查看: 390|回复: 2
[allegro17.2][8层]高通MSM8939核心板PCB文件(CONN72A+CON28+74LS148)原理图和pc...
发表于 2020-1-16 18:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][8层]高通MSM8939核心板PCB文件(CONN72A+CON28+74LS148)原理图和pcb文件
文件描述:
1. 作品用途:高通MSM8939核心板PCB文件
2. 软件版本:allegro17.2
3. 层数:8层
4. 用到的主要芯片:CONN72A+CON28+74LS148
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
74LS14874LS148_0_74LS148_74LS14874LS148IC1U25
0603CC_0603C_2.7NF2.7nFIC3C1; C4; C7
0603CCAP_0_0603C_1NF1nFIC6C2; C3; C5; C6; C8; C9
0603CCAP_0_0603C_0.1UF0.1uFIC19C10; C11; C12; C14; C16; C17; C18; C19; C21; C49; C50; C51; C52; C53; C54; C55; C56; C141; C142
0603CCAP_0_0603C_1UF1uFIC3C13; C15; C20
0603CC_0603C_0.1UF0.1uFIC7C28; C31; C32; C33; C38; C39; C41
0603CC_0603C_1UF1uFIC3C35; C37; C42
0603CCAP_0_0603C_2.2NF2.2nFIC1C43
0603CCAP NP_0603C_0.1UF0.1uFIC32C44; C45; C46; C58; C59; C60; C61; C62; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C102; C122; C124; C126; C127; C128; C135; C136; C137; C138; C139
0603CCAP_0_0603C_2.2UF2.2uFIC2C47; C48
0603CCAP NP_1_0603C_0.1UF0.1uFIC5C69; C70; C81; C82; C86
0603CCAP NP_1_0603C_0.01UF0.01uFIC1C85
0603CCAP NP_0603C_100PF100pFIC20C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C131; C132; C133; C134
0603CCAP NP_0603C_2222IC2C129; C130
0603LL_0_0603L_10001000IC4L1; L3; L5; L6
0603RR_0603R_270270IC6R1; R8; R9; R95; R102; R103
0603RR_0603R_4040IC6R2; R7; R10; R15; R96; R101
0603RR_0603R_1K1KIC12R3; R6; R11; R14; R16; R17; R21; R23; R25; R31; R97; R100
0603RR_0603R_00IC6R18; R19; R20; R22; R24; R26
0603RR_0603R_10K10kIC17R27; R28; R29; R54; R59; R60; R61; R68; R69; R70; R71; R72; R73; R74; R75; R88; R89
0603RR_0603R_1010IC1R30
0603RR_0603R_3333IC6R32; R33; R55; R56; R57; R58
0603RR_0603R_4747IC2R34; R35
0603RR_0603R_2K2KIC11R36; R37; R38; R39; R40; R41; R62; R63; R65; R66; R94
0603RR_0_0603R_10K10KIC9R42; R43; R44; R45; R46; R50; R81; R82; R85
0603RR_0_0603R_100K100KIC2R47; R48
0603RR_0_0603R_1K1KIC1R49
0603RR_0_0603R_3K3kIC3R51; R52; R53
0603RR_0_0603R_**IC3R67; R92; R93
0603RR_0_0603R_510R510RIC1R76
0603RR_0_0603R_49.9R49.9RIC4R77; R78; R79; R80
0603RR_0_0603R_00IC2R83; R84
0603RR_0_0603R_12.1K12.1KIC1R86
0603RR_0_0603R_1M1MIC1R87
0603RR_0_0603R_3333IC2R90; R91
0805LEDLED_0_0805LED_REDredIC3D1; D2; D3
0805RR_0805R_100 0.01%100 0.01%IC3R4; R12; R98
0805RR_0805R_**IC3R5; R13; R99
1210C_WL_0_1210C_W_600600IC1L4
1812CC_1812C_470PF/3KV470pF/3KVIC1C140
1812CCC_1812CC_6.8UF/50V6.8uF/50VIC3C64; C65; C73
ADS1258ADS1258IRTCR_3_ADS1258_ADS1258IADS1258IRTCRIC1U1
BCAP_P_0_B_10UF10uFIC5C29; C30; C34; C36; C40
BCAPACITOR POL_0_B_10UF10uFIC1C57
BCP_B_10UF10uFIC11C63; C66; C67; C68; C71; C72; C76; C79; C80; C83; C84
BCP_B_10UF/35V10uF/35vIC2C74; C77
BCAP NP_B_10UF10uFIC2C123; C125
BD982BD982_BD982_BD982BD982IC1M1
CCP_C_10UF/35V10uF/35vIC2C75; C78
CDRH4D28L_0_CDRH4D28_12UH12uHIC1L2
CON1_GCON1_CON1_G_CASEcaseIC1J6
CON9_1R27SCON9_0_CON9_1R27S_CON9CON9IC1J5
CORE_MCONN72A_CORE_M_CONN72ACONN72AIC1M5
DO214ABDIODE_DO214AB_STPS3L60SSTPS3L60SIC1D14
J30_21TJN_JCON21_J30_21TJN_J_ACC_IOACC_IOIC1J1
J30_21TJN_JCON21_J30_21TJN_J_GYRO_IOGYRO_IOIC3J2; J3; J4
J80OUT_J80_OUTOUTIC1U28
LAN8720ALAN8720_LAN8720A_LAN8720LAN8720IC1U26
NAVGATION_MCON28_NAVGATION_M_CON28CON28IC1M2
OSC-1CRYSTAL_OSC-1_25MHZ25MHzIC1Y1
OSC_5_3CRYSTAL_0_OSC_5_3_16MHZ16MHzIC1X1
SO8_160MAX492_0_SO8_160_OPA2365AIDG4OPA2365AIDG4IC1U3
SO8_160MAX3488/SO_1_SO8_160_SN65LVDM17SN65LVDM179DIC7U5; U6; U7; U15; U17; U18; U20
SO8_160OPA1632_SO8_160_OPA1632OPA1632IC3U31; U32; U33
SO236SN74LVC2G17DCKTG4_SO236_SN74LVCSN74LVC2G17DBVTIC6U21; U22; U23; U24; U27; U29
SOT23_5TPS72325DBVT_SOT23_5_TPS72325DBTPS72325DBVTIC1U13
SOT223AS1117-3_0.3_SOT223_AS1117-3.3AS1117-3.3IC1U11
SOT223AS1117-3_0.3_SOT223_AS1117-2.5AS1117-2.5IC1U12
SSMINI2_F4SML-LX1206LBI/SM_0_SSMINI2_F4_MMA2S7280GIC10D4; D5; D6; D7; D8; D9; D10; D11; D12; D13
SSO16_26_207MAX3232_1_SSO16_26_207_MAX3232EMAX3232EUEIC4U9; U14; U16; U30
TEN30_2421WINTEN30_1221WIN_TEN30_2421WIN_TENTEN30_2421WINIC1U10
THD_15WINTHD_15WIN_THD_15WIN_THD12_2410WTHD12_2410WIIC1M3
THD_15WINTHD_15WIN_THD_15WIN_TEN5_0523TEN5_0523IC1M4
TQFP100_P5MMSTM32F429A_0_TQFP100_P5MM_STM32STM32F429AIC1U8
VSSOP_8REF5020AIDGK_VSSOP_8_REF5040AIDREF5040AIDGKIC1U2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
: {2 G& L% p. w* `6 G/ t& y$ \7 b
发表于 2024-5-20 16:24 | 只看该作者
看看,了解一下!( v+ Z. K' u# F- t0 ~9 L
发表于 2024-5-20 16:27 | 只看该作者
你娃又骗人,说是原理图+PCB,却只有PCB!
GMT+8, 2025-8-11 16:34 , Processed in 0.140625 second(s), 27 queries , Gzip On.
