查看: 300|回复: 1
FPGA ------- FIR 滤波器之固定分数率重采样滤波器
发表于 2019-6-13 10:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
FIR滤波器,它以固定的分数比率P/Q实现数据流的重采样,其中P和Q均为整数,最高可达64,可用于Systolic Multiply-Accumulate(SMAC)架构。- m4 I( u! Y  x! s4 J, |
* ?4 `( k$ o2 T' Q9 M$ A/ x
In Figure 3-34, the operation of an interpolation filter with interpolation rate P=5 is contrasted conceptually with the operation of a fixed fractional rate filter with rate P/Q=5/3.
# d6 X9 ^# Z! A6 S& I" r/ l6 a) v/ k4 W$ N: w: f" t+ b! x
游客,如果您要查看本帖隐藏内容请回复
) |* W2 w3 N/ v9 D2 C- D* [
! N0 L$ u4 e" Y
- k- P. m& v3 c( k
GMT+8, 2025-8-4 19:07 , Processed in 0.125000 second(s), 27 queries , Gzip On.
