--为什么下列程序在xie0的check_error不变为一,而在du0xiex立马为一???* E( i' o( D8 U9 c6 [
LIBRAry ieee ;
T4 c7 H; p4 I7 ~3 i+ Nuse ieee.std_logic_1164.all;
4 `! L/ m5 @# d" I- E, W# Ouse ieee.std_logic_arith.all;0 j# M" K- F" E3 r) f
use ieee.std_logic_unsigned.all;. H! C% W) Q. Z8 c4 k0 D
-- Uncomment the following library declaration if using
+ f, d2 e: d% `1 ~" p, a. O1 z; m-- arithmetic functions with Signed or Unsigned values
& {2 [) W% l# N' I# |% a--use IEEE.NUMERIC_STD.ALL;
6 R- a2 H, G4 N( a6 T-- Uncomment the following library declaration if instantiating
: @$ E) \" f7 `# f2 K% |-- any Xilinx primitives in this code.+ c# r% B; G9 ~3 `! ]/ \: W' i, r
--library UNISIM;8 b9 f) K# t/ W1 m' ~2 c
--use UNISIM.VComponents.all;8 U4 V8 z) `5 V+ H- R& w, n1 Z
entity checkram1 is
* y, M* o. `( |) Vport (5 ~, F" v" `$ o& G
, h) W7 X$ C- t. jram_ce : out std_logic ; --ram pian xuan,di you xiao. U3 R* ~" _. t$ H" D+ o; d4 @
ram_we : out std_logic; --ram xie shi neng,di you xiao0 I) ?9 S6 c$ H1 c
ram_oe: out std_logic; --ram hu chu shi neng,di you xiao
5 j0 E: q0 T u6 J h+ f" tram_db : inout std_logic_vector(15 downto 0); --ram shu ju duan9 u) D7 z: [' x) D% F
+ l# i/ b" X0 x. M" F% o4 H
ram_addr : out std_logic_vector (18 downto 0); --ram di zhi
5 Q" H p0 z' ?: T7 Kram_ub: out std_logic;ram_lb: out std_logic;! o* S: X% m5 {/ H
checkram_ce : in std_logic ;
" g! w5 v+ D9 V# t. L clk_50m : in std_logic ;
. I9 v* o c/ g T! g) r check_error : out std_logic :='1' ;
0 [/ q t) U& c check_over: out std_logic :='1'' W7 K% z% t& b9 C5 J6 P
/ h! G7 N+ t0 C( z" M- q: ?end checkram1;
) Q9 A5 _, y+ v+ E9 ~) a' Earchitecture Behavioral of checkram1 is
: V, b' M. q+ V- ?+ M' Z/ |signal ram_db_in : std_logic_vector(15 downto 0);
c' r; q2 ~' W' d; v; Psignal ram_db_out : std_logic_vector(15 downto 0);/ F! b# o- V) A# p
signal ram_db_io : std_logic ; --ram_db输入输出控制,1输出,0输入! R1 h9 f0 E+ i ^. W; k
signal addr :std_logic_vector (18 downto 0) :="0000000000000000000"; --地址变量--/ j6 j$ P. I7 d9 g
type states is (xie0,du0xiex,dux,dengdai); --状态类型 ( ?1 g2 M' X9 h A; Y
signal state :states := dengdai; --当前状态
8 I* M3 N6 w$ f5 ~7 gsignal timeofxie0 : std_logic_vector (7 downto 0) :="00000000"; --xie0计时标记
- D# U, ~* p8 q# @5 y5 B* G, fsignal timeofdu0xiex : std_logic_vector (7 downto 0) :="00000000";--du0xiex计时标记
8 ` J: T3 q( ~; T; E5 [signal timeofdux : std_logic_vector (7 downto 0) :="00000000";--dux计时标记) Z7 }- p9 u a' h9 ]$ _& m% T O. z: R
begin% n* A ?- h" u- V! \3 ]2 x
-- process (clk_50m,ram_db_io,ram_db_out)
: ^% [* I% @# V5 { x-- begin. |8 a- l! a" j$ { W: t/ O
-- if (ram_db_io = '1' ) then
( ]/ E: O( E& u# g8 O& x# Z-- ram_db <= ram_db_out;, n; m9 x: m6 O+ f6 f; i: H
-- else ram_db <= (others=>'Z');+ s. Q2 b H' S6 B7 a
-- end if;% s0 W% T* }) {# @ D/ d
-- end process ;
9 R9 a' y( o! t2 E" s6 S& G# N--ram_db <= ram_db_out when ram_db_io ='1' else "ZZZZZZZZZZZZZZZZ";0 a4 I+ l9 q2 t7 N0 A/ j" t* z
process (clk_50m)7 d7 A, X$ f/ w4 ]0 f1 b
begin
: l7 y3 c; h0 Y8 ?. ~9 @9 `if rising_edge(clk_50m) then
% Q) Q- h0 ~8 |case state is F C; O) W& ?( @0 | a& X
when dengdai =>
/ n) Y" ~0 H }ram_addr <=(others =>'Z'); ram_db <=(others =>'Z');
4 u3 @. _- x- X9 W+ l3 c6 sram_ce <='1';ram_oe <='1';ram_we <='1';
3 B- {/ L1 ?. P( r, sif checkram_ce = '0' then addr <= "0000000000000000000";state <= dengdai;5 H$ s2 y+ M# k1 \' [
else addr <= "0000000000000000000"; state <= xie0;check_error <= '1';check_over <= '1';end if;
1 R! S# }: h- O ~% Uwhen xie0 =>
# F Y- `% I, ecase timeofxie0 is
, J% O6 G0 N* S) i* }- pwhen "00000000"=> ram_db<="0000000000000001";ram_addr <=addr;
8 k( q* B/ Y. |ram_db_io <= '1';
5 q9 A7 I' X3 p; ~( c w! j3 K* Eram_ce<='0';ram_we<='1';ram_oe<='1';state<=xie0;$ c, `, e, g5 { ~% K
when "00000001"=> ram_ce<='0';ram_we<='0';ram_oe<='1';state<=xie0; . O& Q- { N% }: O5 `# Q
when "00000011"=> ram_ce<='0';ram_we<='1';ram_oe<='1';state<=xie0;) i3 J4 ~9 O$ W% X
when "00001000"=> ram_addr <= addr;ram_ce<='0';ram_we<='1';ram_oe<='1';ram_db_io <= '0';state<=xie0; 0 u% h+ T# }) S( p! Q3 j; g
when "00001001"=> ram_ce<='0';ram_we<='1';ram_oe<='0';state<=xie0;
: u9 ^6 q" [$ u1 u, O when "00001011"=> ram_db_in <= ram_db; state<=xie0;9 U0 ~1 z# \: ^% v" E2 Q
when "00001100"=> ram_ce<='0';ram_we<='1';ram_oe<='1'; state<=xie0;
% x# _- r7 i, f when "01000000"=> if ram_db_in /= "0000000000000001" then
r- \9 j( }0 V# b check_error <= '0';end if;
! U& @: h6 F# {6 m
8 C. N5 b7 T0 C* r1 C! T when "01010000"=> if addr="1111111111111111111" then
% r- }7 J5 w J/ Q( a# e addr<="0000000000000000000";state <= du0xiex;4 }& f) w: [$ X
else addr<=addr+1;end if;
: ]8 s; u j$ P! i3 ~# X1 u when others => state <= xie0;
- R- S/ e7 @$ I* C3 P$ [( |; h f end case;
7 O7 @. D" a+ `: K6 E- l9 B when du0xiex =>
' U% [( y z% B case timeofdu0xiex is
# b+ h& p! x- V& R; @ when "00000000"=> ram_addr <= addr;ram_ce<='0';ram_we<='1';ram_oe<='1';ram_db_io <= '0';state<=du0xiex;
3 U& ] n! X7 u& S y! U8 x- N$ d when "00000001"=> ram_ce<='0';ram_we<='1';ram_oe<='0';state<=du0xiex;
( Q4 G9 T0 A8 j when "00000011"=> ram_db_in <= ram_db; state<=du0xiex;8 u; o( J* p: G( c2 }, x$ N. u
when "00000100"=> ram_ce<='0';ram_we<='1';ram_oe<='1'; state<=du0xiex;% `' `/ ]$ q; I7 c% e/ v0 v
when "01010000"=> if ram_db_in /= "0000000000000000" then
3 T+ P! q* V* S( W8 t$ B# ~ check_error <= '0';end if;
+ ^' ^7 L8 s) n; j1 Z when "01010001"=> ram_db<=addr(15 downto 0);ram_addr <=addr;
2 N6 n) |; o, |. y4 X* ~ ram_db_io <= '1';: o% ?% N; H; h( N# W f
ram_ce<='0';ram_we<='1';ram_oe<='1';state<=du0xiex;2 V1 \4 [5 n" s
when "01010010"=> ram_ce<='0';ram_we<='0';ram_oe<='1';state<=du0xiex;$ d( R5 h1 h- J+ i) m- Q! `
when "01010100"=> ram_ce<='0';ram_we<='1';ram_oe<='1';state<=du0xiex;
& h9 R4 V/ R3 d2 D4 b3 n when "10100001"=> if addr="1111111111111111111" then& R! T7 a* g# W- e
addr<="1111111111111111111";state <= dux;# s- f% \) E, P& ]+ k5 l
else addr<=addr+1;end if;$ I% D- X k$ M! B! C! w' J
when others => state <= du0xiex;
4 [" u0 g+ J3 d$ I2 ]) }8 B end case;
' m8 b! U, i, q& ~$ @ when dux =>
0 v1 C4 a# \, }1 x0 ]' ^ case timeofdux is c# \+ V$ a3 J8 G, I
when "00000000"=> ram_addr <= addr;ram_ce<='0';ram_we<='1';ram_oe<='1';ram_db_io <= '0';state<=dux;; {8 d# H$ W$ O8 _- W
when "00000001"=> ram_ce<='0';ram_we<='1';ram_oe<='0';state<=dux;7 t& I: m# `1 A* t) s0 r: E
when "00000011"=> ram_db_in <= ram_db; state<=dux;/ H( _0 X2 p6 x/ N. ]" g
when "00000100"=> ram_ce<='0';ram_we<='1';ram_oe<='1'; state<=dux;
9 P: Q' O3 O8 D# U when "01010000"=> if ram_db_in /= addr then4 ^, k9 y4 Q z$ V; B3 [( \( ]# t
check_error <= '0';end if;; U! w5 J" e6 i+ g
when "01010001"=> if addr="0000000000000000000" then
; d( ]+ ~; y: q* X: {. F* I% z0 U7 K/ { addr<="0000000000000000000";state <= dengdai;check_over <= '0';
3 `% N5 G4 }, C) b" ` else addr<=addr-1;end if;. B; b& a6 M; P$ i! M4 E
when others => state <= dux;
+ k5 e" x2 g: i& j# m end case;
9 ^3 }; B" H- N% S& o1 uend case;, z0 V( t9 m( @% B* r; z
end if;9 ^1 g1 G6 }- s X+ N. E
4 S, J2 F! a Y5 Nend process;
+ f3 s5 q8 `# {& x3 X4 Wxie0jishi:process (clk_50m)
) W0 h4 R* u- Vbegin
0 o# I; Z$ t) r& c: \if rising_edge(clk_50m) then 7 E; R! }1 W% X8 l
if state = xie0 then9 y2 b' Q7 x/ f: c0 A4 b' j
if timeofxie0 = "01010000" then) U; W2 g* G7 G% V
- M- J, {# J" Utimeofxie0 <="00000000";
, N/ f( p* i1 Q Velse timeofxie0 <= timeofxie0 + 1;
# R5 ]6 S. C5 v' A3 pend if;
% ^, ]: q- w( V, i( xelse timeofxie0<= "00000000";& Z$ f% P7 r: S. N+ w5 }: u
end if;) d, ^- I/ q, j3 O" o
end if;
@) v: @' K3 aend process xie0jishi;5 T. L6 K) V* k0 L4 r! K) X
du0xiexjishi:process (clk_50m)2 }4 ?0 X" k" E1 b3 N- C
begin& X" G+ h, k8 Q, V# X; h
8 ]0 Z% A# u. h& J1 X2 b& Sif state = du0xiex then
( I7 @. K+ N8 ]0 s* B" Aif timeofdu0xiex = "10100001" then) A0 z5 R9 [* s. [" t- C
% D- d- e% m( _ y
timeofdu0xiex <="00000000";
8 U, }) O, W, ?; }% p9 Zelse timeofdu0xiex <= timeofdu0xiex + 1;
# r# z% G2 r; Nend if;
0 B! k* K! s& v* k$ O; [3 Xelse timeofdu0xiex<= "00000000";
5 P+ P4 }& O9 I" z. b- xend if; P$ O9 }( `9 V) L7 F7 z
end if;
2 X$ P1 T- `/ M3 b7 ?end process du0xiexjishi;
1 I: G- Y$ N- R% P W( fduxjishi:process (clk_50m)6 F7 l: {% V6 d& t, n
begin
w/ p+ w/ c: F" Y- t9 lif rising_edge(clk_50m) then # d( n2 R4 {) o
if state = dux then
1 z- j8 q& W' Z+ F0 y' x" ]; Bif timeofdux = "01010001" then
7 w/ \+ u- D2 m+ ?1 \5 C; Q7 f
# n3 I# }$ ?0 l* A# Ztimeofdux <="00000000";& D8 U+ o A+ d V- g
else timeofdux <= timeofdux + 1;
" f$ X; o. N( `- {0 F% W1 Gend if;
. |5 m% p$ f7 m5 K+ [. O" ~! S) Aelse timeofdux<= "00000000";
5 e- T4 W$ E8 X& _end if;$ O5 E6 S, B1 E" u3 u. [! |
end if;. Y8 Y* }3 C! d" r; b
end process duxjishi;
, e3 C' v6 W7 E5 Y. J- ~end Behavioral;
2 J+ ^% E: q7 `' I6 W5 M6 M7 S9 o! V
