| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| BGA84-32-1509E | BGA84-32-1509E | HY5PS1G1631CLFP_Y5 | IC | 2 | U22; U25 |
| BGA441-32-2323 | BGA441-32-2323 | HI3511 | IC | 1 | U21 |
| DB9-2RM | DB9-2RM | DBR30_0911206 | IO | 1 | J37 |
| DIODE2-400-50 | DIODE2-400-50 | nc | IC | 1 | D20 |
| DSW8-L | DSW8-L | ESR_0415_T_V | IC | 1 | S2 |
| GND12 | GND12 | TEST | IC | 14 | TS5; TS6; TS7; TS8; TS12; TS13; TS14; TS15; TS16; TS17; TS18; TS19; TS20; TS21 |
| HEAD-20P | HEAD-20P | 1262_200_22_1 | IO | 1 | J20 |
| HOLE125-8STAR | HOLE125-8STAR | HOLE105-8STAR | IC | 6 | M1; M2; M3; M4; M5; M6 |
| HOLE285-125 | HOLE285-125 | HOLE125 | IC | 2 | J21; J22 |
| HSC0402 | HSC0402 | 100nF | IC | 21 | C39; C40; C41; C42; C349; C354; C359; C360; C361; C366; C367; C368; C369; C370; C371; C372; C373; C374; C1016; C1017; C1018 |
| HSC0603 | HSC0603 | 470nF | IC | 2 | C644; C645 |
| HSC0805 | HSC0805 | 10uF | IC | 4 | C922; C923; C924; C925 |
| HSDC9-3028 | HSDC9-3028 | 676000007 | IC | 1 | J16 |
| ID-BOARD | ID-BOARD | | IC | 6 | ID1; ID2; ID3; ID4; ID5; ID6 |
| IDC20-DTM1 | IDC20-DTM1 | HU5_200PNA_S53T_FA | IO | 1 | J17 |
| MJ8-SRLFY | MJ8-SRLFY | RJHS_5481 | IO | 1 | J23 |
| MLF32-050-0505LE | MLF32-050-0505LE | TLV320AIC31IRHBR | IC | 1 | U23 |
| MLF40-050-0606L | MLF40-050-0606L | ADV7179KCP_REEL | IC | 1 | U24 |
| PCI120-50V32B-F | PCI120-50V32B-F | R_754_1204_114_9622 | IC | 1 | J15 |
| PCI124-UN32BIT | PCI124-UN32BIT | GOLDEN | IO | 1 | J3 |
| PMR0104-200RQ | PMR0104-200RQ | 174552_1 | IC | 1 | J7 |
| PSW3-RA | PSW3-RA | BR_11C_11P6 | IC | 1 | S1 |
| PWC0103-M-C | PWC0103-M-C | DC2026_00 | IC | 1 | J4 |
| QFP48HA-50-0707L | QFP48HA-50-0707L | RTL8201CP | IC | 1 | U27 |
| QFP100-040-1212L | QFP100-040-1212L | TW2815 | IC | 2 | U19; U20 |
| QFP176-040-2020L | QFP176-040-2020L | SII3114 | IC | 1 | U12 |
| SATA7-RM-A | SATA7-RM-A | 674901221_SD | IC | 2 | J26; J27 |
| SBAT2-3209 | SBAT2-3209 | 796136_1 | IC | 1 | U3 |
| SC0402 | SC0402 | 100nF | IC | 50 | C58; C59; C60; C61; C62; C63; C64; C65; C66; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C219; C220; C882; C885; C1036; C1037; C1038; C1039; C1040; C1041; C1042; C1043; C1044; C1045; C1046; C1047; C1048; C1049; C1050; C1051; C1052; C1053; C1054; C1055; C1056; C1057; C1060 |
| SC0603 | SC0603 | 27pF | IC | 198 | C4; C5; C6; C37; C38; C43; C46; C47; C49; C67; C68; C77; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C119; C120; C121; C122; C123; C125; C126; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C178; C179; C180; C187; C188; C189; C190; C191; C192; C193; C194; C195; C196; C197; C204; C207; C212; C213; C216; C217; C218; C241; C242; C246; C247; C248; C249; C310; C311; C312; C313; C682; C685; C686; C687; C694; C695; C707; C710; C711; C712; C713; C714; C718; C719; C720; C721; C722; C723; C724; C725; C736; C737; C738; C739; C740; C741; C742; C743; C744; C745; C746; C810; C811; C812; C813; C814; C815; C816; C817; C818; C819; C821; C822; C823; C824; C825; C827; C828; C830; C831; C832; C833; C834; C835; C837; C838; C839; C840; C841; C842; C843; C844; C846; C848; C849; C850; C851; C852; C853; C854; C855; C856; C857; C881; C900; C901; C902; C907; C908; C926; C1001; C1002; C1003; C1005; C1006; C1007; C1019; C1020; C1021; C1022; C1023; C1024; C1025; C1026; C1027; C1028; C1029; C1030; C1031; C1032; C1033; C1034; C1059 |
| SC0805 | SC0805 | 10nF | IC | 38 | C73; C74; C75; C76; C112; C181; C182; C198; C205; C206; C214; C729; C732; C918; C920; C932; C933; C934; C935; C936; C937; C938; C939; C941; C942; C943; C944; C945; C946; C947; C948; C949; C950; C951; C1008; C1009; C1058; C1062 |
| SC1206 | SC1206 | 1000nF | IC | 7 | C32; C177; C199; C200; C201; C202; C203 |
| SC1210 | SC1210 | 10uF | IC | 5 | C29; C208; C209; C1010; C1012 |
| SCAPC2-280-327 | SCAPC2-280-327 | 100uF | IC | 3 | C36; C1063; C1064 |
| SD0805-LED | SD0805-LED | LED | IC | 8 | D5; D6; D7; D8; D9; D10; D13; D14 |
| SD2723 | SD2723 | DZ | DISCRETE | 1 | D1 |
| SED124-32FP | SED124-32FP | 1470464_3 | IC | 1 | J35 |
| SEN3-100C | SEN3-100C | 3638A | IC | 1 | D4 |
| SF6127 | SF6127 | SSQ12 | DISCRETE | 1 | F1 |
| SIP-1P | SIP-1P | TSW_101_23_F_S | IC | 4 | J38; J39; J40; J41 |
| SIP-2P | SIP-2P | ASP_113626_01 | IC | 1 | J45 |
| SIP-2P-156A | SIP-2P-156A | * | IC | 1 | J6 |
| SIP-3P | SIP-3P | 201_040_003_05_3 | IC | 1 | J1 |
| SIP-4P | SIP-4P | 826629_4 | DISCRETE | 1 | J14 |
| SIP-5P | SIP-5P | TSW_105_23_F_S | DISCRETE | 1 | J18 |
| SL0805 | SL0805 | MGLB2012_220T_LF | IC | 23 | LB1; LB2; LB3; LB5; LB6; LB7; LB8; LB9; LB10; LB11; LB12; LB13; LB15; LB16; LB17; LB18; LB19; LB21; LB22; LB23; LB24; LB25; LB27 |
| SL1210 | SL1210 | 1.8uH | IC | 1 | L1 |
| SOP8-50-150 | SOP8-50-150 | MIC2025_2BM | IC | 6 | Q8; Q1001; U1; U7; U10; U1002 |
| SOP8-50-150-230 | SOP8-50-150-230 | MOCD211M | IC | 1 | U13 |
| SOP8-50-150A | SOP8-50-150A | PI6C2405A_1HWEX | IC | 1 | U6 |
| SOP8-50-160B | SOP8-50-160B | AT24C64AN_10SI_27 | IC | 1 | U26 |
| SOP16-26-208-255 | SOP16-26-208-255 | ICL3232EIA_T | IC | 2 | U5; U29 |
| SOP16H-26-173A | SOP16H-26-173A | TPS54550PWP | IC | 1 | U31 |
| SOP16H-26-173B | SOP16H-26-173B | TPS54350PWPR | IC | 1 | U1001 |
| SOP56-20-250-550 | SOP56-20-250-550 | SN74CBTLV16212GR | IC | 4 | U2; U16; U17; U18 |
| SOP56-20-720 | SOP56-20-720 | S29GL256N10TFI010 | IC | 1 | U4 |
| SOT23 | SOT23 | PMOS-GSD | IC | 34 | D2; D3; D15; D16; D17; D18; D19; D36; D37; D38; D39; D44; D45; D46; D47; D48; D53; D54; D55; D56; D57; D58; D59; D60; D62; D63; D64; D65; D66; D67; Q1; Q5; Q6; Q7 |
| SOT23-5B | SOT23-5B | SN74LVC1G125DBVR | IC | 2 | U14; U15 |
| SOT23-6A | SOT23-6A | SRV05-4 | IC | 2 | U28; U30 |
| SOT-DPAK | SOT-DPAK | 0 | IC | 3 | U8; U9; U11 |
| SPL0707C | SPL0707C | 2.3uH | IC | 2 | L2; L1001 |
| SR0603 | SR0603 | 69.8K | IC | 299 | C70; D61; R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R13; R14; R15; R16; R17; R18; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R65; R66; R67; R68; R70; R71; R72; R73; R74; R75; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R139; R140; R141; R142; R143; R144; R149; R150; R151; R153; R154; R155; R156; R157; R158; R160; R161; R162; R163; R164; R165; R166; R167; R168; R177; R207; R208; R209; R210; R268; R269; R271; R272; R273; R274; R295; R437; R465; R481; R482; R507; R508; R1001; R1002; R1004; R1005; R1008; R1009; R1653; R1654; R1655; R1656; R1657; R1658; R1659; R1660; R1661; R1662; R1701; R1702; R1703; R1704; R1705; R1706; R1707; R1708; R1709; R1710; R1711; R1712; R1713; R1714; R1715; R1716; R1719; R1752; R1753; R1754; R1755; R1756; R1757; R1758; R1759; R1760; R1761; R1763; R1764; R1765; R1766; R1767; R1768; R1769; R1770; R1771; R1772; R1773; R1774; R1775; R1776; R1779; R1783; R1784; R1785; R1786; R1789; R1790; R1791; R1792; R1793; R1794; R1795; R1796; R1797; R1798; R1800; R1801; R1814; R1815; R1824; R1825; R1827; R1829; R1830; R1831; R1832; R1833; R1834; R1835; R1836; R1838; R1848; R1849; R1853; R1855; R1856; R1863; R1864; R1865; R1866; R1868; R1869; R1870; R1872; R1876; R1877; R1878; R1879; R1880; R1881; R1891; R1892; R1893; R1894; R1895; R1896; R1897; R1898; R1899; R1900; R1905; R1906; R1907; R1908; R1909; R1910; R1911; R1912; R1913; R1914; R1915; R1919; R1920; R1921 |
| SR0805 | SR0805 | 0 | IC | 26 | R12; R43; R69; R76; R133; R134; R135; R136; R137; R138; R145; R146; R147; R148; R159; R1003; R1697; R1698; R1699; R1700; R1882; R1916; R1917; R1918; R1922; R1923 |
| SRLY8-87-283 | SRLY8-87-283 | UD2_3NU_L5 | IC | 1 | K1 |
| SRN8-1608 | SRN8-1608 | 33 | IC | 26 | RN9; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN27; RN29; RN30; RN31; RN32; RN33; RN34; RN35; RN44; RN45; RN46; RN47; RN48; RN49; RN50; RN51 |
| SSW-PUSH | SSW-PUSH | TL3301AF160RG | IC | 2 | S4; S5 |
| STC3216 | STC3216 | 2.2uF/nc | IC | 47 | C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C20; C21; C22; C24; C25; C26; C27; C31; C69; C71; C72; C221; C375; C376; C380; C381; C382; C383; C658; C659; C663; C666; C667; C669; C671; C673; C674; C677; C678; C681; C726; C1013; C1014; C1015; C1035 |
| STC3528 | STC3528 | 33uF | IC | 6 | C210; C211; C222; C909; C1004; C1011 |
| STC7343 | STC7343 | 47uF | IC | 12 | C1; C2; C44; C45; C113; C114; C115; C116; C117; C118; C326; C1061 |
| STFM16-50-285 | STFM16-50-285 | H1260T | DISCRETE | 1 | T1 |
| SWBC0112-40T | SWBC0112-40T | C1OT_1_NAB | IC | 2 | J43; J44 |
| SX2-1205 | SX2-1205 | 25MHz | IC | 4 | X2; X3; X4; X5 |
| SX4-0705 | SX4-0705 | 54MHz/nc | DISCRETE | 4 | OSC1; OSC2; OSC9; OSC11 |
| TSW4-RG | TSW4-RG | | IC | 1 | S6 |
| USB4-1415 | USB4-1415 | 292303_1 | IC | 2 | J13; J19 |
| VAF2 | VAF2 | AV_84_5Y_HW | IO | 1 | J2 |
| VAF3-A | VAF3-A | AV2_84_9B_PB | IC | 2 | J10; J11 |
| VAF5-A | VAF5-A | PJ_324M | IC | 1 | J5 |
| VAF12-RF | VAF12-RF | AV8_84_13T_PB_HW | IC | 2 | J8; J9 |
| XTAL2-100 | XTAL2-100 | 0.0328MHz | IC | 1 | X1 |
