查看: 227|回复: 1
modelsim 时钟采集的数据是错误的?
发表于 2019-10-11 14:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用modelsim进行仿真时,在延一拍处理过程中,出现数据采集不到,pix_data_1d的数据采集不到,代码如下:reg fram_h1d;
* t: k+ s2 V& K3 a7 @/ @reg fram_h2d;, i& H9 r( @3 P
reg fram_h3d;
: ?$ \/ R0 K4 U* A' \; B5 M) `reg fram_h4d;9 d0 \. g9 j0 Z
reg fram_h5d;. E6 l+ e7 s) x( g) |( A
reg fram_hpose_2d;/ I1 U5 Q% u. ^) |# z4 d5 N
reg fram_hnege_1d;
% t+ U9 H& v! g$ L9 i3 ereg fram_hnege_2d;
& g$ M, N: H. f" W) W. f9 m4 kreg fram_hnege_3d;- K2 B: Z8 Z1 t( Z! F4 T0 G+ ]
; C/ p" y$ y% V6 |* T
4 j+ y' d6 t; V4 z
reg [ 9:0] pix_data_1d;, i" ?% f( q+ M$ a0 W4 r
reg [ 9:0] pix_data_2d;9 C0 ]5 I. u  P& ^/ S
reg [ 9:0] pix_data_3d;
2 C( Y4 Z: U- e% \) preg [ 9:0] pix_data_4d;* N  d9 {- r- n  }9 j
always@( posedge CLK or negedge RST_N )
$ p7 s1 C* e% F! dbegin6 w' ^, N, d& p3 D& y( l/ w
    IF( RST_N == 1'b0 )/ z% p; u$ k0 j
        begin1 b! g( G2 L4 c* N
            fram_h1d      <= 1'b0 ;
: t, }) W1 B. i  h. c            fram_h2d      <= 1'b0 ;8 ]/ M" d7 n/ d5 s: V8 }
            fram_h3d      <= 1'b0 ;  k* }, M# R2 b2 R6 O( i# q
            fram_h4d      <= 1'b0 ;# l5 x- ^3 t; W1 q! `7 M
            fram_h5d      <= 1'b0 ;
; J8 m; J8 c" w; k* C2 K% H            fram_v1d      <= 1'b0 ;
2 b0 \8 \, P4 j' Z0 N, i' B$ M            fram_v2d      <= 1'b0 ;  . o! t3 t$ x9 b2 q4 Q& y
            fram_v3d      <= 1'b0 ;: H$ z, h3 o# {5 ~
            fram_v4d      <= 1'b0 ;0 ]' g3 ^) P- o. p6 M& `
            fram_v5d      <= 1'b0 ;
( [" Y# v1 {. F7 G2 v% W' J            fram_v6d      <= 1'b0 ;" m0 H$ F9 O0 D! r) ?
            fram_hpose_2d <= 1'b0 ;4 x# x2 A4 r; p$ ^3 y
            fram_hnege_1d <= 1'b0 ;8 c: x' x( U, g
            fram_hnege_2d <= 1'b0 ;
7 T4 E5 h! `$ E. E1 X. @3 [7 _            fram_hnege_3d <= 1'b0 ;
1 g" Q4 j3 ]) p7 G! a1 c, S  C1 h        end
* s, `" m; c3 G; l: p' u6 H    else
' q# f& ]7 Z4 e  `        begin
+ E( \) Q, L- }( \  U            fram_h1d      <= FRAME_HI ;: X" Z# n4 i6 B# y
            fram_h2d      <= fram_h1d ;
/ L/ ]3 ]: Q0 o1 Z# ~' j& d! q            fram_h3d      <= fram_h2d ;
9 c3 a& c; W- i+ E" V            fram_h4d      <= fram_h3d ;
- O: d/ s6 H- M5 J- a  S9 N            fram_h5d      <= fram_h4d ;# M9 P" ]& O; a9 `
            fram_v1d      <= FRAME_VI ;  n- ]: N1 M+ W" X7 j( O8 h0 C: G. T
            fram_v2d      <= fram_v1d ;  - Y, m% p& O5 F( J8 n. L' Z/ o
            fram_v3d      <= fram_v2d ;; i# N) H$ Z; k1 x& H- v" J
            fram_v4d      <= fram_v3d ;
1 W% s: x7 E+ K/ X            fram_v5d      <= fram_v4d ;
  A4 W0 B* q. k, `1 o            fram_v6d      <= fram_v5d ;5 a+ \+ e& S8 g' \# ^: J* {2 N$ Z1 I
            fram_hnege_2d <= fram_hnege_1d ;( u& q4 e5 j/ z' O
            fram_hnege_3d <= fram_hnege_2d ;8 ~( o& C+ \* G2 @& e5 ^$ m( f$ d! W% k
            fram_hpose_2d <= fram_h1d && ( !fram_h2d ) ;1 g" w& i0 h, L* A( H' N
            fram_hnege_1d <= fram_h1d && ( !FRAME_HI ) ;5 g0 J" E8 q% |1 u& L( o1 L/ X
        end8 z# y7 E- E3 z) Y
end
1 Y! g5 v0 I7 _) G$ w: j
: [6 D) M  @1 H
2 y6 {4 K: M' w( F4 n7 B1 ^0 r6 U' J2 ?  G
. K6 s7 F# b& J& V7 q! \, e2 O; Z5 X/ S
0 @' L* J" `8 l) S( A
发表于 2019-10-11 18:45 | 只看该作者
pix_data_1d的数据采集不到可能没调好吧
GMT+8, 2025-8-20 17:48 , Processed in 0.109375 second(s), 23 queries , Gzip On.
