查看: 254|回复: 1
FPGA ------- Buffer之BUFGP
发表于 2019-6-17 13:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BUFGP
; O9 c8 M5 C2 P5 U) @/ D
$ J/ ?/ L7 [; r, \% \, O1 w6 \
/ }* S0 R8 g6 c& h' P: ]6 e, n ! o$ V1 w+ n' W& j4 u7 s* A( D4 c
+ g9 w0 Y$ {4 a7 R6 E
) U, `) w  L" S$ I$ e% [
用于驱动时钟或延长线的主要全局缓冲器5 N- o: c5 x  V7 h/ I
  [& u0 Y  q/ W; x: n- Y
8 q+ b% U" o5 b: W- @% }3 [This design element is a primary global buffer that is used to distribute high fan-out clock or control signals throughout in FPGA devices. It is equivalent to an IBUFG driving a BUFG.
( t6 N+ e' X5 j  O) k4 uThis design element provides direct access to Configurable Logic Block (CLB) and Input Output Block (IOB) clock pins and limited access to other CLB inputs. The input to a BUFGP comes only from a dedicated IOB.
4 e4 ?0 a& J$ Q! ~: S! kBecause of its structure, this element can always access a clock pin directly. However, it can access only one of the F3, G1, C3, or C1 pins, depending on the corner in which the BUFGP is placed. When the required pin cannot be accessed directly from the vertical line, PAR feeds the signal through another CLB and uses general purpose routing to access the load pin.
: {7 _: v- Q# k9 x, G/ c9 U* x' i
* a1 \/ {  C, z7 v: L" ~
游客,如果您要查看本帖隐藏内容请回复
" B) z; R$ y' E" G' x1 S
! i) Z% V+ \+ @  G9 Y( z2 Z- ~8 T) r, h' i) L7 H7 S* V
发表于 2019-6-17 17:00 | 只看该作者
这是英文版的?
GMT+8, 2025-8-4 18:48 , Processed in 0.140625 second(s), 27 queries , Gzip On.
