查看: 1059|回复: 0
cadence17.2__ORCAD无法导出PDF
    郁闷
    2019-11-22 15:10
    发表于 2019-11-14 09:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    破解版17.2.第一次用。发现无法将原理图导出为PDF。
    ERROR(ORCAP-43004): Unable to find the executable gswin64c.exe at the specified path. If the executable is available in your system, specify its path. If it is not available, download from http://ghostscript.com/download/, install, and specify the path
    0 N- g, S9 `( X5 e! V
    GMT+8, 2025-11-22 22:06 , Processed in 0.187500 second(s), 27 queries , Gzip On.
