查看: 267|回复: 1
FPGA ------ FIR 滤波器之 Interpolated Filter 的系数数据(Filter Coefficient D...
发表于 2019-6-17 11:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Interpolated Filter ) ^5 E+ w6 c. N5 e5 e
& j- x  B8 y$ |! H' z; q
. S5 r: W8 W9 k$ u% O/ T) L
A previous section explained that an IFIR filter is similar to a conventional FIR, but with the unit delay operator replaced by k-1 units of delay. k is referred to as the zero-packing factor. One way to realize this substitution is by the insertion of k-1 zeros between the coefficient values of a prototype filter. When specifying an IFIR architecture, the full set of prototype coefficients is supplied in the coefficient file, without the zeros implied by the zero-packing factor. The zero-packing factor is defined through the filter user inteRFace. For example, consider the filter coefficient data in the .coe file shown in Figure 3-48.+ @, ^" o8 |  p; s2 Z+ t& k
2 n+ z! N% s8 Y& u% x2 J- K0 T
) h  ]  Q) }. _  U) L
: }0 u) J( u( P3 F, G: J
7 {8 @$ t4 E/ a) N9 l
游客,如果您要查看本帖隐藏内容请回复
" v8 q+ L3 _; l' @# u
  f  P' c0 K* j, E
# N% p" S6 S8 a+ i5 `6 L: n
9 B4 I1 Q/ T: }6 h  r
0 [, ~3 d% `/ U; s: V( U. ^+ \3 H
4 i4 ]& ]- U' a
! e) P8 c' z% ^( F* n8 X
发表于 2019-6-17 17:13 | 只看该作者
这是英文版的吗
GMT+8, 2025-8-5 00:33 , Processed in 0.140625 second(s), 27 queries , Gzip On.
