, R109, R121, R122, R123, R124, R126, R132, R133, R134, R135, R136, R139, R141, R143, R155, R170, R180, R183, R185, R186, R188, R192, R197, R200, R211, R223, R233, R257, R258, R260, R276R1005
53
R1005_0_R1005_10R4R1005
RESISTER_0_R1005_100KR6R1005
RESISTER_0_R1005_17.4K, 1%R8R1005
RESISTER_0_R1005_10K/1%R13R1005
R1005_0_R1005_NCR14, R15, R17, R18, R30, R32, R36, R40, R47, R50, R51, R57, R111, R112, R113, R114, R115, R116, R117, R118, R120, R125, R137, R144, R145, R146, R148, R149, R152, R153, R154, R157, R160, R269R1005
34
RESISTER_0_R1005_40.2K/1%R16R1005
R1005_0_R1005_4.7KR21, R22, R33, R263, R264, R265, R266, R267R1005
8
R1005_0_R1005_44.2/1%R25, R39R1005
R1005_0_R1005_1KR28, R29, R83, R94, R107, R210, R278, R279, R282, R283R1005
10
R1005_0_R1005_10KR31, R52, R79, R89, R100, R240, R250R1005
RESISTOR_R1005_0R37, R45R1005
RESISTOR_R1005_10KR38R1005
R1005_0_R1005_20KR41R1005
RESISTOR_R1005_NCR42R1005
RESISTOR_R1005_1.8KR43R1005
R_R1005_NCR44, R46R1005
R_R1005_0R48, R55, R56R1005
R1608_R1608_100K,1%/R1608R60, R65, R167R1608
R1608_R1608_20K,1%/R1608R61, R169R1608
R1608_R1608_44.2K,1%/R1608R63, R165R1608
R1608_R1005_249KR66R1005
R1608_R1005_68KR67R1005
R_R1608_0/1608R68R1608
R1608_R1005_150K,1%R70R1005
R1608_R1005_100K/1%R71R1005
R1005_0_R1005_330R72, R92, R106, R172R1005
R1005_0_R1005_51KR73, R74, R75, R76, R77, R78, R80, R81, R87, R88, R90, R91, R97, R98, R99, R101, R102, R103, R104, R105R1005
20
R1608_R1005_100KR110, R163, R166R1005
R_0_R1005_NCR119R1005
R1005_0_R1005_10K/R1005R142R1005
R1005_0_R1005_5.1MR150, R151, R158R1005
R1005_0_R1005_10MR156R1005
R1005_0_R1005_20K,1%R162R1005
R1005_0_R1005_10K,1%R164R1005
R1608_R1608_91K,1%/R1608R168R1608
R1005_0_R1005_510R171R1005
R1005_0_R1608_453K,1%/R1608R174R1608
R1005_0_R1608_100K,1%/R1608R175R1608
RESISTOR_1_R1005_47KR176R1005
RESISTOR_1_R1005_10KR177, R179R1005
RESISTOR_1_R1005_12.7KR178R1005
R1005_0_R1608_NC/R1608R181, R182, R184, R187, R189, R190, R191, R193, R194, R195, R196, R198, R199, R201, R202, R203, R204, R205, R206, R207, R208, R209, R212, R213, R215, R216, R217, R220, R221, R222, R224, R225, R226, R228, R229, R231, R235, R285R1608
38
R1005_0_R1608_0/R1608R227, R234, R284R1608
R_R1005_240KR230R1005
R_R1005_300KR232R1005
R1005_0_R1005_10K/1%R236, R237, R238, R239, R242, R243, R244, R245, R246, R247, R248, R249, R252, R253, R254, R255R1005
16
R1005_0_R1005_10K/NCR241, R251R1005
R1005_0_R1005_1.2K/1%R256R1005
R1005_0_R1005_75/1%R262R1005
R1005_0_R1005_1.8KR280, R281R1005
RP_0_R-AR4_0RA1, RA2, RA3, RA4, RA5R-AR4
SW-TACT_SW-TACT-1105SMD-4_3MM_SSW1SW-TACT-1105SMD-4_3MM
SW-TACT_SW-TACT-1105SMD-4_3MM_1SW2, SW3SW-TACT-1105SMD-4_3MM
TP_TP0_8-SMD_TPTP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10TP0_8-SMD
10
TP_P0_0.8_D0_TP0_8-SMD_TPTP11, TP12, TP13, TP14, TP15, TP16, TP17, TP18, TP19, TP20, TP21, TP22, TP23, TP24, TP25, TP26, TP27, TP28, TP29, TP40, TP41, TP42, TP43, TP44, TP45, TP46, TP47, TP48, TP49, TP50, TP51, TP52, TP53, TP54, TP55, TP56, TP57, TP58, TP59TP0_8-SMD
39
TP_P0_0.8_D0_TP0_8-SMD_A_CAMDATTP30, TP31, TP32, TP33TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_A_FIELDTP34TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_A_CAMPCLTP35TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_A_CAMVSYTP36TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_A_CAMHRETP37TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_A_CAMD_1TP38TP0_8-SMD
TP_P0_0.8_D0_TP0_8-SMD_FLASHTP39TP0_8-SMD
TP_TP0_9-TH_GNDTPH1, TPH2, TPH3TP0_9-TH
SN74AVC8T245-DGV_3_SOP24P-0_4-5U1SOP24P-0_4-5X4_4
LT3591EDDB_1_LT3591EDDB_LT3591EU2LT3591EDDB
LTC3872ETS8_LTC3872_LTC3872ETS8U3LTC3872
LP3962_EMP_0_SOP8_W6_0_E1_27_SIU4SOP8_W6_0_E1_27
PCA9517DGK_0_MSOP08P-0_65-3X3_1U5MSOP08P-0_65-3X3
RCLAMP0502B_SOT-523_RCLAMP0502BU6, U7, U8, U9SOT-523
SN74LVC1G04DBV_2_SOT23-5_SN74LVU10, U34, U36SOT23-5
TPS2051BDBV_0_SOT23-5_TPS2051BDU11, U13SOT23-5
SDMP0340LT_SOT-523_BEC_SDMP0340U12SOT-523_BEC
PCA9517DGK_0_MSOP08P-0_65-3X3_PU14MSOP08P-0_65-3X3
SN74AVC8T245-DGV_2_TVSOP16_W6_4U15TVSOP16_W6_4_E0_4
MAX1818EUT33_0_SOP8_W6_0_E1_27_U16, U41SOP8_W6_0_E1_27
MAX1818EUT33_SOT23-6_MAX1818EUTU17, U40SOT23-6
LTC3406ES5_SOT23-5_LTC3406ES5U18, U21, U42SOT23-5
LTC3406ES5_0_SOT23-5_MIC5319-3.U19, U37SOT23-5
54ALS32/LCC_1_SOT23-5_74LVC1G32U22, U23, U24SOT23-5
SN74CBTLV3257_TSSOP16P-0_65-5X4U25, U26TSSOP16P-0_65-5X4_4
SN74AVCA164245DGG_TSSOP48P-0_5-U27, U28, U32TSSOP48P-0_5-12X6
SN74LVC1G11DBV_SOT23-6_SN74LVC1U29, U31SOT23-6
SN74LVC1G08DBV_SOT23-5_SN74LVC1U30, U38SOT23-5
MAX8698C_0_MAX8698C_MAX8698CU33MAX8698C
MAX16054AZT_SOT23-6_MAX16054AZTU35SOT23-6
LM2832XMY_LM2832XMY_LM2832XMYU39LM2832XMY
SI4423DY_SOP8_W6_0_E1_27_SI4423U43SOP8_W6_0_E1_27
MAX6458_SOT23-5_MAX6458U44SOT23-5
LTC3406ES5_1_SOT23-5_MIC5219BM5U46SOT23-5
K4T2G084QA-HCE6_0_BGA68_W11_0X1U47, U48, U49, U50BGA68_W11_0X18_0_P0_8_PAD0_45
K4T1G084QQ-HCE6-DDR2_BGA60_W9_0U51, U52, U53, U54BGA60_W9_0X11_0_P0_8_PAD0_4
S5PV210_3_BGA584_W35_0_P0_65_PAU55BGA584_W35_0_P0_65_PAD0_35
CRYSTAL_SX-8_SX-8_24MHZ (SMD,SXX1, X2SX-8
CRYSTAL_CH-308_CH-308_32.768KHZX3CH-308
CRYSTAL_SX-8_SX-8_27MHZ (SMD,SXX4SX-8
MBRS320T3_MBRS320T3_MBRS320T3ZD2MBRS320T3
1SMB5920BT3G-6_2V_1SMB5920BT3_OZD31SMB5920BT3
附件:
' G4 l. a) m; n3 z: I( a# ]4 g5 H PCB源文件如下:9 w7 a; k( U( m5 m0 j
游客,如果您要查看本帖隐藏内容请回复
+ O1 K9 _* ^9 X- Q* p, g
1 ~0 {; j0 x: }
发表于 2021-10-29 13:35 | 只看该作者
#在这里打卡快速回复#
    2021-7-23 15:37
    发表于 2022-10-8 15:28 | 只看该作者
    要做通信主板了,拿来学习下
    GMT+8, 2025-8-4 14:38 , Processed in 0.140625 second(s), 27 queries , Gzip On.
