作品名:[AD 10][4层]工业级CAN 转以太网工控板(SN65HVD72DR+TM4C129X+INA196AIDBVR)PCB源文件2 q3 Y( D+ k" i! Z1 b, |3 M
9 v8 ~" I6 |6 f Z9 `9 O文件描述
+ S: c: D! V, ?; G& q9 g6 @, ^3 b8 \- A' s+ p
1. 作品用途:工业级CAN 转以太网工控板+ ?0 C8 X8 f, _3 V9 A4 H
# `, `5 z! E: D% H7 U
2. 软件版本:AD 10 f3 X1 S% A, r! P' d7 D$ ]
" B& h) {. z/ L; N3 v* Y! B3. 层数:4层板+ H/ s. N. g$ G8 z% c' [! U: g
) Z" R3 k6 }( ]+ Q& t4 [4. 用到的主要芯片:SN65HVD72DR+TM4C129X+INA196AIDBVR( L) B6 m H% e; S4 B1 P
' i/ p8 I. U" Z. q3 ]5. PCB尺寸:76.2mm*50.8mm- v7 r) _4 |- k6 x, l
9 f3 l M7 m: q) N/ P, y# C5 Y7 \, X0 ]2 F7 p$ h6 d% j
作品截图如下:2 ` I/ Q- C- L: c: i9 o
2 Q8 s8 k- E9 B! O0 n
顶层截图:
* U1 K* b5 U, B0 c' ^8 Y1 \" d) V
' { @6 X6 X* o1 T
9 w' }7 w( g$ _ a b4 j% G
底层截图:
1 q! x, \0 D9 t2 a% k" Y( X% {) O
/ {& I) ^# s P0 B9 s
% p5 |* h: e) P全层截图:
4 u! ~3 l0 i4 X# _' Y& q. g' C6 h
' M, T7 J6 }& g' }: Q% p3 K. D; C3 J1 I; ^4 [: M! H
叠层信息截图如下:
( s7 I) b6 o( R" X5 }* P
8 c0 \" F y t( _6 \- O* F
( Z+ n3 W4 a8 j0 ~BOM:. O' F' V5 u% D7 ?8 |8 u) ?, Y
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | C0603C106M9PACTU | C1 | 0603 | 1 | GRM188R61C104KA01D | C2, C7, C10 | 0603 | 3 | CAPC0603 | C3, C5, C11, C12, C13, C16, C18, C22, C23, C24, C25, C35, C37, C38, C39, C40, C41, C42 | 0603 | 18 | CAPC0603 | C4, C27, C28 | 0402 | 3 | CAPC0805 | C6, C17, C21, C36, C43 | 0805 | 5 | CAPC1210 | C8 | 1210 | 1 | CAPC0603 | C9 | 1812 | 1 | GRM1555C1H330JA01D | C14, C15, C45, C46, C47, C48 | 0402 | 6 | CAPC0402 | C19, C20, C26, C29, C31, C32, C33, C34 | 0402 | 8 | 06033C104JAT2A | C30, C44 | 0603 | 2 | DESD1P0RFW-7 | D1, D2, D6, D7, D11 | SOT-323 | 5 | TPD4E1U06DCK | D3 | DCK0006A_N | 1 | B72590D0050H160 | D4, D5, D16 | RESC0402N | 3 | LED-0805 | D8, D12, D13, D14, D15 | DIOC0805N | 5 | 1SMB5915BT3G | D9 | SMB | 1 | DFLS1200-7 | D10 | powerDI123 | 1 | 1000 OHM | FB1 | 0603L | 1 | Fiducial | FID1, FID2, FID3, FID4, FID5, FID6 | Fiducial10-20 | 6 | NY PMS 440 0025 PH | H1, H2, H3, H4, H5, H6 | MH3.2_H5_W6_KO8_STARHEAD | 6 | RJ45_NOMAG_NOLED | J1 | TE_6116526-1 | 1 | CON-OSTVN02A150 | J2, J4, J6, J8 | CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACK | 4 | HEADER_2041501 | J3, J7 | HDR2X5 _2MM | 2 | ZX62R-AB-5P | J5 | CON-USB-MICRO-REV | 1 | ERM8-025-05.0-L-DV-K-TR | J9 | SAMTEC_ERM8-025-05_0-L-DV-K-TR | 1 | HEADER_TMM-103-01-G-D-RA | J10 | HEADER_TMM-103[2X] | 1 | IND-WE-7440 | L1 | IND_744029100 | 1 | Size: 0.65" x 0.20 " | LBL1 | Label_650x200 | 1 | RESC0603 | R1, R2, R7, R9, R10, R11, R13, R16, R19, R21, R22, R26, R27, R29, R34, R41, R42, R49, R50, R51, R53, R55, R58, R59, R61, R62 | 0603 | 26 | CRCW04022K20JNED | R3, R60 | 0402 | 2 | RESC0402 | R4, R6, R8, R12, R17, R18, R20, R23, R24, R30, R31, R32, R33, R37, R38, R39, R40, R44, R47, R48, R52, R54, R56 | 0402 | 23 | CRCW04021M00JNED | R5 | 0402 | 1 | CRCW040233R0JNED | R14, R15, R35, R36, R43, R46 | 0402 | 6 | RC1206FR-07120RL | R25, R45 | 1206 | 2 | RESC1206 | R28 | 1206 | 1 | ERJ-3RSFR10V | R57 | 0603 | 1 | SW-EVQQ2 | SW1 | SW-EVQQ2 | 1 | HX1198FNL | T1 | XFMR_ HX1198FNL | 1 | TESTLOOP-100 | TL1, TL2, TL3 | PAD70H39 | 3 | TP1_PD40_D0.5_S50 | TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10, TP11, TP12, TP13, TP14, TP15, TP16, TP17, TP18, TP19, TP20 | TP1_PD40_D0.5_S50 | 20 | SN65HVD72DR | U1 | D0008A_N | 1 | TM4C129X | U2 | BGA212C50P19X19_1000X1000X100 | 1 | TPS2051B | U3 | DBV5 | 1 | SN65HVD256D | U4 | D0008A_L | 1 | TPS62177DQC | U5 | DQC-10P | 1 | INA196AIDBVR | U6 | SOT23-5P | 1 | XTAL-NX5032GA | Y1 | XTAL-NX5032GA | 1 |
; g# f9 _0 u1 F( ]! N附件:! M5 K, b) ?3 U/ ]
% w8 X. h0 a3 ^, f& v( hPCB源文件如下:; g4 U0 M; q, `6 C
I# ]3 ^- a9 k: }& e
) I# P+ g ^/ @0 ]6 R2 r' z
8 c! d7 w% G* I4 R) J
7 e T& ?! `1 f7 j2 n |
