- ' S6 t) Q3 r( Q- L; w
- * linux/lib/string.c
- * Copyright (C) 1991, 1992 Linus Torvalds
- ) k H4 h- `1 _0 S% J
- * stupid library routines.. The optimized versions should generally be found
- * as inline code in <asm-xx/string.h>
- * These are buggy as well..
- * * Fri Jun 25 1999, Ingo Oeser
- * - Added strsep() which will replace strtok() soon (because strsep() is
- * reentrant and should be faster). Use only strsep() in new code, please.
- * * Sat Feb 09 2002, Jason Thomas ,
- * Matthew Hawkins
- * - Kissed strtok() goodbye
- . s0 q) j+ J- P; I) p
- #include <linux/types.h>
- #include <linux/string.h>
- #include <linux/ctype.h>
- #include <linux/module.h>
5 i9 d& b# \7 |+ V7 w v5 S- #ifndef __HAVE_ARCH_STRNICMP
- * strnicmp - Case insensitive, length-limited string comparison
- * @s1: One string
- * @s2: The other string
- * @len: the maximum number of characters to compare
- int strnicmp(const char *s1, const char *s2, size_t len)
- /* Yes, Virginia, it had better be unsigned */
- unsigned char c1, c2;
- ! @- i& g( y/ \( c* k6 m
- c1 = 0; c2 = 0;
- if (len) {
- do {
- c1 = *s1; c2 = *s2;
- s1++; s2++;
- if (!c1)
- break;
- if (!c2)
- break;
- if (c1 == c2)
- continue;
- c1 = tolower(c1);
- c2 = tolower(c2);
- if (c1 != c2)
- break;
- } while (--len);
- return (int)c1 - (int)c2;
0 W& |: u' j0 @- EXPORT_SYMBOL(strnicmp);
- #endif
- 2 P6 c& @6 i3 ~" b4 @
- #ifndef __HAVE_ARCH_STRCPY
- * strcpy - Copy a %NUL terminated string
- * @dest: Where to copy the string to
- * @src: Where to copy the string from
- #undef strcpy
- char * strcpy(char * dest,const char *src)
- char *tmp = dest;
- , X, W9 X" `( [$ W2 j) c
- while ((*dest++ = *src++) != '/0')
- /* nothing */;
- return tmp;
- EXPORT_SYMBOL(strcpy);
- #endif
0 d2 P. G# ^: _- #ifndef __HAVE_ARCH_STRNCPY
- * strncpy - Copy a length-limited, %NUL-terminated string
- * @count: The maximum number of bytes to copy
- * The result is not %NUL-terminated if the source exceeds
- * @count bytes.
- * In the case where the length of @src is less than that of
- * count, the remainder of @dest will be padded with %NUL.
- char * strncpy(char * dest,const char *src,size_t count)
- char *tmp = dest;
" {. d! `5 Z; ~6 ?4 u. N6 R- while (count) {
- if ((*tmp = *src) != 0) src++;
- tmp++;
- count--;
- return dest;
- EXPORT_SYMBOL(strncpy);
- #endif
- t% O! j, D0 f+ Z/ u
- #ifndef __HAVE_ARCH_STRLCPY
- * strlcpy - Copy a %NUL terminated string into a sized buffer
- * @size: size of destination buffer
- * Compatible with *BSD: the result is always a valid
- * NUL-terminated string that fits in the buffer (unless,
- * of course, the buffer size is zero). It does not pad
- * out the result like strncpy() does.
- size_t strlcpy(char *dest, const char *src, size_t size)
- size_t ret = strlen(src);
- 6 B) [* | D3 K' f
- if (size) {
- size_t len = (ret >= size) ? size-1 : ret;
- mEMCpy(dest, src, len);
- dest[len] = '/0';
- return ret;
- EXPORT_SYMBOL(strlcpy);
- #endif
- 5 ]0 k+ I" N' K/ d: G, x1 G
- #ifndef __HAVE_ARCH_STRCAT
- * strcat - Append one %NUL-terminated string to another
- * @dest: The string to be appended to
- * @src: The string to append to it
- #undef strcat
- char * strcat(char * dest, const char * src)
- char *tmp = dest;
! f: z% T( W7 }* J: Q8 n2 s- while (*dest)
- dest++;
- L/ u- S7 H& [4 N- return tmp;
- EXPORT_SYMBOL(strcat);
- #endif
- $ n8 m6 I$ e+ A, W+ _* |: {( K
- #ifndef __HAVE_ARCH_STRNCAT
- * strncat - Append a length-limited, %NUL-terminated string to another
- * @count: The maximum numbers of bytes to copy
- * Note that in contrast to strncpy, strncat ensures the result is
- * terminated.
- char * strncat(char *dest, const char *src, size_t count)
- char *tmp = dest;
$ ^8 w% C3 E, U; M- if (count) {
- while (*dest)
- dest++;
- while ((*dest++ = *src++) != 0) {
- if (--count == 0) {
- *dest = '/0';
- break;
7 c& v5 ]3 C; H3 B! i9 M- return tmp;
- EXPORT_SYMBOL(strncat);
- #endif
- w/ b: f. r) T- #ifndef __HAVE_ARCH_STRLCAT
- * strlcat - Append a length-limited, %NUL-terminated string to another
- * @count: The size of the destination buffer.
- size_t strlcat(char *dest, const char *src, size_t count)
- size_t dsize = strlen(dest);
- size_t len = strlen(src);
- size_t res = dsize + len;
- / |. y [% j% D0 K) n
- /* This would be a bug */
- BUG_ON(dsize >= count);
) \) Z5 @( M' M0 t" u# @4 t+ n9 z6 a- dest += dsize;
- count -= dsize;
- if (len >= count)
- len = count-1;
- memcpy(dest, src, len);
- dest[len] = 0;
- return res;
- EXPORT_SYMBOL(strlcat);
- #endif
- ' M1 y7 _- C' D/ e
- #ifndef __HAVE_ARCH_STRCMP
- * strcmp - Compare two strings
- * @cs: One string
- * @ct: Another string
- #undef strcmp
- int strcmp(const char * cs,const char * ct)
- register signed char __res;
( h. ?, T! g9 m L5 v- while (1) {
- if ((__res = *cs - *ct++) != 0 || !*cs++)
- break;
- # x9 X& [# n( {- O
- return __res;
- EXPORT_SYMBOL(strcmp);
- #endif
- Y! E, y5 Z1 [! p0 S* I- #ifndef __HAVE_ARCH_STRNCMP
- * strncmp - Compare two length-limited strings
- * @cs: One string
- * @count: The maximum number of bytes to compare
- int strncmp(const char * cs,const char * ct,size_t count)
- register signed char __res = 0;
* I- q' d5 Z; t7 R2 b' }- while (count) {
- break;
- count--;
- 2 c* \9 p- |0 a+ n# M, n+ n4 N
- return __res;
- EXPORT_SYMBOL(strncmp);
- #endif
- - H9 _$ d+ _& e+ a" M1 c( r) P
- #ifndef __HAVE_ARCH_STRCHR
- * strchr - Find the first occurrence of a character in a string
- * @s: The string to be searched
- * @c: The character to search for
- char * strchr(const char * s, int c)
- for(; *s != (char) c; ++s)
- if (*s == '/0')
- return NULL;
- return (char *) s;
- EXPORT_SYMBOL(strchr);
- #endif
- , N' ]* O0 }: J6 u. e5 C
- #ifndef __HAVE_ARCH_STRRCHR
- * strrchr - Find the last occurrence of a character in a string
- char * strrchr(const char * s, int c)
- const char *p = s + strlen(s);
- do {
- if (*p == (char)c)
- return (char *)p;
- } while (--p >= s);
- return NULL;
- EXPORT_SYMBOL(strrchr);
- #endif
0 @+ f2 n, L4 e6 t) t- u+ S- #ifndef __HAVE_ARCH_STRNCHR
- * strnchr - Find a character in a length limited string
- * @count: The number of characters to be searched
- char *strnchr(const char *s, size_t count, int c)
- for (; count-- && *s != '/0'; ++s)
- if (*s == (char) c)
- return NULL;
- EXPORT_SYMBOL(strnchr);
- #endif
- 8 i- }8 {9 {- h2 ~0 m
- #ifndef __HAVE_ARCH_STRLEN
- * strlen - Find the length of a string
- * @s: The string to be sized
- size_t strlen(const char * s)
- const char *sc;
- ) z! |8 z' ~2 P0 D# A! j6 N1 G1 Q5 r
- for (sc = s; *sc != '/0'; ++sc)
- /* nothing */;
- return sc - s;
- EXPORT_SYMBOL(strlen);
- #endif
) R2 }( C9 |& J- #ifndef __HAVE_ARCH_STRNLEN
- * strnlen - Find the length of a length-limited string
- * @count: The maximum number of bytes to search
- size_t strnlen(const char * s, size_t count)
- const char *sc;
- ( w. o c8 [ ~) w5 U7 Z
- for (sc = s; count-- && *sc != '/0'; ++sc)
- /* nothing */;
- return sc - s;
- EXPORT_SYMBOL(strnlen);
- #endif
+ e5 H( H' c/ o5 \+ |+ q2 _/ j- #ifndef __HAVE_ARCH_STRSPN
- * strspn - Calculate the length of the initial substring of @s which only
- * contain letters in @accept
- * @accept: The string to search for
- size_t strspn(const char *s, const char *accept)
- const char *p;
- const char *a;
- size_t count = 0;
l& y4 _! [" {5 }! ]* U! A" x- K- for (p = s; *p != '/0'; ++p) {
- for (a = accept; *a != '/0'; ++a) {
- if (*p == *a)
- break;
- if (*a == '/0')
- return count;
- ++count;
) }" u. B8 E/ W6 j0 M- return count;
. ^5 L! X0 S- Q; `7 @* q5 z) \- EXPORT_SYMBOL(strspn);
- #endif
# F3 K! g4 C. ^1 H+ L/ s, t- /**
- * strcspn - Calculate the length of the initial substring of @s which does
- * not contain letters in @reject
- * @reject: The string to avoid
- size_t strcspn(const char *s, const char *reject)
- const char *p;
- const char *r;
- size_t count = 0;
, D3 s* F% O' |5 ]# L& p- for (p = s; *p != '/0'; ++p) {
- for (r = reject; *r != '/0'; ++r) {
- if (*p == *r)
- return count;
- ++count;
- + c! s7 `; t0 X7 B
- return count;
- EXPORT_SYMBOL(strcspn);
( L$ P/ e. [5 G! _- #ifndef __HAVE_ARCH_STRPBRK
- * strpbrk - Find the first occurrence of a set of characters
- * @cs: The string to be searched
- * @ct: The characters to search for
- char * strpbrk(const char * cs,const char * ct)
- const char *sc1,*sc2;
- 3 F# b1 S; l. J1 [* V; C" ]
- for( sc1 = cs; *sc1 != '/0'; ++sc1) {
- for( sc2 = ct; *sc2 != '/0'; ++sc2) {
- if (*sc1 == *sc2)
- return (char *) sc1;
- return NULL;
- EXPORT_SYMBOL(strpbrk);
- #endif
5 s [1 W" R2 G: `" o, F- #ifndef __HAVE_ARCH_STRSEP
- * strsep - Split a string into tokens
- * strsep() updates @s to point after the token, ready for the next call.
- * It returns empty tokens, too, behaving exactly like the libc function
- * of that name. In fact, it was stolen from glibc2 and de-fancy-fied.
- * Same semantics, slimmer shape. ;)
- char * strsep(char **s, const char *ct)
- char *sbegin = *s, *end;
6 O) f9 Z! _& E; R- if (sbegin == NULL)
- return NULL;
# n, c8 j. ?+ m# D- end = strpbrk(sbegin, ct);
- if (end)
- *end++ = '/0';
- *s = end;
( {3 t C( _5 v( @- return sbegin;
- & m$ m3 |/ e0 S7 F8 i2 j8 b& r L! i; k: L
- EXPORT_SYMBOL(strsep);
- #endif
5 X% n: J5 h }+ A8 m- #ifndef __HAVE_ARCH_MEMSET
- * memset - Fill a region of memory with the given value
- * @s: Pointer to the start of the area.
- * @c: The byte to fill the area with
- * @count: The size of the area.
- * Do not use memset() to access IO space, use memset_io() instead.
- void * memset(void * s,int c,size_t count)
- char *xs = (char *) s;
- . m5 A! c6 l, `9 j1 \) T" {) O
- while (count--)
- *xs++ = c;
- 3 L2 g9 D/ }# X4 z5 L
- return s;
- EXPORT_SYMBOL(memset);
- #endif
- 5 J% ~' y U5 @7 y2 A
- #ifndef __HAVE_ARCH_MEMCPY
- * memcpy - Copy one area of memory to another
- * @dest: Where to copy to
- * @src: Where to copy from
- * You should not use this function to access IO space, use memcpy_toio()
- * or memcpy_fromio() instead.
- void * memcpy(void * dest,const void *src,size_t count)
- char *tmp = (char *) dest, *s = (char *) src;
- ! n Y2 }/ {. ^# a+ v
- while (count--)
- *tmp++ = *s++;
- ! h7 `/ M* c. P& r6 N- B
- return dest;
- EXPORT_SYMBOL(memcpy);
- #endif
. s: U* w- P1 R* A6 A- #ifndef __HAVE_ARCH_MEMMOVE
- * memmove - Copy one area of memory to another
- * Unlike memcpy(), memmove() copes with overlapping areas.
- void * memmove(void * dest,const void *src,size_t count)
- char *tmp, *s;
5 s- P/ t' G1 v- if (dest <= src) {
- tmp = (char *) dest;
- s = (char *) src;
- while (count--)
- *tmp++ = *s++;
- else {
- tmp = (char *) dest + count;
- s = (char *) src + count;
- while (count--)
- *--tmp = *--s;
9 C$ \$ }# i/ q- return dest;
- EXPORT_SYMBOL(memmove);
- #endif
- - n; T- D7 K# _' d" a
- #ifndef __HAVE_ARCH_MEMCMP
- * memcmp - Compare two areas of memory
- * @cs: One area of memory
- * @ct: Another area of memory
- #undef memcmp
- int memcmp(const void * cs,const void * ct,size_t count)
- const unsigned char *su1, *su2;
- int res = 0;
# @* @3 ]' y3 h1 _- for( su1 = cs, su2 = ct; 0 < count; ++su1, ++su2, count--)
- if ((res = *su1 - *su2) != 0)
- break;
- return res;
- EXPORT_SYMBOL(memcmp);
- #endif
- 9 J. t- T: p) W0 R( k
- #ifndef __HAVE_ARCH_MEMSCAN
- * memscan - Find a character in an area of memory.
- * @addr: The memory area
- * @c: The byte to search for
- * @size: The size of the area.
- * returns the address of the first occurrence of @c, or 1 byte past
- * the area if @c is not found
- void * memscan(void * addr, int c, size_t size)
- unsigned char * p = (unsigned char *) addr;
/ y9 W' x) Q' Y- while (size) {
- if (*p == c)
- return (void *) p;
- p++;
- size--;
- EXPORT_SYMBOL(memscan);
- #endif
- ) R# \- t7 E/ T' l0 T/ ? b
- #ifndef __HAVE_ARCH_STRSTR
- * strstr - Find the first substring in a %NUL terminated string
- * @s1: The string to be searched
- * @s2: The string to search for
- char * strstr(const char * s1,const char * s2)
- int l1, l2;
- " V: Y5 {3 p2 W% ?9 _' C3 g0 R# V3 \
- l2 = strlen(s2);
- if (!l2)
- return (char *) s1;
- l1 = strlen(s1);
- while (l1 >= l2) {
- l1--;
- if (!memcmp(s1,s2,l2))
- s1++;
- return NULL;
- EXPORT_SYMBOL(strstr);
- #endif
- " P% Q3 F! @4 G0 N
- #ifndef __HAVE_ARCH_MEMCHR
- * memchr - Find a character in an area of memory.
- * @s: The memory area
- * @n: The size of the area.
- * returns the address of the first occurrence of @c, or %NULL
- * if @c is not found
- void *memchr(const void *s, int c, size_t n)
- const unsigned char *p = s;
- while (n-- != 0) {
- if ((unsigned char)c == *p++) {
- return (void *)(p-1);
- return NULL;
- EXPORT_SYMBOL(memchr);
- #endif# [5 g% ?7 y: e. ` F' N6 f
& F' h+ d! g0 u( V- G3 l" W
" K5 d/ B7 L4 t9 B, w! m3 h
( m3 N- X) L9 O7 C9 h
0 m' @) l. K9 S6 N5 T: ?# u" A# |
" O8 m6 d$ _9 o, ~' o
" a) [4 ]4 r" I4 z3 N |
