查看: 205|回复: 1
请教大神,小弟正在向NIOS上移植FATFS文件系统。移植完成后,调用f_open创建并打开...
发表于 2019-12-18 18:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教大神,小弟正在向NIOS上移植FATFS文件系统。移植完成后,调用f_open创建并打开一个文件,这个时候遇到“打开失败”。调试了一下,发现check_fs函数中的LD_WORD
8 g' L4 D) m& `
(&fs->win[BS_55AA])!=0xAA55判断失败,返回2。请教其中的原因。谢谢!部分代码如下:
% }9 W. M! [/ ~% a# R+ E9 T; J. ], l
static
0 D. S, u6 @( \- U9 n# z) O& y
BYTE check_fs (   /* 0:FATboor sector, 1:Valid boor sector but not FAT, 2:Not a boot sector, 3: Disk error*/
/ L  ~9 o: ^2 X! i! w3 _
    FATFS* fs, /* File system object */
1 i" G4 D" i. I' C
    DWORD sect /* Sector# (lba) to check if it is an FAT boot record ornot */
3 u' b2 F" @2 ?2 }
( ^$ c8 }  ^/ A. L
" N0 ^3 F( n& s: M: c, v) e
    WORD temp;
. C2 k2 R0 t: Z+ G1 ^
4 G* w. C% n8 T! T6 W* W) B+ `  }' D: f
    fs->wflag = 0; fs->winsect = 0xFFFFFFFF;  /* Invaidatewindow */
6 r2 D2 e( A; H! y( B
    if (move_window(fs, sect) != FR_OK)           /* Load bootrecord */
$ d) X5 d; U. L% Q' `( t4 F
       return 3;
: A" K2 P1 V4 ]
    if (LD_WORD(&fs->win[BS_55AA]) != 0xAA55) /* Check bootrecord signature (always placed at offset 510 even if the sector size is>512) */
7 W! n/ i" A0 s
        return 2;
3 x! _5 Z( M8 k, i5 n& R8 V* s
    if ((LD_DWORD(&fs->win[BS_FilSysType])& 0xFFFFFF) == 0x544146)    /* Check "FAT" string */
& P. i  z. f( d7 y( o2 Y
       return 0;
4 n) P0 w0 o& K
    if ((LD_DWORD(&fs->win[BS_FilSysType32]) &0xFFFFFF) == 0x544146)  /* Check "FAT" string */
. _' u3 b0 |! q
       return 0;
3 {0 V5 T7 t- F4 }+ |# o( C1 J+ `! v- X; h' P: M) d- Q7 F
    return 1;
5 h% {+ L% P$ f" N( k/ l
GMT+8, 2025-8-24 16:09 , Processed in 0.109375 second(s), 23 queries , Gzip On.
