) N5 H4 O/ I4 X8 d+ v) v
' ^$ ?" i% \; P/ `0 R, o: g[AD 10][2层]SBC RK3066底板(ADV7125JSTZ240+ALC5631Q+CP2102)原理图和PCB文件& i( s4 n# E9 O9 i& f2 y
3 @ r, o+ D& n" y' X! p
文件描述
# }) }! z* C$ w/ |1. 作品用途:SBC RK3066底板8 T! i( ~, V: U. a/ ?* R( K
2. 软件版本:AD 103 d/ K0 I( b9 k6 c
3. 层数:2层板
1 B+ S9 T8 U- R6 g4. 用到的主要芯片:ADV7125JSTZ240+ALC5631Q+CP2102
0 W+ ]. v; G+ J* U& D: o7 V5. PCB尺寸:194*125 mm' q+ j0 _2 l' o$ p$ u
, G6 h( u& x( A1 i
作品截图如下:
8 W+ @2 R6 Q/ a/ f顶层截图:
1 ?$ k& c J( n: g( y/ @. a5 p
+ P3 X M0 M: X7 z8 a4 I$ P; R0 t
' N Z" i. ?2 E3 z底层截图:
l; |, y- N* X
9 Q3 K& Q6 ~9 d' D8 A( G( W
5 X$ b( p( i/ x0 r2 \5 ^
全层截图:1 Q, N1 p3 b# U2 ~
, a3 r' }1 v% c/ Z2 w L* _叠层信息截图如下:* J; ]0 d; W, O# T% V
) U. B4 S& x$ a; F) C( \BOM:
3 i+ d# }, t) c! e9 R+ N( z| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | waveshare_logo | 1 | WS_symbol_XL | 1 | | Header 3X2 | AI JMP, AUART JMP | Header 3x2 | 2 | | Buzzer | Buzzer1 | BUZZER2 | 1 | | 104 | C1, C5, C8, C12, C16, C25, C31, C33, C34, C35, C39, C41, C43, C45, C46, C49, C50, C53, C54 | 0603 | 19 | | 223 | C2, C3, C4, C37, C38 | 0603 | 5 | | 103 | C6 | 0603 | 1 | | 10uF | C7, C40, C42, C44, C47, C48, C51, C52 | C0805 | 8 | | 10uF | C9, C13, C14, C15, C36 | 0603 | 5 | | 105 | C10, C11 | 0603 | 2 | | 4.7uF | C17, C23, C24, C30 | 0603 | 4 | | 2.2uF | C18, C20 | 0603 | 2 | | 1uF | C19, C26, C27 | 0603 | 3 | | 100pF | C21 | 0603 | 1 | | 680pF | C22, C28, C29, C32 | 0603 | 4 | | C_0805 | C55, C56, C57, C58, C59, C60, C61 | 0603 | 7 | | Cap | C62, C63, C64, C65, C66, C67, C73, C74, C75, C76, C77, C78, C79, C80, C81, C82, C83 | 0603 | 17 | | Cap | C68 | WS_3216 | 1 | | Cap | C69, C70, C71, C72 | C0805 | 4 | | Header 9X2 | CAMERA | Header 9X2 | 1 | | 10uF | CE1, CE2 | ws_3225_1 | 2 | | IN5819 | D1 | DO_214AC | 1 | | 1N5819 | D2, D4 | DO_214AC | 2 | | 3.0V | D3 | SOD123 | 1 | | 3A | F1 | 1206-A | 1 | | 0R | FB1, FB3, FB4, FB5, FB6, R16, R52, R58 | 0603 | 8 | | BLM18PG181SN1 | FB2, L1 | 0603 | 2 | | COM76 | H1, H2 | HEADER 38X2 - 2.0MM | 2 | | Header 6 | H3 | SIP6 | 1 | | Header 8 | H4, H5 | SIP8 | 2 | | Header 10 | H6 | SIP10 | 1 | | Header 4X2 | I2C | SIP4_LyingMother X2 | 1 | | Header 3X2 | ICSP1 | SIP3X2 | 1 | | FT-009 | IR1 | HS0038B | 1 | | CONN-50x2 | J1, J2 | SMD50X2A-1.27MM | 2 | | 07TFT-40PIN | J3 | FPC40 | 1 | | 3V | J4 | CR1220 | 1 | | DC_PORT | J5 | DC3-3.5 | 1 | | HR911105A | J6 | HY911105H | 1 | | HDMI_A | J7 | HDMI_A | 1 | | TF_SD_SOCKET | J8 | TF-1 | 1 | | USB MICRO B Connector | J9, J14 | JS-MR1-4036 | 2 | | PJ313B | J10 | PJ313B | 1 | | PJ313C | J11 | PJ313C | 1 | | USB-A-DULE | J12, J13 | USB-A-DULE | 2 | | Inductor | L6, L7, L8, L9, L10, L11, L12, L13, L14, L15 | 0603 | 10 | | Header 4X2 | LED JMP, PWR | Header 4X2 | 2 | | LED_0805 | LED1, LED2, LED3, LED4, LED5 | 0805_LED | 5 | | luosihole L | luosihole L1, luosihole L2, luosihole L3, luosihole L4 | luosikong L | 4 | | MIC-4020 | MIC1 | MIC | 1 | | PWM JMP | ONE-WIRE JMP | Header 2x2 | 1 | | ds18b20 | ONEWIRE1 | DS18B20_DIP | 1 | | Header 8X2 | P1, P4 | SIP8 x2 | 2 | | Header 10X2 | P2 | SIP10X2 | 1 | | Header 6X2 | P3 | SIP6X2 | 1 | | MOSFET N | Q1, Q2 | SOT23 | 2 | | MOSFET P | Q3 | SOT23 | 1 | | PNP 8550 | Q4 | SOT-23 | 1 | | 4K7 | R1, R2, R3, R4, R5, R6, R17, R19 | 0603 | 8 | | RESISTOR 4PACK | R7, R8, R9, R10, R11, R12, R13 | 0402x4 | 7 | | 1K | R14, R15, R21 | 0603 | 3 | | 2K | R18, R20, R45, R51 | 0603 | 4 | | 33R | R22, R23, R25, R26, R28, R29, R39, R40, R41, R42, R43, R44, R46 | 0603 | 13 | | 10K%1 | R24 | 0603 | 1 | | 10R | R27, R34 | 0603 | 2 | | 1K5%1 | R30 | 0603 | 1 | | 3K3%1 | R31 | 0603 | 1 | | 100K | R32, R54, R55, R56 | 0603 | 4 | | 10K | R33, R35, R36, R37, R38, R53, R59, R60 | 0603 | 8 | | 470R | R47, R48 | 0603 | 2 | | 22R | R49, R50 | 0603 | 2 | | 2k7-1% | R57 | 0603 | 1 | | R_0805 | R61 | 0603 | 1 | | Res Semi | R62, R63, R64, R76, R77, R79 | 0603 | 6 | | Res1 | R65, R66, R67, R68, R71, R74, R75, R78, R100 | 0603 | 9 | | Header 8 | SPI0 | SIP8_LyingMother | 1 | | VOL+/RECOVER | SW1 | KEY | 1 | | VOL- | SW2 | KEY | 1 | | ESC | SW3 | KEY | 1 | | PWR-ON | SW4 | KEY | 1 | | CP2102 | U1 | QFN28(5x5) | 1 | | ALC5631Q | U2 | QFN48-6X6 | 1 | | FE1_1s | U3 | SSOP_28 | 1 | | ADV7125JSTZ240 | U4 | TSQFP50P900X900X160-48N | 1 | | BAT54S | U5, U6, U8, U9, U11, U12, U13 | SOT-23 | 7 | | SN74LVC1G126DBVT | U7, U10 | SOT23-5 | 2 | | Header 6X2 | UART0/1 | SIP6_LyingMother X2 | 1 | | Header 6 | UART3 | SIP6_LyingMother | 1 | | D Connector 15 | VGA1 | DB15_2 | 1 | | 12M | Y1 | SMD3225 | 1 | 附件:
1 Q2 q% m7 p/ Y1 @( i d* X原理图和PCB文件如下:. g, c3 ~* S+ ]
4 P4 K a5 h" N8 U
4 \, I4 _" h3 f- ?
