查看: 404|回复: 1
STM32 与FPGA通信过程NWE波形不对???
    2019-11-19 15:34
    发表于 2019-6-11 14:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    stm32配置:( e+ j) I3 K/ d! o+ A
    void fsmc_init(void)) @7 T: D8 i9 X& C5 |
    {9 W8 ~% y9 @# c7 E2 p5 a2 {7 Z+ L- E
            GPIO_InitTypeDef GPIO_InitStructure;' L2 ]( @  n% ?% ?: D) `  M) m
            FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
    ) z5 S( [6 p7 k: J4 z5 J/ U! B' G  FSMC_NORSRAMTimingInitTypeDef  readWriteTiming; 4 I* U! s! E; W5 ~- V3 J( {
            FSMC_NORSRAMTimingInitTypeDef  writeTiming;( c4 L# j4 @( \
    " B4 A$ a8 y* G5 a) t  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);        //ê1ÄüFSMCê±Öó
    , Z4 y. X6 e8 s( I6 b* J( \' P; c        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE,ENABLE);//ê1ÄüPORTB,D,EòÔ¼°AFIO¸′óÃ1|Äüê±Öó
    + s7 R( c* H* Z* \! x1 L
    - @6 F" e% f7 W4 ~- @          /* SRAM Address lines configuration   PD11 12 13 ¶Ôó| A16 17 18
    - e0 S/ b3 z7 t3 @! e      PE2 3 4 5 6 ?? A23 19 20 21 22  ×ü128¸ùμØÖ·×üÏß */
    9 o' E2 M  K& \, {  C! o  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 |GPIO_Pin_12 | GPIO_Pin_13;
    + w. U" H/ n1 H# W/ B4 \, R  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                   6 i! x. Q2 W+ X  I( k) [
            GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    ! ~  a6 X% V9 M" Z) h& W  GPIO_Init(GPIOD, &GPIO_InitStructure);2 d  t# C' Q! Z( J, z2 y7 G9 d
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
    + P/ v, t4 O0 [1 M' l) J" m  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                   8 a8 E8 {) v& _* b9 D: K- B, Z
            GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;0 Q: `  M7 n! G2 m; E
      GPIO_Init(GPIOE, &GPIO_InitStructure);
    & b; V$ @) Z0 j- V7 G& X# n5 E0 ^2 A6 A# r* {) q: G
      //FSMC_D0~FSMC_D7¸′óÃíÆíìêä3ö
    ( M8 b+ [" L5 A9 x        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_14|GPIO_Pin_15;
    5 a& M' v2 v" M: A1 I8 s        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    2 q1 ~3 Q: M+ r. c4 V3 {        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;# x8 |9 d" H  o: z0 P: T0 J
    % U; o3 _5 V/ V  O) [5 Q           " D) T! E* P' u
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;                                 # c# R! r/ w- t1 p* \
            GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  1 o+ ?+ L7 y2 _, ?7 _  B8 {/ A8 Q2 N
            GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;" w0 a! @: ~* n
            GPIO_Init(GPIOE, &GPIO_InitStructure);        " [. {# }( v. q, _/ e: r6 R2 }, `
    9 v# e+ H, K2 J( h        //FSMC_NOE  FSMC_NWE¸′óÃíÆíìêä3ö6 R) B3 Y1 P# c- U8 o- T/ f7 ~0 g
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5;                                : Y, ^) u; h- P: j6 g
    ' `6 g% m  r% p        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;% U/ X5 ~/ t0 E' g: G6 h- s8 D2 o
            GPIO_Init(GPIOD, &GPIO_InitStructure); ; h6 I) O9 b4 S) l3 m
    - i: y! b, ~% j8 }. s1 F( C  //FSMC_NCE  ¸′óÃíÆíìêä3ö
    ' c! f& E  t& y& T5 m! P) n7 a$ S        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;                                % q% @, [3 [* n/ b1 ?
    , b) S& h) Q: Q& H% @' W. W, T        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;) b6 R/ ^: t5 g$ Y
            GPIO_Init(GPIOD, &GPIO_InitStructure); + U1 h! ?+ H: z. H1 R2 U
    ! V$ X# q/ I8 F( [        readWriteTiming.FSMC_AddressSetupTime = 0x01;         //μØÖ·½¨á¢ê±¼ä£¨ADDSET£©Îa2¸öHCLK 1/36M=27ns
    + V! m$ W& N+ Y  readWriteTiming.FSMC_AddressHoldTime = 0x00;         //μØÖ·±£3Ö걼䣨ADDHLD£©Ä£ê½AÎ′óÃμ½
    0 H& v& C5 N' x( G' ]# q; `2 y  readWriteTiming.FSMC_DataSetupTime = 0x0f;                 // êy¾Y±£′æê±¼äÎa16¸öHCLK,òòÎaòo¾§Çy¶ˉICμĶáêy¾YμÄê±oò£¬Ëù¶è2»Äü쫿죬óèÆä¶Ô1289Õa¸öIC¡£5 H9 A1 ?% ~. V, R( h
      readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;: {$ `3 d% F8 ?( }' c7 u
      readWriteTiming.FSMC_CLKDivision = 0x00;
    9 y' u) Y6 B7 g/ c  readWriteTiming.FSMC_DataLatency = 0x00;  e) m  `! X5 Z6 n6 Y
      readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //Ä£ê½A
    ) V- H. n2 c* G; D
    & p& P1 i( Y4 i( O" k  E
      U9 i) Y  H. d5 B/ D  l0 U        writeTiming.FSMC_AddressSetupTime = 0x00;         //μØÖ·½¨á¢ê±¼ä£¨ADDSET£©Îa1¸öHCLK  + p: R# E0 ?! S  o- d( L
      writeTiming.FSMC_AddressHoldTime = 0x00;         //μØÖ·±£3Ö걼䣨A
    4 }! l0 x7 I! ]7 @% R; f  writeTiming.FSMC_DataSetupTime = 0x02;                 ////êy¾Y±£′æê±¼äÎa4¸öHCLK        * m6 I5 k% m  A7 n
      writeTiming.FSMC_BusTurnAroundDuration = 0x00;& t$ s/ B+ U' [+ x, M% v) H  m
      writeTiming.FSMC_CLKDivision = 0x00;- m+ h' x: C' n
      writeTiming.FSMC_DataLatency = 0x00;; Q/ L2 u; b9 \8 I+ R
      writeTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //Ä£ê½A
    / `9 e; l# h& `6 l5 w) \" F+ n' ^3 H$ p* T
    ; W& W$ C: ~5 w* [' h  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//  ÕaàïÎòÃÇê1óÃNE4 £¬ò2¾í¶Ôó|BTCR[6],[7]¡£
    * m2 P( P! z* k+ m+ c  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 2»¸′óÃêy¾YμØÖ·# L' y0 F& B4 `* O+ ]+ G  h
      FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM   ! S4 {. `9 [6 X+ i: Q' P: |
      FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;//′æ′¢Æ÷êy¾Y¿í¶èÎa8bit
    4 V( F- q. G1 w) ?( \  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
    ; U: H4 @( L& N& K4 d7 p  F5 R  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    ! }+ H0 `* x, U0 k) r4 w        FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable; , A( L; L3 A5 q& u1 F$ r) }
      FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    $ i0 j7 ^2 u0 b: g. B+ s/ g  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    0 G/ j# S9 G9 I% t. ^$ s0 p  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;        //  ′æ′¢Æ÷D′ê1Äü& i7 l' V( ]8 k7 g! m; z$ E
      FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    1 E* P% o7 L! P) ^9 L  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // ¶áD′ê1óÃ2»í¬μÄê±Dò* o! U8 Z. x: a
      FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    ; N- q3 o9 n- U; j! r5 C  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //¶áD′ê±Dò" D3 X+ v7 c  n1 `3 r$ c- F
      FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;  //D′ê±Dò9 r4 @3 z3 [# ?$ [
    / e- g9 R: C" w9 U  ]# n$ z  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //3õê¼»ˉFSMCÅäÖÃ
    # @) l4 R7 W$ K: t
    , q/ W; L2 k6 B* A        FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  // ê1ÄüBANK1
    ) h; y- _, S, ~* }5 x/ C4 B8 S  delay_ms(100);
    7 d! y& l  r5 B- u/ N}
    8 X8 M) _+ O! E4 P
    6 @( w( z  |: P: S. \$ U. E
    " O/ k& c5 W9 [' N  j( g. D
    / V2 j% Z% |; @1 q  z
    & C& S3 d  t3 V
    4 T( E1 A) P$ G" I! l写时序发现NEW波形不正确:其中黄色片选信号,蓝色位NWE写使能。2 K$ S/ y/ W7 G) d7 @5 q7 I
    ; C4 G! `0 h) j, U  ?9 s. z
    8 e; n! [  g5 I; A) x * D+ Z9 d9 i0 r9 |' m
    ' J" L0 c5 n2 y& z: {
    " `/ D$ C* J$ T
    ) V% [9 |5 ~4 i. L0 \/ l0 @* Z9 y6 P
    - v% Q1 T" J7 ?; r7 k( Y- R6 x6 H: o5 ^3 ?. ^, G  P
    8 M+ z/ r/ U% v  G
    发表于 2019-6-11 16:53 | 只看该作者
    这代码也太多了吧
    GMT+8, 2025-8-4 12:55 , Processed in 0.140625 second(s), 27 queries , Gzip On.
