OpenGLShader::compile(Fragment): 0:2(24): error: attribute' variables may not be declared in the fragment shader6 O& e1 o1 S1 f
0:2(24): error: illegal type for a varying variable. \! X* ~4 K- n
0:2(50): error:attribute' variables may not be declared in the fragment shader3 P& y; n" k) m/ G
0:2(50): error: illegal type for a varying variable% n% J- U+ z5 k8 w
0:2(107): error: `gl_Position' undeclared& g4 O3 O% E6 S3 C) n6 ?5 n
0:2(117): error: type mismatch2 e$ F% H w" ^$ h7 g2 a3 N
0:2(141): error: type mismatch *** Problematic Fragment shader source code ***' x: c! o. H. a1 U& ]
#define lowp
# Q- M0 ?3 d0 V/ ]#define mediump: F1 A5 g; e( d4 O) W% q. x
#define highp& A+ G" j* N5 v$ |
#line 1
# e5 m% X c4 }; j1 q. mattribute vec4 vertexIn; attribute vec2 textureIn; varying vec2 textureOut; void main(void) { gl_Position = vertexIn; textureOut = textureIn; }
QOpenGLShader::compile(Vertex): 0:2(334): error: `gl_FragColor' undeclared
4 Y1 h- q9 E5 c" e# I0:2(334): error: value of type vec4 cannot be assigned to variable of type error *** Problematic Vertex shader source code ***
9 A4 m) e, G% i* K- [#define lowp5 r2 M2 E3 f$ ?+ y* [$ D# N
#define mediump% W) {: M6 `; j7 g5 r
#define highp
: J! F5 \4 L$ s+ H#line 1
& I# T% J; H7 [. Y( |varying vec2 textureOut; uniform sampler2D tex_y; uniform sampler2D tex_uv; void main(void) { vec3 yuv; vec3 rgb; yuv.x = texture2D(tex_y, textureOut).r; yuv.y = texture2D(tex_uv, textureOut).r - 0.5; yuv.z = texture2D(tex_uv, textureOut).a - 0.5; rgb = mat3( 1, 1, 1, 0, -0.39465, 2.03211, 1.13983, -0.58060, 0) * yuv; gl_FragColor = vec4(rgb, 1); }
QOpenGLShader::link: "error: linking with uncompiled shadererror: linking with uncompiled shader"
* J/ `8 }9 c" {/ `; aQOpenGLShader::link: "error: linking with uncompiled shadererror: linking with uncompiled shader") \, D% N4 ^* e) b5 a8 M# e3 ^
QOpenGLShaderProgram::uniformLocation( tex_y ): shader program is not linked/ r6 u* c7 Y# [' v
QOpenGLShaderProgram::uniformLocation( tex_uv ): shader program is not linked 4 J) a! A1 \& X7 A
