- ODDR #(* m% k, v, S! U7 h
- .DDR_CLK_EDGE("OPPOSITE_EDGE"), // "OPPOSITE_EDGE" or "SAME_EDGE"
/ H6 p6 m- O7 K2 o) i - .INIT(1'b0), // Initial value of Q: 1'b0 or 1'b1
0 f7 E5 N3 q4 Y) Z2 @/ z# m - .SRTYPE("SYNC") // Set/Reset type: "SYNC" or "ASYNC"
9 Y2 ?8 s0 L- W: z- x+ D3 _( S - ) ODDR_SCK_inst (
* R6 R: ~* o# P5 m- W - .Q( SPI_SCLK ), // 1-bit DDR output( I$ P1 \% w+ H2 M- ^# ~+ y
- .C( clk10M ), // 1-bit clock input2 `0 I' H7 T* X( B( x4 H
- .CE( 1'b1 ), // 1-bit clock enable input. h2 r7 \& S, x5 r
- .D1( 1'b0 ), // 1-bit data input (positive edge)
/ v( Q' c. d' S z& H: T# E8 V/ Z - .D2( ~SPI_SEN_B ), // 1-bit data input (negative edge)
" ^! L4 d" H: C8 M2 [ - .R( 1'b0 ), // 1-bit reset
0 I6 r% X- J/ ?3 c9 H- @ - .S( 1'b0 ) // 1-bit set& A/ @4 M- ]$ P: u$ ]9 Z
复制代码 开头ODDR之后为啥跟了一个#呢?谢谢大佬帮助
5 Z" G+ ^- Z# x0 j |
