2.20 RTC 测试【测试说明】:读取并设置时间,断电重启后检查时间是否正确) `" G, k e3 M
【接口标识】:无# U8 ?8 i, a3 t! i
【系统设备】:/sys/class/rtc/rtc0/ # |: m, a6 D, I S
测试操作# u% e1 r+ C; x/ e
1. 断电重启设备,查看当前系统时间和硬件时间: =====> 输入指令: date
1 U- q k3 K$ [9 H=====> 输出信息: Tue Sep 25 22:47:03 UTC 2018 , H* ~& ^" p" c
2. 查看当前RTC芯片时钟: =====> 输入指令: hwclock % m$ z3 B/ N& x3 n7 t
=====> 输出信息: Tue Sep 25 22:47:18 2018 0.000000 seconds 3. 设置系统时钟,并同步到RTC芯片 =====> 输入指令: date -s "2019-01-14 12:34:56" 7 B5 p/ D1 S, r0 z
=====> 输出信息: Mon Jan 14 12:34:56 UTC 2019
9 q, |0 e/ M/ `: j1 d! k
4. 将系统时钟写入硬件时钟 =====> 输入指令: hwclock -w 5 C. w' w9 P! Z" U* b
测试结果
6 p, \6 l( {* c+ D$ M1. 断电重启评估板,查看当前系统时钟和硬件时钟 =====> 输入指令: date
_7 u0 J! U; P2 i1 D=====> 输出信息: Mon Jan 14 12:36:22 UTC 2019
" S' R+ Y( d1 b" H
2. 查看当前RTC芯片时钟 =====> 输入指令: hwclock " H$ O4 s% S; G6 L6 j6 C
=====> 输出信息: Mon Jan 14 12:36:40 2019 0.000000 seconds 可以看到我们得到的时间与设置的时间基本相同。 3 }8 W- r! h7 e% _8 p
2.21 WakeAlARM 唤醒测试【测试说明】:设定 wakealarm 事件,之后使系统进入睡眠,等待 wakealarm 事件唤醒。
) \: |- ]. B8 u$ B5 z# W【接口标识】:无, k8 a/ X0 F6 K' A3 z' t
【系统设备】:如 /sys/class/rtc/rtc1/wakealarm 7 L6 A+ f% e p# o8 M
测试操作
: b+ A. M" O$ J# R, Y( {) G) u1. 设定 rtc1,使 10 秒后产生 wakealarm 事件 =====> 输入指令: echo +10 > /sys/class/rtc/rtc1/wakealarm 2. 使设备进入睡眠 =====> 输入指令: echo mem > /sys/power/state 3 _8 t( s2 w ? @7 c" r( P5 e
=====> 输出信息: PM: Syncing filesystems ... done. Freezing user space processes ... (elapsed 0.001 seconds) done. Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done. Suspending console(s) (use no_console_suspend to debug) , D% ]' u1 J) ?7 A' ^! Q: I
测试结果
7 p" S) l" y; d" F( C1. 可以看到开发板的除电源指示灯以外的 LED 都灭了。
3 C4 O. G k% X7 ]5 }; a; Q2. 10秒内 LED 的状态又恢复了,并且系统输出类似如下信息: PM: suspend of devices complete after 90.667 msecs PM: suspend devices took 0.090 seconds PM: late suspend of devices complete after 1.286 msecs PM: noirq suspend of devices complete after 1.272 msecs Disabling non-boot CPUs ... CPU1: shutdown CPU2: shutdown CPU3: shutdown Enabling non-boot CPUs ... CPU1 is up CPU2 is up CPU3 is up PM: noirq resume of devices complete after 1.140 msecs PM: early resume of devices complete after 1.114 msecs PM: resume of devices complete after 760.379 msecs PM: resume devices took 0.760 seconds Restarting tasks ... done. 6 y8 V7 g0 D6 a, |0 P
2.22 音频播放测试【测试说明】:通过播放音频文件验证评估板的音频播放功能。
0 M9 P# g' p! ]【接口标识】:EAR
- c' A5 q0 S" d; u7 L' a4 T) w【系统设备】:wm8960-audio* E/ X6 r9 q; J$ ~& b7 `
测试操作# W( n: q; p; Q; b% \* f, v
把耳机插入开发板的“EAR”口。
& b! x, M& q" n: d* I/ A" F执行测试命令: =====> 输入指令: aplay /unit_tests/audio8k16S.wav
, J/ q: ?3 O; a$ S% R, B( ^ J=====> 输出信息: Playing WAVE '/unit_tests/audio8k16S.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo 测试结果9 h: u( R! C( s
执行上面的测试命令后会听到音频设备输出的声音。
/ ^0 J8 [; M) q$ w( g7 `& F2.23 音频录音测试【测试说明】:通过录音并播放录音文件验证评估板的音频录音功能。7 p# D& r' ^5 I0 V( e' m
【接口标识】:MIC- \8 e" |9 ?+ j; Z7 i2 o9 `
【系统设备】:wm8960-audio
( n5 k9 \) }9 \. Z: p0 t; g测试操作! F& I; R( S7 ]) v9 l. C; _
1. 把带MIC的耳机插入开发板的“MIC”口。( f4 U& M$ h* [: x v4 x" W% |* H
2. 执行录音命令:
=====> 输入指令: arecord -d 5 -f S16_LE -t wav foobar.wav 6 b+ Z1 B' d$ f _8 I
=====> 输出信息: Recording WAVE 'foobar.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono 3. 播放录音 =====> 输入指令: aplay foobar.wav 1 q$ @1 W: ?. `. d: _, u/ Q
=====> 输出信息: Playing WAVE 'foobar.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono 测试结果
( }) i& h: l+ `1 k/ G执行上面的测试命令后会听到播放的录音。 " l q# u( `& E, I. j4 U6 c
3 第三部分 显示功能测试1 u; q) e$ v% |- _2 B+ l& ^
; M* ^+ _6 i8 v0 G$ ^, K' y: M' v
3.1 操作说明每项显示功能测试都需要重启系统进入到u-boot命令行,并在u-boot命令行下执行指令。 % @. u, }( t3 j" t
3.2 单屏显示LVDS1 显示/ t5 R( Z0 G2 c5 f/ ?; j
说明:默认为 LVDS1 显示,即上电后不干预启动的情况下,LVDS1 为显示设备。
$ N0 O: L5 K( p显式配置 LVDS1 为显示的方法: run load_scr; source; setenv display $disp_fb0_lvds1; saveenv; boot LVDS0 显示 run load_scr; source; setenv display $disp_fb0_lvds0; saveenv; boot HDMI 显示 run load_scr; source; setenv display $disp_fb0_hdmi; saveenv; boot LCD(RGB) 显示 run load_scr; source; setenv display $disp_fb0_lcd; saveenv; boot
" s3 K6 B8 l& G3.3 双LVDS屏显示LVDS1 + LVDS0 双屏同步显示 run load_scr; source; setenv display $disp_lvds_dul; saveenv; boot LVDS1 + LVDS0(fb4) 双屏异步显示 run load_scr; source; setenv display $disp_lvds_sep; saveenv; boot
" o& L0 j# c8 w6 S- s o) i3.4 双屏异步显示LVDS1 + HDMI 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lvds1 $disp_fb1_hdmi; saveenv; boot LVDS1 + LCD(RGB) 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lvds1 $disp_fb1_lcd; saveenv; boot LVDS0 + HDMI 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lvds0$disp_fb1_hdmi; saveenv; boot LVDS0 + LCD(RGB) 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lvds0 $disp_fb1_lcd; saveenv; boot HDMI + LVDS1 双屏异步显示 run load_scr; source; setenv display $disp_fb0_hdmi $disp_fb1_lvds1; saveenv; boot HDMI + LVDS0 双屏异步显示 run load_scr; source; setenv display $disp_fb0_hdmi $disp_fb1_lvds0; saveenv; boot LCD(RGB) + LVDS1 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lcd $disp_fb1_lvds1; saveenv; boot LCD(RGB) + LVDS0 双屏异步显示 run load_scr; source; setenv display $disp_fb0_lcd $disp_fb1_lvds0; saveenv; boot 1 o N( R/ r) @' b% k# S. H; V+ y1 b
! X- c% D! I! O. ^
; ^4 I& i+ `, _% d# L; D* K
) Z1 l) H5 J) W. F1 b6 B& l |
