ug470 7Series_Config.pdf第25页Table 2-4: Configuration Pin Definitions有说明,必须要有下降沿。 + i B9 |( W4 I& m) q- |" e) mConfiguration reset initiated upon falling edge, and configuration (i.e. programming) sequence begins upon the following rising edge.9 l0 `( S: \+ Q- H+ j
) I* Q9 o" y0 Q H" z
Note: Holding PROGRAM_B Low from power-on does not keep the FPGA configuration in reset. Instead, use INIT_B to delay the power-on configuration sequence.
