查看: 574|回复: 1
MY-IMX6-EK200 Linux-4.1.15 测试手册 v2.0(5)
发表于 2019-8-7 11:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4  第四部分 扩展模块功能演示4.1  RTL8188 模块功能演示(WIFI Client)
【测试说明】:使用RTL8188作为无线网卡连接到WIFI AP。3 Z/ Y+ w: k# G# N0 Y5 J
【接口标识】:WIFI、WIFI_ANT
3 s" @/ w, [/ M【系统设备】:wlan02 e- t- c' B7 |; O1 ?  d9 v9 F  B
测试操作
3 l2 k8 o# Z0 V! i0 R; N5 E1. 确定“WIFI”标识处有贴上WIFI模块,否则无需进行测试。+ {$ A( o/ R' Q% ~! r
2. 把WIFI天线连接到“WIFI_ANT”标识的接口上。
3 b; r- \0 {, }$ ~  Y6 J) k3. 生成 SSID 的 WPA PSK 文件
" I4 a0 }) |0 P9 u* B
命令格式: wpa_passphrase <ssid> [passphrase]
=====> 输入指令:
wpa_passphrase MY-TEST-AP myzr2012 > /etc/wpa_supplicant.conf
pkill wpa_supplicant
4. 连接
=====> 输入指令:
wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
4 Q. ^, ]; a4 o' r" m8 {
=====> 输出信息:
Successfully initialized wpa_supplicant
RFkill: Cannot open RFKILL control device
==> rtl8188e_iol_efuse_patch
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
5. 获取 IP
=====> 输入指令:
udhcpc -i wlan0
' u5 a# [/ L& J" B5 O$ S
=====> 输出信息:
udhcpc (v1.23.1) started
Sending discover...
Sending select for 192.168.43.121...
Lease of 192.168.43.121 obtained, lease time 3600
/etc/udhcpc.d/50default: Adding DNS 192.168.43.1
6. 测试连接
=====> 输入指令:
ping -I wlan0 192.168.43.1 -c 2 -w 4
) O3 D  ^# L. |  |$ F
=====> 输出信息:
PING 192.168.43.1 (192.168.43.1) from 192.168.43.130 wlan0: 56(84) bytes of data.
64 bytes from 192.168.43.1: icmp_seq=1 ttl=64 time=5.66 ms
64 bytes from 192.168.43.1: icmp_seq=2 ttl=64 time=9.22 ms
7 {/ g+ G" f  E+ o! C5 k0 h7 h7 U
--- 192.168.43.1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 5.663/7.444/9.226/1.783 ms
测试结果
% f& t! C! c( }“0% packet loss”表示WIFI连接正常。
) d9 u5 ^* ~; x2 @+ W5 q
( |4 T5 F) p$ a, Q
* k3 o( e6 [% Z# s# r# D
4.2  RTL8188 模块功能演示(WIFI AP mode)/ w3 G& k4 M% \
【测试说明】:使用RTL8188作为WIFI AP,并把手机连接到此AP。
7 `9 {: U3 N" d5 Z【接口标识】:WIFI、WIFI_ANT6 O5 v+ J2 S$ ]9 {- P2 G
【系统设备】:wlan0. x9 R" Z6 I$ ~4 n1 t) r: c# K7 @
测试操作
6 z& {3 U8 \0 A* v( w1. 确定“WIFI”标识处有贴上WIFI模块,否则无需进行测试。
9 B" L8 S# T, x; r7 b2 t- _4 s( Z2. 把WIFI天线连接到“WIFI_ANT”标识的接口上。4 T, e! {3 G; B8 i, I9 J. P2 {9 m% X4 t
3. 为 wlan0 配置 IP:
=====> 输入指令:
ifconfig wlan0 192.168.99.1
" J: y8 |/ _; v) w
=====> 输出信息:
4. 为 wlan0 启用 DHCP 服务:
=====> 输入指令:
touch /var/lib/misc/udhcpd.leases
udhcpd -f /etc/my_udhcpd.conf &
4 V1 t2 P: W2 r8 Q1 x( N
=====> 输出信息:
[1] 469
udhcpd (v1.23.1) started
5. 为 wlan0 启用 Host-AP 功能
=====> 输入指令:
hostapd /etc/my_hostapd.conf -B
  X1 i5 G$ ~* P* G4 l  o. J) q
=====> 输出信息:
Configuration file: /etc/my_hostapd.conf
rfkill: Cannot open RFKILL control device
Using interface wlan0 with hwaddr e0:b9:4d:7f:e4:40 and ssid "MY_HOSTAP_V25"
RTL871X: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:AES
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
6. 客户端设备连接到 Host-AP
; p# X7 L6 l/ n2 q; J至此,开发板的 Host-AP 功能已启用,客户端设备可搜索“MY_HOSTAP_V25”,通过密码“myzr2012”连接到此AP。7 @4 I8 A" W5 P( |5 @
测试结果
9 V4 x9 z2 I% C  G# _/ n! X1. 设备连接成功时产生的信息
=====> 输出信息:
Sending OFFER of 192.168.12.20
Sending ACK to 192.168.12.20
2. 设备断开连接时产生的信息
=====> 输出信息:
RTL871X: OnDeAuth(wlan0) reason=3, ta=b4:0b:44:f5:64:2f
RTL871X: clear key for addr:b4:0b:44:f5:64:2f, camid:4
5 q" I& g( H5 g( D" e& n
4 M8 h6 a* D6 M4.3  EC20 模块测试
【测试说明】:4G连接成功后,开发板向外网发送ICMP报文来验证连接正常。
# c; U5 A# I5 `【接口标识】:MINI_PCIE  I5 C/ Z0 m- f9 Z6 T- c! R; g
【系统设备】:eth2
3 F4 c* c9 n3 D, b测试操作' Z4 U% K8 [# S4 R7 |
1. 开发板断电,接上4G模块,接上天线并插入SIM卡后启动评估板。; l0 Q! t! D* r/ ^  {: H/ f; @
2. 使用指令进行网络连接:
=====> 输入指令:
/my-demo/gcc-linaro-5.3-ARM/quectel-CM &
. L- }5 F/ x$ y/ C- j' M6 K
=====> 输出信息:
[1] 540
[12-18_03:17:06:719] WCDMA<E_QConnectManager_Linux&Android_V1.1.34
[12-18_03:17:06:720] /my-demo/gcc-linaro-5.3-arm/quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null)
[12-18_03:17:06:723] Find /sys/bus/usb/devices/1-1.2 idVendor=2c7c idProduct=0125
[12-18_03:17:06:723] Find /sys/bus/usb/devices/1-1.2:1.4/net/eth2
[12-18_03:17:06:723] Find usbnet_adapter = eth2
[12-18_03:17:06:723] Find /sys/bus/usb/devices/1-1.2:1.4/GobiQMI/qcqmi2
[12-18_03:17:06:724] Find qmichannel = /dev/qcqmi2
[12-18_03:17:06:794] Get clientWDS = 7
[12-18_03:17:06:826] Get clientDMS = 8
[12-18_03:17:06:858] Get clientNAS = 9
[12-18_03:17:06:890] Get clientUIM = 10
[12-18_03:17:06:922] Get clientWDA = 11
[12-18_03:17:06:954] requestBaseBandVersion EC20CEFAR02A10M4G
[12-18_03:17:07:050] requestGetSIMStatus SIMStatus: SIM_READY
[12-18_03:17:07:082] requestGetProfile[1] cmnet///0
[12-18_03:17:07:114] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[12-18_03:17:07:146] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[12-18_03:17:07:223] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE
[12-18_03:17:07:274] requestSetupDataCall WdsConnectionIPv4Handle: 0x8777e7a0
[12-18_03:17:07:370] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
[12-18_03:17:07:403] ifconfig eth2 up
[12-18_03:17:07:452] busybox udhcpc -f -n -q -t 5 -i eth2
[12-18_03:17:07:492] udhcpc (v1.23.1) started
[12-18_03:17:07:656] Sending discover...
[12-18_03:17:07:706] Sending select for 10.25.154.46...
[12-18_03:17:07:766] Lease of 10.25.154.46 obtained, lease time 7200
[12-18_03:17:07:888] /etc/udhcpc.d/50default: Adding DNS 211.136.17.107
[12-18_03:17:07:888] /etc/udhcpc.d/50default: Adding DNS 211.136.20.203
3. 测试连接
=====> 输入指令:
ping -I eth2 www.baidu.com -c 2 -w 4
8 q" v3 X4 e- O% ^4 [/ T, S- p5 E
=====> 输出信息:
PING www.baidu.com (14.215.177.38): 56 data bytes
64 bytes from 14.215.177.38: seq=0 ttl=49 time=15.753 ms
64 bytes from 14.215.177.38: seq=1 ttl=49 time=11.835 ms
+ `: P& D" Q0 |9 y. r1 ~
--- www.baidu.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 11.835/13.794/15.753 ms
测试结果
; z0 {( I2 o1 p/ b0 g- f$ l6 n“0% packet loss”表示WIFI连接正常。
$ q0 m  F& U9 l; b6 @8 t8 ~- U$ H: m
! R/ V' u: i" T- v; t' a% z8 N$ g2 E" `9 O+ x
发表于 2019-8-7 18:54 | 只看该作者
学习一下,谢谢楼主分享
GMT+8, 2025-11-24 20:48 , Processed in 0.156250 second(s), 23 queries , Gzip On.
