查看: 1193|回复: 4
[Cadence Sigrity] DDR3仿真报错求解
发表于 2019-7-31 08:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
报错信息4 n0 `5 t! J+ n$ Y7 ?0 L' f+ l
Loading case file into SPDSIM ...9 B  n$ A& C2 ]
Simulation Start ...! @0 \! z4 K' E1 s) {8 c: d
   Extracting trace/pad parameters ...1 l$ q' |! X5 g) o+ z, t' s# d$ l
Simulation Error:
4 S* |  v1 w( y/ C9 b0 pError 4030: Invalid data when reading line:
) K8 V4 l, p% Y5 k5 W".padstackDef OB70_150X40_120D 5.080000e-001mm OblongVia"
" T& D: A3 g* Z1 [. HError 4030: Invalid data when reading line:4 r) y9 X9 \" r: R2 K
".PadStackDef OB70_150X40_120D 5.080000e-001mm OblongVia = (2.032mm"9 d+ E6 l$ Z* p6 u. E9 |/ o; Z
Error 4030: Invalid data when reading line:; M' A  G! s) o, n. v( Z
".PadStackDef OB70_150X40_120D0 5.080000e-001mm OblongVia"
( |0 y% x9 \5 q; [4 `, cError 4030: Invalid data when reading line:. q6 C" c; O3 [
".PadStackDef OB70_150X40_120D0 5.080000e-001mm OblongVia = (2.032mm": u" y/ z( U( X' m% U. s- F& M# |# g
Error 4030: Invalid data when reading line:9 b2 s5 i5 |. l! t9 p: A+ g
".PadStackDef OB70_170X40_140D 5.080000e-001mm OblongVia"5 @% |6 y1 u# Y
Error 4030: Invalid data when reading line:- Y4 n2 c8 t0 x8 J- n8 r
".PadStackDef OB70_170X40_140D 5.080000e-001mm OblongVia = (2.54mm"  p0 R+ D2 C" L8 @7 W4 W& Z9 V, x
. B6 b) k2 i0 f+ V9 T' u! l".PadStackDef OB70_170X40_140D0 5.080000e-001mm OblongVia"
* t+ c+ w+ e7 k# Q8 DError 4030: Invalid data when reading line:
5 r8 _9 R- s( T".PadStackDef OB70_170X40_140D0 5.080000e-001mm OblongVia = (2.54mm"
6 e. a( {( x  s6 ^& o! ?Error 2190: Error message is found from SPDSIM, please check it.
! l6 Q8 S% m3 Y5 n5 JError 2190: Error message is found from SPDSIM, please check it.( A: C- N3 W6 @& v
推荐
 楼主| 发表于 2019-8-1 22:49 | 只看该作者
xieda2005 发表于 2019-7-31 12:002 y4 R3 o' A+ t, [" c9 z
没有仿真过程和设置页面,只有这个,别人就只能猜,这不是解决问题的方法,提供一个你用的那个工具模块, ...
1 @3 a+ [* k7 ~7 j: B
谢谢两位,问题解决了,打了cadencesigrity2016的补丁,SPEED2000 DDR仿真正常。' E! Z. ^. }& a
+ i( \+ G/ U' Y8 `7 ]& o% r1 C! ^
) f1 e0 y, o( s9 \/ c- b, P
发表于 2019-7-31 09:19 | 只看该作者
有仿真过程吗
    无聊
    2025-5-22 15:56
  • 签到天数: 256 天
    [LV.8]以坛为家I
    发表于 2019-7-31 12:00 | 只看该作者
    没有仿真过程和设置页面,只有这个,别人就只能猜,这不是解决问题的方法,提供一个你用的那个工具模块,什么的。你这个好像就是层叠那设置没有设置对。
    谢谢两位,问题解决了,打了cadencesigrity2016的补丁,SPEED2000 DDR仿真正常。 [attachimg]197600[/attachimg]  详情 回复 发表于 2019-8-1 22:49
    发表于 2019-8-4 10:12 | 只看该作者
    我是来学习的
    GMT+8, 2025-7-30 21:53 , Processed in 0.140625 second(s), 31 queries , Gzip On.
