查看: 1196|回复: 1
两段相同的程序在同一个ARM的小灯闪烁的频率不同,请大神看看什么问题?
发表于 2019-12-31 10:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
6 A/ ~# @) o4 t# K#include "LED.h"
* H6 N0 F5 s; E1 @( y" E
& x( x% k; |7 f8 z$ ~/*& T: P# a2 f1 g6 _. O* ?
+ ]/ k6 d$ a5 J: u" W; f9 \
º¯ÊýÃû£ºLED_GPIO_Config
/ W/ k2 j% j8 G0 {1 s- G- i" YÃèÊö £ºÅäÖÃLEDÓõ½µÄI/O¿Ú1 r1 U; W+ x1 g5 M# h0 q/ t
ÊäÈë £ºÎÞ
( D* M7 n  V) ?" |( SÊä³ö £ºÎÞ# [/ a3 N5 n+ y5 ?( R4 Z; \
$ ~' l! t; W! B, V% V4 Q+ a4 o; Avoid LED_GPIO_Config(void)
. p: b& w  L5 ^{
" A4 b2 M5 e0 t0 b: @: L; ]& B* _# ]
/¶¨ÒåÒ»¸öGPIO_InitTypeDefÀàÐ͵ĽṹÌå*/
5 e1 [+ F  r. n  `0 @: nGPIO_InitTypeDef GPIO_InitStructure;
% w: }$ K7 N! Z7 }3 v1 j
# W) l9 U3 s  J2 S' ~/*¿ªÆôGPIOCµÄÍâÉèʱÖÓ*/
& G: |* d* _* p; F0 NRCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
1 P6 |7 b$ r9 J; w% K( {
* e$ b! S& b& v$ ~/*Ñ¡ÔñÒª¿ØÖƵÄGPIOCÒý½Å*/
; x. ?6 r3 e1 k8 w  f6 `* h8 O8 }+ d
* m' h' M. E+ ^GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_5;
, O2 w, b, l* E2 n8 `# h/ O- E
3 z, @  p' m9 p) I1 j/*ÉèÖÃÒý½ÅģʽΪͨÓÃÍÆÍìÊä³ö*/
2 q' `& G5 D. D1 F6 o0 r, T) Y: kGPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
0 o* I0 U8 y. m2 r" c: p9 M7 ~
  H9 L. c* a# k9 Z/ k/*ÉèÖÃÒý½ÅËÙÂÊΪ50MHz */8 z. l4 Q6 x1 Y$ Q% V8 O4 W
0 g" t0 E* @  m: ~- Y' rGPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;8 y- Q: g$ T' x+ B
8 n, S& T2 I. X& g8 |" u2 I
/*µ÷Óÿ⺯Êý£¬³õʼ»¯GPIOC*/; L7 v+ `( M5 Y0 j5 B- ]
GPIO_Init(GPIOE, &GPIO_InitStructure);- V. i( k) E0 b  M, Q
* R+ D. l9 h' `9 r, L. M/*PA.8 Êä³ö¸ß*/
& ?% {8 n2 d6 XGPIO_SetBits(GPIOE,GPIO_Pin_5);
# I* l9 w4 K" Y7 }4 H0 r* V! j. ^  n0 x/ b
GPIO_SetBits(GPIOE,GPIO_Pin_6);
# X  u. O; b; v9 t& V% P) Z
: ~) r; l2 V. o3 o$ c- U4 |```int main(void)( Y  `. l; e& [- |4 F1 O0 }
3 x  {, \; r' K8 G2 q& f) p; t  d0 p( c  m6 `
/* LED ¶Ë¿Ú³õʼ»¯ *// i! B" @$ D7 r5 T2 i' x
LED_GPIO_Config();
0 d7 ~+ Y' I: M+ C. ?7 ?0 u4 U: _8 {; J8 K4 ?8 c* W1 W; n. Q2 k
while (1)
7 r) N# u' O9 V/ @9 D+ d2 n{: N. L. B) ^& g& G
+ |# s9 I; V6 C) y7 T6 t' \LED2_OFF;   . f. l- }: X7 r- C& F
  LED1_ON;# L3 v7 e0 x' I6 {3 U! @, e: s
Delay(0x2FFFFF);
/ w$ |# Z7 u: c) P% ^0 L$ ^0 Q  i1 f. Y+ [( D3 f6 W1 w
$ _9 o/ F5 t  o/ Y1 V% Q. K9 ]$ F    LED1_OFF;   / @' T* c' W$ s& k, u
0 x& W, X, d, B
    LED2_ON;! N0 \- l& w2 n: V/ D
Delay(0x2FFFFF);
- R7 S/ i1 H# v& Y/ ^: g
# Q" c' e0 |8 i1 @* Q8 S! ^6 i6 A' F& m) Y2 _! A' n
: W2 D7 a( P2 h8 Q}% m& Z# [# R2 t, |: Q5 \2 q
! R; I! j5 {/ u4 w3 @- m, v) X: \9 j
0 \' |2 v5 G* c& C
int main(void)
$ E2 L$ _, c/ C9 `7 q8 o! y{
5 J- {' j: u6 W' e9 U7 e7 ^. j' I8 a. B+ @9 y; I
/* LED ¶Ë¿Ú³õʼ»¯ */8 N1 q8 @" \3 i
LED_GPIO_Config();: s9 M* y' m) ?
' _7 R8 S% S% A! mwhile (1)5 o' i3 U) Z6 t) u1 o
' A, U( S1 q  I9 T! H, ?5 n" A/ N' @* V3 o. c! N
LED2_OFF;
/ w4 j) H7 X+ A5 @3 C! S# M  LED1_ON;2 Y: i/ C0 V3 [8 @: ~5 d" ~, j
Delay(0x2FFFFF);
6 O" H' n+ B" i7 ]
- T( C* Z: O1 R- v
+ w  R. A# ]7 R* V    LED1_OFF;   + Q5 J9 a; d! ?1 K: U. {
; b  {# s4 I3 i: C  p
    LED2_ON;6 X$ o' v% l+ C1 X+ W1 H
Delay(0x2FFFFF);
6 L  G* b' c+ B- w+ G0 H5 h" j+ {
4 a7 r# w; |* }7 a6 F7 p' t. [# N: g8 G3 k5 E
4 l1 ?3 G8 E9 H/, G; _+ C4 C9 u# z
void LED_GPIO_Config(void)& a: U1 y$ O; ^6 g
3 N' V# M/ [8 L1 `2 o2 z3 O( p, H
, F) K+ e/ u: |. B% v1 \" Y/¶¨ÒåÒ»¸öGPIO_InitTypeDefÀàÐ͵ĽṹÌå*/! B6 I& \. D4 x( c, ?; w# y3 }
GPIO_InitTypeDef GPIO_InitStructure;$ C+ _0 x0 i0 F& G
3 J) G' x( O, K# T# E' ^* |
/*¿ªÆôGPIOCµÄÍâÉèʱÖÓ*/$ b, y' F, ]- B8 _; V  S2 i4 W
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);5 S$ u& o1 P. I( }
3 ~7 U' l* {$ N+ Q% b/*Ñ¡ÔñÒª¿ØÖƵÄGPIOCÒý½Å*/                                                              ( b6 z; b: F- R3 T' b  m5 r
# U$ ]6 G3 R7 C$ C
4 X. n# v2 l( n! x1 O/*ÉèÖÃÒý½ÅģʽΪͨÓÃÍÆÍìÊä³ö*/" [" F) G5 ^5 P' y
* @2 Q9 _: @8 u8 l$ N; @/ z# ?& ^6 x5 \* r1 s* K/ U
4 c8 ~; x; g0 _0 o0 k# R GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
5 k) w. P- W, t2 c; B/ l
3 H! g' V+ E+ z7 G. I/*µ÷Óÿ⺯Êý£¬³õʼ»¯GPIOC*/. i7 U) d/ U% {, m  s
. U  I& z* s' J) c1 I0 N  A; _! o  R8 ^/ t* C. A
/*PA.8 Êä³ö¸ß*/
2 {9 g" L3 }  B+ \5 B GPIO_SetBits(GPIOE,GPIO_Pin_5);   2 L/ K7 y$ I2 }* V* Q1 T8 g$ `
    2019-11-29 15:37
    发表于 2019-12-31 18:58 | 只看该作者
    哥,你这是开玩笑呢吧
    GMT+8, 2025-11-25 12:48 , Processed in 0.156250 second(s), 23 queries , Gzip On.
