Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2PIN_3_81 | CON2_2PIN_3_81_3.81MM*2 | 3.81mm*2 | IC | 1 | 12V_IN |
8PIN_1_5AAA | CON20_2_8PIN_1_5AAA_8PIN -1.5MM | 8PIN -1.5mm | IC | 1 | ALM |
8XJTAG | CON20AP_2_8XJTAG_NC | NC | IC | 1 | JTAG1 |
10X2 | CON20_10X2_2X10_2.54MM | 2x10_2.54mm | IC | 1 | XIO |
B00T | JUMPER_0_B00T_FOR BOOT | For BOOT | IC | 1 | J2 |
C0402 | CAP_NP_C0402_0.1UF | 0.1uF | IC | 66 | C8; C11; C15; C33; C89; C96; C98; C99; C101; C103; C104; C106; C108; C109; C111; C113; C114; C116; C118; C119; C121; C123; C124; C126; C128; C129; C131; C133; C134; C438; C441; C442; C443; C444; C445; C447; C448; C449; C454; C456; C457; C460; C462; C466; C467; C468; C469; C470; C471; C473; C474; C476; C478; C479; C480; C481; C482; C484; C485; C487; C488; C489; C490; C491; C492; C594 |
C0402 | CAP_NP_C0402_0.01UF | 0.01uF | IC | 4 | C14; C18; C27; C436 |
C0402 | CAP NP_C0402_0.1UF | 0.1uF | IC | 21 | C43; C44; C45; C46; C47; C48; C52; C53; C54; C55; C56; C63; C69; C70; C72; C73; C74; C75; C92; C578; C593 |
C0402 | CAP_NP_C0402_0.1UF/C0603 | 0.1uF/C0603 | IC | 2 | C57; C685 |
C0402 | CAP_NP_C0402_10NF | 10nF | IC | 2 | C61; C683 |
C0402 | CAP NP_C0402_30PF | 30pF | IC | 4 | C64; C65; C66; C67 |
C0402 | C_C0402_0.1UF | 0.1uf | IC | 1 | C68 |
C0402 | GRM188-100NF-16V_C0402_0.1UF_10 | 0.1uF | IC | 36 | C76; C78; C80; C81; C595; C596; C597; C599; C606; C607; C608; C610; C617; C618; C619; C621; C628; C629; C630; C632; C639; C640; C641; C643; C650; C651; C652; C654; C661; C662; C663; C665; C672; C673; C674; C676 |
C0402 | 12061C104MAT2A_C0402_0.1UF_+-20 | 0.1uF | IC | 18 | C83; C84; C603; C604; C614; C615; C625; C626; C636; C637; C647; C648; C658; C659; C669; C670; C680; C681 |
C0402 | CAP NP_C0402_1000PF | 1000pF | IC | 9 | C86; C602; C613; C624; C635; C646; C657; C668; C679 |
C0402 | CAP NP_C0402_100PF | 100pF | IC | 9 | C88; C605; C616; C627; C638; C649; C660; C671; C682 |
C0402 | CAP_NP_C0402_0.1UF_10% | 0.1uF | IC | 4 | C90; C91; C93; C94 |
C0402 | CAP NP_0_C0402_0.1UF | 0.1uF | IC | 150 | C155; C159; C162; C170; C171; C173; C175; C176; C177; C178; C179; C180; C181; C184; C187; C190; C198; C199; C200; C201; C202; C206; C207; C208; C209; C210; C213; C217; C219; C228; C229; C230; C232; C233; C234; C235; C236; C237; C238; C240; C244; C247; C255; C256; C257; C258; C259; C262; C263; C264; C265; C269; C272; C275; C283; C284; C285; C288; C289; C290; C291; C292; C293; C294; C297; C300; C303; C311; C312; C313; C314; C315; C318; C319; C320; C321; C322; C325; C329; C331; C339; C340; C341; C342; C343; C346; C347; C348; C349; C353; C357; C359; C367; C368; C369; C370; C373; C374; C375; C376; C377; C378; C380; C385; C388; C395; C396; C397; C400; C401; C402; C403; C404; C405; C406; C408; C412; C415; C424; C425; C426; C428; C429; C430; C431; C432; C433; C434; C509; C510; C511; C513; C514; C515; C517; C518; C519; C521; C522; C523; C525; C526; C527; C529; C530; C531; C533; C534; C535; C537 |
C0402 | CAP NP_0_C0402_10NF | 10nF | IC | 90 | C156; C157; C161; C163; C164; C166; C167; C168; C169; C185; C186; C188; C191; C192; C193; C194; C195; C196; C214; C215; C218; C220; C221; C222; C223; C224; C225; C241; C242; C245; C248; C249; C250; C251; C252; C253; C270; C271; C273; C276; C277; C278; C279; C280; C281; C298; C299; C301; C304; C305; C306; C308; C309; C310; C326; C327; C330; C332; C333; C334; C335; C336; C337; C354; C355; C358; C360; C361; C362; C364; C365; C366; C381; C382; C386; C389; C390; C391; C392; C393; C394; C409; C411; C414; C416; C418; C419; C420; C421; C422 |
C0402 | CAP_NP_C0402_330NF | 330nF | IC | 1 | C439 |
C0402 | CAP_NP_C0402_2200PF | 2200pF | IC | 2 | C446; C459 |
C0402 | CAP_NP_C0402_18PF | 18pF | IC | 2 | C450; C452 |
C0402 | CAP_NP_C0402_0.1UF(NC) | 0.1uF(NC) | IC | 2 | C451; C455 |
C0402 | CAP_NP_C0402_1000PF | 1000pF | IC | 1 | C453 |
C0402 | CAP_NP_C0402_DNP | DNP | IC | 2 | C463; C465 |
C0402 | CAP_NP_C0402_6.8NF | 6.8nF | IC | 1 | C464 |
C0402 | CAP_NP_C0402_30PF | 30pF | IC | 1 | C472 |
C0402 | CAP_NP_C0402_100PF | 100pF | IC | 4 | C483; C494; C495; C575 |
C0402 | CAP0402_C0402_22PF | 22pF | IC | 2 | C686; C687 |
C0402 | CAP0603_C0402_0.1UF | 0.1uF | IC | 4 | C850; C853; C854; C862 |
C0402 | CAP0603_C0402_0.01UF | 0.01uF | IC | 2 | C852; C866 |
C0402 | CAP0402_C0402_0.1UF | 0.1uF | IC | 8 | C1006; C1007; C1017; C1019; C1020; C1022; C1024; C1025 |
C0402 | CAP0402_C0402_0.01UF | 0.01uF | IC | 3 | C1009; C1018; C1023 |
C0402_BGA | CAP0402_C0402_BGA_0.01UF | 0.01uF | IC | 55 | C890; C891; C892; C893; C894; C909; C910; C911; C918; C919; C920; C921; C922; C923; C924; C925; C926; C927; C928; C929; C930; C943; C944; C945; C946; C947; C948; C962; C963; C964; C965; C966; C967; C1026; C1027; C1028; C1029; C1030; C1031; C1032; C1033; C1034; C1035; C1036; C1037; C1038; C1039; C1040; C1041; C1042; C1043; C1044; C1045; C1046; C1047 |
C0402_BGA | CAP0402_C0402_BGA_0.1UF | 0.1uF | IC | 51 | C912; C913; C914; C915; C931; C932; C933; C934; C935; C936; C949; C950; C951; C952; C953; C954; C955; C968; C969; C970; C971; C972; C973; C974; C975; C976; C977; C978; C979; C980; C981; C982; C983; C984; C985; C986; C987; C988; C989; C990; C991; C992; C993; C994; C1002; C1003; C1004; C1010; C1011; C1012; C1013 |
C0603 | CAP_NP_C0603_1UF(25V)/C0603 | 1uF(25V)/C0603 | IC | 11 | C3; C7; C20; C21; C24; C26; C28; C29; C34; C37; C41 |
C0603 | CAP_NP_C0603_100PF/C0603 | 100pF/C0603 | IC | 3 | C9; C32; C42 |
C0603 | CAP_NP_C0603_1UF/C0603 | 1uF/C0603 | IC | 2 | C60; C684 |
C0603 | TPSA 10UF-10V_C0603_2.2UF/C0603 | 2.2uF/C0603 | IC | 9 | C77; C600; C611; C622; C633; C644; C655; C666; C677 |
C0603 | 12061C104MAT2A_C0603_0.1UF(50V) | 0.1uF(50V)/C0603 | IC | 1 | C79 |
C0603 | GRM188-100NF-16V_C0603_10UF(6V3 | 10uF(6V3)/C0603 | IC | 9 | C82; C598; C609; C620; C631; C642; C653; C664; C675 |
C0603 | CAP_C0603_10UF(6V3)/C0603 | 10uF(6V3)/C0603 | IC | 9 | C85; C601; C612; C623; C634; C645; C656; C667; C678 |
C0603 | CAP_NP_C0603_10UF(6V3)/C0603 | 10uF(6V3)/C0603 | IC | 24 | C95; C97; C100; C102; C105; C107; C110; C112; C115; C117; C120; C122; C125; C127; C130; C132; C440; C458; C477; C493; C496; C497; C576; C577 |
C0603 | CAPACITOR POL_0_C0603_10UF(6V3) | 10uF(6V3)/C0603 | IC | 60 | C158; C160; C165; C172; C174; C183; C189; C197; C203; C204; C212; C216; C226; C227; C231; C243; C246; C254; C260; C261; C266; C268; C274; C282; C286; C287; C296; C302; C307; C316; C317; C324; C328; C338; C344; C345; C350; C352; C356; C363; C371; C372; C383; C384; C387; C398; C399; C410; C413; C417; C423; C427; C508; C512; C516; C520; C524; C528; C532; C536 |
C0603 | CAP NP_C0603_0.1UF/C0805 | 0.1uF/C0805 | IC | 10 | C182; C211; C239; C267; C295; C323; C351; C379; C407; C435 |
C0603 | CAP_NP_C0603_1UF(6V3)/C0603 | 1uF(6V3)/C0603 | IC | 2 | C437; C461 |
C0603 | CAP_NP_C0603_100UF(6V3)/C1210 | 100uF(6V3)/C1210 | IC | 1 | C486 |
C0603 | CAP0603_C0603_10UF | 10uF | IC | 4 | C849; C851; C857; C864 |
C0603 | CAP0603_C0603_1UF | 1uF | IC | 13 | C865; C867; C903; C904; C905; C906; C907; C908; C940; C941; C942; C960; C961 |
C0603 | CAP0603_C0603_4.7UF | 4.7uF | IC | 29 | C888; C889; C895; C899; C900; C901; C902; C916; C917; C937; C938; C939; C956; C957; C958; C959; C995; C996; C997; C998; C999; C1000; C1001; C1005; C1008; C1014; C1015; C1016; C1021 |
C0805 | CAP_NP_C0805_10UF(25V)/C0805 | 10uF(25V)/C0805 | IC | 15 | C1; C2; C10; C12; C13; C16; C17; C19; C31; C35; C36; C50; C51; C205; C475 |
C1210 | CAP_NP_C1210_100UF(6V3)/C1210 | 100uF(6V3)/C1210 | IC | 13 | C4; C5; C6; C22; C23; C25; C38; C39; C40; C58; C59; C62; C71 |
C1210 | CAP NP_C1210_1NF | 1NF | IC | 10 | C498; C499; C500; C501; C502; C503; C504; C505; C506; C507 |
C1210 | CAP_C1210_100UF/6.3V/C1210/X5R | 100uF/6.3V/C1210/X5R | IC | 3 | C896; C897; C898 |
CAPB | 12061C104MAT2A_CAPB_2200PF/2KV_ | 2200pF/2KV | IC | 1 | C87 |
CON3 | CON3_CON3_CON3 | CON3 | IC | 1 | RS485 |
CON5 | CON5_CON5_5PIN_1.5 | 5Pin_1.5 | IC | 1 | RS232 |
CON20 | CON20_CON20_CON20 | CON20 | IC | 1 | J4 |
CON40 | CON40_CON40_CON40 | CON40 | IC | 1 | J5 |
C_BAT1 | CAPACITOR POL_C_BAT1_CR1220 | CR1220 | IC | 1 | BAT1 |
EP2AGX45F780 | EP2AGX45F780_0_EP2AGX45F780_(S1 | EP2AGX45F780_2 | IC | 1 | P1 |
H110X | H1102_NEW_H110X_H1102 | H1102 | IC | 1 | T11 |
H500X | H5007_1_H500X_PULSE H5007NL | PULSE H5007NL | IC | 10 | T1; T2; T3; T4; T5; T6; T7; T8; T9; T10 |
IND_10MMX10MM2 | INDUCTOR_IND_10MMX10MM2_MSS1048 | MSS1048-472 | IC | 2 | L1; L2 |
IND_10MMX10MM2 | INDUCTOR_IND_10MMX10MM2_MSS10_1 | MSS1048-332 | IC | 1 | L3 |
IND_10MMX10MM2 | INDUCTOR_IND_10MMX10MM2_1.5UH/5 | 1.5uH/5A | IC | 2 | L5; L11 |
JZ3472AAAA | OSC_DIP8_9_JZ3472AAAA_12.50MHZ | 12.50Mhz | IC | 1 | Y4 |
KSZ9031RN_A | KS8995M_1_KSZ9031RN_A_KSZ9031RN | KSZ9031RNX | IC | 10 | U11; U13; U14; U15; U16; U17; U18; U19; U20; U21 |
LB0603 | IND-FB_LB0603_500@100M | 500@100M | IC | 4 | FB1; FB2; FB3; FB49 |
LB0603 | FBEAD_1_LB0603_FBEAD | FBEAD | IC | 50 | FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB23; FB24; FB25; FB26; FB27; FB28; FB29; FB30; FB31; FB32; FB33; FB34; FB35; FB36; FB37; FB38; FB39; FB40; FB41; FB42; FB43; FB44; FB45; FB46; FB77; FB78; FB79; FB80; FB81; FB82; FB83 |
LB0603 | FERRITE_BEAD_LB0603_BLM18PG330 | BLM18PG330 | IC | 4 | FB48; FB74; FB75; FB76 |
LB0603 | COIL_0_LB0603_BLM21PG331SN1 | BLM21PG331SN1 | IC | 2 | L4; L7 |
LB0805 | INDUCTOR_LB0805_BLM21PG331SN1 | BLM21PG331SN1 | IC | 18 | B1; B2; B3; B4; B5; B6; B7; B8; B9; B10; B11; B12; B13; B14; B15; B16; B17; B18 |
LB0805 | IND-FB_LB0805_500@100M | 500@100M | IC | 25 | FB47; FB50; FB51; FB52; FB53; FB54; FB55; FB56; FB57; FB58; FB59; FB60; FB61; FB62; FB63; FB64; FB65; FB66; FB67; FB68; FB69; FB70; FB71; FB72; FB73 |
LB0805 | COIL_0_LB0805_0805LS-471X_L_ | 0805LS-471X_L_ | IC | 1 | L6 |
LED0603 | LED_LED0603_GRN | GRN | IC | 46 | 12V; ACT1; ACT2; ACT3; ACT4; ACT5; ACT6; ACT7; ACT8; CPU; D6; D7; D8; D9; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D21; DONE; LED1; LED2; LED3; LED4; LED5; LED6; LED7; LED8; LED9; LED10; LINK1; LINK2; LINK3; LINK4; LINK5; LINK6; LINK7; LINK8; PLL |
LED0603 | DIODE BREAKDOWN_LED0603_SD101AW | SD101AWS | IC | 3 | D1; D2; D3 |
LED0603 | ZC2800E/SOT_5_LED0603_P ESD3V3S1 | PESD3V3S1UB | IC | 7 | Z1; Z2; Z3; Z4; Z5; Z6; Z7 |
LMK01020BBBBBB | LMK04031BISQ_0_LMK01020BBBBBB_L | LMK04031BISQ | IC | 1 | U22 |
MBPD | SFP_MBPD_1.25GBPS | 1.25Gbps | IC | 8 | SFP1; SFP2; SFP3; SFP4; SFP5; SFP6; SFP7; SFP8 |
MLF-32P | KS8721_0_MLF-32P_KSZ8041NL/QFN | KSZ8041NL/QFN | IC | 9 | U8; U31; U32; U33; U34; U35; U36; U37; U38 |
OSC4P | OSC-HALF_1_OSC4P_50MHZ/10PPM/5X | 50MHZ/10PPM/5X7 | IC | 2 | U12; U30 |
QFN_32 | XRP7713_0_QFN_32_XRP7713 | XRP7713 | IC | 1 | U2 |
R0402 | RES_R0402_4.99 | 4.99 | IC | 6 | R1; R2; R7; R9; R16; R17 |
R0402 | RES_R0402_4.99/0603 | 4.99/0603 | IC | 1 | R4 |
R0402 | RES_R0402_0R | 0R | IC | 5 | R6; R12; R14; R399; R410 |
R0402 | RES_R0402_100 | 100 | IC | 5 | R10; R396; R398; R412; R413 |
R0402 | RES_R0402_100R\ | 100R\ | IC | 1 | R11 |
R0402 | RES_R0402_100K | 100K | IC | 1 | R13 |
R0402 | RES_R0402_300 | 300 | IC | 50 | R19; R78; R79; R80; R81; R94; R95; R96; R97; R110; R111; R112; R113; R126; R127; R128; R129; R194; R195; R216; R217; R238; R239; R260; R261; R282; R283; R304; R305; R326; R327; R348; R349; R370; R371; R392; R393; R402; R422; R423; R424; R425; R426; R427; R428; R429; R430; R431; R432; R453 |
R0402 | R_2_R0402_300 | 300 | IC | 8 | R20; R21; R22; R23; R24; R25; R26; R27 |
R0402 | R_2_R0402_4.99K | 4.99K | IC | 10 | R28; R46; R53; R56; R59; R449; R450; R451; R452; R454 |
R0402 | RES_R0402_10K | 10K | IC | 56 | R29; R30; R31; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R404; R407; R408; R409; R411 |
R0402 | RES_R0402_1K | 1K | IC | 6 | R32; R33; R35; R37; R397; R403 |
R0402 | R_2_R0402_49.9K/R0805 | 49.9K/R0805 | IC | 1 | R48 |
R0402 | R_2_R0402_1K | 1K | IC | 3 | R50; R54; R58 |
R0402 | R_2_R0402_100 | 100 | IC | 2 | R51; R52 |
R0402 | 270-0805_R0402_4.99K_5% | 4.99K | IC | 9 | R61; R468; R485; R502; R519; R536; R553; R570; R587 |
R0402 | 270-0805_R0402_75/R0603_5% | 75/R0603 | IC | 2 | R62; R63 |
R0402 | 270-0805_R0402_300_5% | 300 | IC | 18 | R64; R65; R469; R470; R486; R487; R503; R504; R520; R521; R537; R538; R554; R555; R571; R572; R588; R589 |
R0402 | RESISTOR_0_R0402_4.99K | 4.99K | IC | 42 | R66; R67; R73; R74; R75; R76; R471; R472; R477; R483; R488; R489; R494; R499; R505; R506; R511; R516; R517; R522; R523; R528; R532; R539; R540; R545; R549; R551; R556; R557; R562; R566; R567; R573; R574; R579; R583; R585; R590; R591; R596; R600 |
R0402 | 270-0805_R0402_49.9_5% | 49.9 | IC | 36 | R68; R69; R70; R71; R473; R474; R475; R476; R490; R491; R492; R493; R507; R508; R509; R510; R524; R525; R526; R527; R541; R542; R543; R544; R558; R559; R560; R561; R575; R576; R577; R578; R592; R593; R594; R595 |
R0402 | 10K-0805_R0402_4.99K_5% | 4.99K | IC | 1 | R72 |
R0402 | RESISTOR_0_R0402_6.49K 1% | 6.49K 1% | IC | 9 | R77; R484; R501; R518; R535; R552; R569; R586; R603 |
R0402 | RESISTOR_0_R0402_10K | 10K | IC | 96 | R174; R175; R176; R178; R182; R183; R184; R188; R191; R196; R197; R198; R200; R203; R205; R206; R210; R213; R218; R219; R220; R222; R225; R226; R227; R228; R233; R234; R240; R241; R242; R244; R246; R249; R250; R254; R257; R262; R263; R264; R266; R268; R270; R271; R272; R276; R278; R284; R285; R286; R288; R290; R291; R293; R294; R298; R301; R306; R307; R308; R310; R312; R313; R314; R315; R316; R320; R322; R328; R329; R330; R332; R336; R337; R338; R342; R344; R350; R351; R352; R354; R357; R359; R360; R364; R366; R372; R373; R374; R376; R379; R380; R381; R382; R386; R389 |
R0402 | RESISTOR_0_R0402_1K(NC) | 1K(NC) | IC | 20 | R177; R179; R199; R201; R221; R223; R243; R245; R265; R267; R287; R289; R309; R311; R331; R333; R353; R355; R375; R377 |
R0402 | RESISTOR_0_R0402_1K | 1K | IC | 36 | R180; R181; R185; R202; R204; R207; R224; R229; R247; R248; R251; R269; R273; R292; R295; R317; R334; R335; R339; R356; R358; R361; R378; R383; R481; R482; R498; R500; R515; R533; R534; R550; R568; R584; R601; R602 |
R0402 | RESISTOR_0_R0402_30 | 30 | IC | 10 | R186; R208; R230; R252; R274; R296; R318; R340; R362; R384 |
R0402 | RESISTOR_0_R0402_12.1K | 12.1K | IC | 10 | R187; R209; R231; R253; R275; R297; R319; R341; R363; R385 |
R0402 | R_R0402_75 | 75 | IC | 40 | R189; R190; R192; R193; R211; R212; R214; R215; R232; R235; R236; R237; R255; R256; R258; R259; R277; R279; R280; R281; R299; R300; R302; R303; R321; R323; R324; R325; R343; R345; R346; R347; R365; R367; R368; R369; R387; R388; R390; R391 |
R0402 | RES_R0402_49.9 | 49.9 | IC | 3 | R394; R395; R414 |
R0402 | RES_R0402_0_DNP | 0_DNP | IC | 2 | R400; R406 |
R0402 | RES_R0402_2.7K | 2.7K | IC | 3 | R401; R405; R415 |
R0402 | RES_R0402_120 | 120 | IC | 7 | R416; R417; R419; R420; R433; R434; R467 |
R0402 | RES_R0402_50 | 50 | IC | 1 | R418 |
R0402 | RES_R0402_1.2K | 1.2K | IC | 1 | R421 |
R0402 | RES_R0402_NC | NC | IC | 1 | R462 |
R0402 | 10K-0805_R0402_49.9_5% | 49.9 | IC | 2 | R463; R464 |
R0402 | RES_R0402_4.99K | 4.99K | IC | 2 | R465; R466 |
R0402 | 270-0805_R0402_0_5% | 0 | IC | 16 | R478; R479; R495; R496; R512; R513; R529; R530; R546; R547; R563; R564; R580; R581; R597; R598 |
R0402 | 10K-0805_R0402_1K_5% | 1K | IC | 8 | R480; R497; R514; R531; R548; R565; R582; R599 |
R0402 | RES_R0402_1K/1%/R0402 | 1K/1%/R0402 | IC | 1 | R604 |
R0402 | R_V_R0402_0_1%_ | 0 | IC | 3 | R605; R629; R630 |
R0402 | 270-0805_R0402_100_5% | 100 | IC | 7 | R606; R607; R608; R609; R610; R611; R612 |
R0402 | RES_R0402_0/R0402 | 0/R0402 | IC | 2 | R618; R619 |
R0402 | RES_R0402_4.7K/R0402 | 4.7K/R0402 | IC | 1 | R620 |
R0402 | R_V_R0402_4.7K | 4.7K | IC | 5 | R621; R623; R624; R626; R723 |
R0402 | R_V_R0402_1K | 1K | IC | 2 | R622; R625 |
R0402 | R_V_R0402_470 | 470 | IC | 1 | R627 |
R0402 | R_V_R0402_0 | 0 | IC | 1 | R628 |
R0402 | R_V_R0402_100 | 100 | IC | 4 | R694; R695; R696; R697 |
R0402 | R_R0402_10K | 10K | IC | 2 | R727; R728 |
R0402 | RES_R0402_2K/1%/R0402 | 2K/1%/R0402 | IC | 1 | R826 |
R0603 | RES_R0603_0R/0603 | 0R/0603 | IC | 1 | R5 |
R0603 | RES_R0603_3K/R0603 | 3K/R0603 | IC | 1 | R8 |
R0603 | RES_R0603_600 | 600 | IC | 2 | R34; R36 |
R0603 | R_2_R0603_300/0603 | 300/0603 | IC | 7 | R39; R40; R41; R42; R43; R44; R45 |
R0603 | R_R0603_10K_1% | 10K_1% | IC | 2 | R716; R725 |
R0603 | R_R0603_8.66K_1% | 8.66K_1% | IC | 1 | R717 |
R0603 | R_R0603_3.74K_1% | 3.74K_1% | IC | 1 | R726 |
R0805 | RES_R0805_4.99/R0805 | 4.99/R0805 | IC | 3 | R3; R15; R18 |
R0805 | R_2_R0805_300/R0805 | 300/R0805 | IC | 1 | R38 |
RJ45 | RJ45-1G _9_RJ45_RJ45 BELFUSE SS | RJ45 Belfuse SS-6488S-A-FLS-50 | IC | 10 | LAN1; LAN2; LAN3; LAN4; LAN5; LAN6; LAN7; LAN8; LAN9; LAN10 |
SIP3 | CON3_SIP3_CON3 | CON3 | IC | 1 | J1 |
SIP_4P | CON4_SIP_4P_CON4 | CON4 | IC | 1 | ADC |
SIP_10P | JTAG CON_SIP_10P_JTAG CON | JTAG CON | IC | 1 | U41 |
SMA | CON1_2_SMA_SMA | SMA | IC | 1 | REFCLK |
SMT_DIA10MM | CAP_POL_SMT_DIA10MM_470UF | 470uF | IC | 1 | C30 |
SO8NB | FDS8984_0_SO8NB_FDS8984 | FDS8984 | IC | 3 | U1; U3; U4 |
SO8NB | 6PIN_3_SO8NB_TMP36 | TMP36 | IC | 1 | U6 |
SO8NB | SST25VF080-FP_SO8NB_W25Q32(NC) | W25Q32(NC) | IC | 1 | U10 |
SO8NB | MAX1487_SO8NB_MAX3485CSA | MAX3485CSA | IC | 1 | U28 |
SO8NBAAA | W25Q32BVSSIG_SO8NBAAA_W25Q64BVS | W25Q64BVSSIG | IC | 1 | U26 |
SOP9-50-150 | 6PIN_0_SOP9-50-150_TPS54527DDA | TPS54527DDA | IC | 2 | U29; U39 |
SOT23 | BAS21/SOT_3_SOT23_BAS21/SOT | BAS21/SOT | IC | 1 | D5 |
SOT23 | DIODE_TUNINGVARACTORS_SOT23_SMV | SMV-1249-074LF | IC | 1 | D30 |
SOT23 | BAS21/SOT_2_SOT23_BAS21/SOT | BAS21/SOT | IC | 1 | D31 |
SOT23 | 2N6249_0_SOT23_2N3904/STO23 | 2N3904/STO23 | IC | 2 | Q1; Q2 |
SOT23 | IMP809_SOT23_CAT809S | CAT809S | IC | 1 | U7 |
SOT223-3L | AP1117_0_SOT223-3L_SPX1117M3-L | SPX1117M3-L | IC | 1 | U23 |
SSOP16 | SP3232E_0_SSOP16_SP3232 | SP3232 | IC | 1 | U9 |
TP | TEST POINT_TP_TEST POINT | Test point | IC | 4 | TP1; TP2; TP3; TP4 |
TPS74701_SON10 | TPS74701_TPS74701_SON10_TPS7480 | TPS74801 | IC | 1 | U52 |
TPS74801_SON10 | TPS74801_TPS74801_SON10_TPS7480 | TPS74801 | IC | 1 | U51 |
TQFP144 | LPC1778FBD144_1_TQFP144_LPC1778 | LPC1778FBD144 | IC | 1 | U5 |
XTAL32768 | CRYSTAL_XTAL32768_32.8K | 32.8K | IC | 1 | Y3 |
XTAL_HC49SMT | CRYSTAL_XTAL_HC49SMT_24MHZ | 24MHZ | IC | 1 | Y2 |
XTAL_HC49SMT | CRYSTAL_XTAL_HC49SMT_HC49SM-12M | HC49SM-12M288-1B25B14 | IC | 1 | Y5 |
Y200W | ZTA_Y200W_ZTA | ZTA | IC | 1 | Y1 |
Y200WA | R_3_Y200WA_5.1K(MJ5606) | 5.1K(MJ5606) | IC | 1 | R60 |
附件:
