查看: 2550|回复: 0
pads2005导入网表错误
发表于 2009-5-13 01:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
打开一个示例的pcb文件,然后导出 .asc文件,然后再导入此 文件,就会出现一堆错误 如下:* {+ z, C; u1 u4 A; l) }
7 n  }& P9 v- J+ P- N8 h4 l& q' @; c% y! t  u/ X
Reading file --  F:\pads Projects\Samples\test.asc$ n0 H) Y- v' B" v+ C4 x$ P2 O% _3 U
Bad Lines item type name <BOARD>
  ]4 `* }4 _* r: _; r1 K, tD6970            BOARD    -625   875    1
. A" s  X' o' w*Bad *LINES* ascii data line format; J! M5 N7 t( e5 @1 o4 W4 A9 `
CLOSED 11  10  0
# ~- c. k( d+ x7 H/ I: M4 $ ?/ |' _+ W  F3 `4 t
- `, p8 a, o) K8 A/ @! M0      0
% i; q" M- Z7 e& v$ }- O2
7 |; {# d3 c, O*Bad *LINES* ascii data line format
8 G& u' ]* f5 S8 l) O$ L* s* \350    0
4 b2 t* _$ e8 X; i2 % b# M& z; h# ?' W
*Bad *LINES* ascii data line format6 O9 R/ `/ [3 G8 F1 y; A' L. u
350    -1050 7 S. P4 h% X  H0 A& l
2 , o' y0 d! q# X
*Bad *LINES* ascii data line format' F4 q# H- q' t5 P! w
2425   -1050 " Q- `- G( }1 w
2 ! G2 _' G3 }  k- g+ E
+ f$ N8 b- j# i) f8 \- Z2425   1600  " M- s# T9 S1 g/ j) b
2 / R5 M6 X8 F% S1 V4 n$ g
*Bad *LINES* ascii data line format8 W7 {; ~9 ~; [& x+ I6 D7 E
2275   1600
* c# g# K" _1 A. F- a2 5 t* s+ a0 U# B' W% T
*Bad *LINES* ascii data line format, y9 {) A! u% ?8 P' f, D. j' b! N
2275   1725
6 [3 C6 w3 r/ N2 n2 n1 f( ~5 F1 i. ?  }9 s
8 b: c: b) ~- O
*Bad *PARTDECAL* ascii data line format' S* }, x: ^( p8 \- Y
-50    250
- V% E6 G+ X) ]' H4 E*Bad *PARTDECAL* ascii data line format5 f( f6 M( D# }- N( d* j
-50    175
4 b8 a/ M" u( P- l0 `) Q*Bad *PARTDECAL* ascii data line format8 `! E4 R/ k+ K3 l) S" M# S
0      175     T2 F& {6 S! ?3 l# u
*Bad *PARTDECAL* ascii data line format0 d- V( y# b, W" R0 C! E2 A
0      125   % q& c# W7 U1 I; O7 Z- F# V% m
*Bad *PARTDECAL* ascii data line format; c* H. Q3 M$ r' w: V; X
-50    125   . j+ k& t- O3 o4 E
2 v& M# S) K' q-50    50    2 P5 Z: i8 t! z
*Bad lines piece data line format VALUE         220         175   0.000  1         100          10 N   LEFT   DOWN
% o. L+ Y9 D: U6 Y  Z& p2 IREGULAR <PADS STROKE FONT>) S3 p) A$ H% ~9 F; U
( s7 s, ]' {( s- x9 OREF.DES.
GMT+8, 2025-11-26 22:28 , Processed in 0.140625 second(s), 24 queries , Gzip On.
