查看: 385|回复: 1
求教定时器通道单独关闭???
发表于 2019-7-18 17:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4 L- a  k7 e& Y# |7 d4 ]! ^" f. I) D) N; E# G3 ]. q
void TIM4_Configuration(void)3 t1 h) Z/ @2 J8 U) Z
{, M+ U( P1 o' P, x8 w( T
        u32        temp;
7 F1 ^2 c; F9 O  N        TIM_TimeBaseInitTypeDef        TIM_TimeBaseInitStruct;
; b: {6 Y+ K5 E: l. M% q4 F        TIM_OCInitTypeDef TIM_OCInitStruct;4 e: M8 g' _* l  h& _% G  I
0 l0 n5 v' o# z  Q& d3 m& T
        temp = SystEMCoreClock / 1000000;
1 p4 v' `9 s1 j        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);                        . u2 O( B- ?: S6 _4 H' p
        TIM_DeInit(TIM4);
! p6 i+ ]8 u/ c9 i        if(SystemCoreClock > 36000000)
- j3 p7 R; Z- L3 j& F        {7 x4 Y) q; ~; a7 N, _1 H. y' b
                TIM_TimeBaseInitStruct.TIM_Prescaler = 1;# X; W+ A0 R0 d4 j
                TIM_TimeBaseInitStruct.TIM_Period = PWM_Period * temp / 2;
0 Q, x- Q  @/ J                TIM_OCInitStruct.TIM_Pulse = PWM_Recharge * temp / 2;0 \5 I/ y, ~9 v. v$ g2 X6 K
        }% Q: a+ t* M, N* a- A2 w/ L% S+ B* _
        else
' V0 J! E1 {1 _; o( ~3 q        {" R% ^3 m4 x% Q! `' W# I
                TIM_TimeBaseInitStruct.TIM_Prescaler = 0;
9 `; k' N& p) R* a0 v0 B, ~# F                TIM_TimeBaseInitStruct.TIM_Period = PWM_Period * temp;# [) t7 E2 w; k/ o  A
                TIM_OCInitStruct.TIM_Pulse = PWM_Recharge * temp;
( Y& Z% d. X! C6 J; \- v7 }3 I7 X) i        }
2 g: r' R' e' s- b: F( B        TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;' X8 V! n7 |1 y& p
        TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
/ T6 G  E" R( Z- D3 N5 r  D        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseInitStruct);
$ O5 `# w6 ]7 k9 K0 n. K" r3 Y7 \8 z; }0 u6 I5 V. C7 `  F
        TIM_OCInitStruct.TIM_OCMode        = TIM_OCMode_PWM1;) j4 p2 x$ [, i! g: U9 ?& I
        TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Disable;- C5 z" w# Y* b! S- J- S" l4 w# C
        TIM_OCInitStruct.TIM_OCPolarity        = TIM_OCPolarity_High;
, b$ J6 A! \- N7 z/ F* c        TIM_OC1Init(TIM4, &TIM_OCInitStruct);
) v0 B6 e% J' ~% g        TIM_OC2Init(TIM4, &TIM_OCInitStruct);
* e, V: B$ i; b! p* |        TIM_OC3Init(TIM4, &TIM_OCInitStruct);+ O: ^, A3 R5 S+ e; ~
        TIM_OC4Init(TIM4, &TIM_OCInitStruct);
7 C. t- x8 T- g1 y  ~# u# o7 U9 e8 c6 ?* e- ?% j1 p! {# X
        TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);5 p  Z1 o$ N0 j# u1 L
        TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);; z' I7 j' w5 h7 l5 @  v
        TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);( b. {( T/ ?5 g
        TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);) U0 m% Q" U1 E$ \( n$ R# M* x
        TIM_CCxCmd(TIM4, TIM_Channel_1, TIM_CCx_Enable);
+ a3 `9 T( e# R; H( B; ]3 E/ t        TIM_CCxCmd(TIM4, TIM_Channel_2, TIM_CCx_Enable);9 |% j' P' t/ T  f. H
        TIM_CCxCmd(TIM4, TIM_Channel_3, TIM_CCx_Enable);$ w- |% i" i8 s( U5 X" C' l  m
        TIM_CCxCmd(TIM4, TIM_Channel_4, TIM_CCx_Enable);
$ R+ O8 i9 z0 s) Q; G' a2 }        TIM_ARRPreloadConfig(TIM4, ENABLE);
- _* v& H; C- ?$ y2 z& [2 g) I, I  `0 R3 Z1 h. f5 g
        TIM_CleaRFlag(TIM4, TIM_FLAG_Update);) c- D$ P+ {9 I+ n0 N
        TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);; |! q! @. ?5 c) K7 t7 F
        TIM_Cmd(TIM4, ENABLE);
* a9 C4 C) k8 R9 D+ K        , S" M* d7 M3 i7 k7 u, y
        TIM_CCxCmd(TIM4, TIM_Channel_2, TIM_CCx_Disable); //放在这里面起作用& P; \( g; B. ^" _
8 b: H) D% g1 J( ?4 S- f' n
* w! ^! x0 J! g. e4 n! }
0 _! b: V3 F$ w* \        。
7 A, e9 T% ~! F" Y* F- l        。# I2 c* U0 L  u- p- S! W
        。* S+ g1 [9 \5 e5 ]. r0 N
0 x8 E9 f; g$ U! Q$ t4 w' p3 {        TIM4_Configuration();; [( y2 p# P% x  `3 T: q
( V$ N" C( D- g3 S  K//期望随时单独失能某一通道,但这样不起作用:        " \" q4 ]5 L; y7 I9 ?+ q! U
0 W6 |2 V) I1 T. V1 Q7 x/ A; A; G5 L5 j7 D- u
7 I9 y' ?7 o3 j& E' c- `
5 s( M- a9 t1 j4 n7 J
发表于 2019-7-18 18:42 | 只看该作者
建议仔细阅读数据手册,每个定时器都有一个CCER位,看看它的作用。
GMT+8, 2025-11-24 23:17 , Processed in 0.156250 second(s), 23 queries , Gzip On.
