TA的每日心情 | 开心 2021-8-19 15:42 |
签到天数: 21 天 [LV.4]偶尔看看III
orcad的网表导入到EXP2005 sp1过程,结果转网表提示失败,在file->file viewer里提示如下: T. Z' R( S; }0 ?: ]- o- C7 k
3 n8 x1 G9 E. s, @$ [4 j" l6 R! U n+ r+ d* N
Number of Part Numbers: 25/ [. t* W1 Y3 k; C: Z* L6 H
Part Numb: BNC-4 -> Vend Part: BNC-4
5 T$ }6 Y* U: U6 Q) h* d! E4 M Part Numb: CE/8MM -> Vend Part: CE/8MM , h1 @7 x7 o+ T' E8 O: E/ X2 ^+ [2 U
Part Numb: C0603 -> Vend Part: C0603 ) Z* N i) {" ?' p' j8 N6 H+ d; F
Part Numb: C0805 -> Vend Part: C0805 * ]9 Z. k- D% ^% F" a$ \. t. V
Part Numb: C1206 -> Vend Part: C1206 # {, l0 F6 n N9 @
Part Numb: DIODE2 -> Vend Part: DIODE2
. H4 L- F5 W) u! X' R Part Numb: FPBGA-233_17X17 -> Vend Part: FPBGA-233_17X17
+ F( S! x0 X; J/ E Part Numb: HC49U -> Vend Part: HC49U 4 Q8 F7 P' I8 P
Part Numb: HEADER_8X2 -> Vend Part: HEADER_8X2
( n) m. @. H. f$ [8 w Part Numb: HEADER4 -> Vend Part: HEADER4
6 N8 s5 n( p( _, g* w& v3 m8 m Part Numb: HOLD/3.3 -> Vend Part: HOLD/3.3 8 D, I* e, B8 y/ E7 o
Part Numb: L-12X12X7_SMD -> Vend Part: L-12X12X7_SMD 8 l3 Q' f3 R8 o) q
Part Numb: L0805 -> Vend Part: L0805 # {+ G/ q" l( t( Z
Part Numb: MASK -> Vend Part: MASK $ C( d7 V/ [% T+ } b
Part Numb: PCI_XPRESS_X1 -> Vend Part: PCI_XPRESS_X1 1 z( x- B1 R- M* w7 a6 T) P# d
Part Numb: R0603 -> Vend Part: R0603
5 r8 t- H# _) K! k Part Numb: SOT23M2 -> Vend Part: SOT23M2
: C( T1 @4 _+ e1 O5 M Part Numb: SOT223 -> Vend Part: SOT223
/ X$ R" J. ~, W( h+ ~ Part Numb: SO8NB -> Vend Part: SO8NB
" {; s: Y$ ~0 [+ \( Y! q5 c; H Part Numb: TEST_60X35-H -> Vend Part: TEST_60X35-H . E& @: W4 e" g1 W- a; \% }
Part Numb: TP/SMD/D1.0 -> Vend Part: TP/SMD/D1.0
% U, H: W- n! r Part Numb: TQFP-64_9X9-P0.4 -> Vend Part: TQFP-64_9X9-P0.4
9 g8 Q% S3 O. J$ o Part Numb: 8P4R-A-SMD -> Vend Part: 8P4R-A-SMD & e8 A6 B) R7 t1 C2 E6 L
Part Numb: 1206N -> Vend Part: 1206N
$ f8 S v6 z9 m8 ? Part Numb: 7343 -> Vend Part: 7343
% N$ W; v! U% R* s J3 C& {; } Number of Part Names: 0
2 e" k- Y, h7 t Number of Part Labels: 0( i$ A( X- F# v8 ^9 |4 h, i6 B
) o$ J; ]0 R* Y- r INTERNAL S/W ERROR: A part pin has no alphanumeric pin number
. X# s9 T6 r" b$ t on part number TEST_60X35-H.: U, P$ t2 |) v) p. h
If a Parts DataBase other than the local one is corrected,
$ h# T/ T1 B* V; J& F please be sure to run Packager in the overwrite mode or
2 h/ i" T8 |0 g Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be+ U; z9 ?1 ^1 V8 s# h- m6 g( z4 V
sure not to use these modes or the corrections will be lost.
) {2 k7 T" v$ k) d, A) ?, u! m% ? INTERNAL S/W ERROR: A part pin has no alphanumeric pin number
* N7 A3 @" _: v' S8 K2 ] 1 k) X W$ v, i# X
on part number L-12X12X7_SMD.
% q, P- y& r% d- v If a Parts DataBase other than the local one is corrected,
3 j& T" j8 t4 |0 A, C please be sure to run Packager in the overwrite mode or
: x7 S W$ b+ W- K; a' _' U- Q' P Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be
8 t& r! E9 j5 |* {* p sure not to use these modes or the corrections will be lost.8 M3 m- N/ ]8 K g( p9 g% D
! ~7 _$ U% E9 d8 W
INTERNAL S/W ERROR: A part pin has no alphanumeric pin number/ y" Q$ n, r2 [0 o
on part number TEST_60X35-H.8 ^ m: }; c. T5 j& U( O: }
If a Parts DataBase other than the local one is corrected,7 w( C8 K/ @# L
' x3 D/ M: x9 r. R Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be
! j& {1 ]: b" X( `/ I, D! ]+ E0 m sure not to use these modes or the corrections will be lost.
% D& Y' B: d, [ N: F INTERNAL S/W ERROR: A part pin has no alphanumeric pin number: r# |& V6 c" T3 P
5 L- g. S% `7 U# W$ H
on part number L-12X12X7_SMD.3 O3 G8 M% S3 m1 `+ r3 f/ G
5 m% C) i7 U* _ please be sure to run Packager in the overwrite mode or, o G3 ^! k" b; I
Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be( s' L. p6 k% ^* E; s1 i2 N8 e
0 D: f3 r( J1 @/ w/ l" m5 Y3 q) } 116 nets were found containing 516 pins' k' b. b3 T) z' m
145 components were found
9 y7 O, C* f! x5 u$ n$ D! Q- d) w& I& N/ e& L- ^! [
" q- h/ c4 P i- x! }1 [ on part number L-12X12X7_SMD.
9 s; e8 N( z8 z3 p. } If a Parts DataBase other than the local one is corrected,6 u! J- \2 z x5 c4 ~
$ G* y/ r# p6 N; g8 r% G: { Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be4 Q7 i$ O2 v. b3 {
sure not to use these modes or the corrections will be lost.8 y$ Z. A- x$ J4 D
1 u4 C n. l2 s
INTERNAL S/W ERROR: A part pin has no alphanumeric pin number5 D! F' H' f% ?- n* q
on part number TEST_60X35-H.. S- p( _7 w; r0 y
If a Parts DataBase other than the local one is corrected,; z0 B! r7 y% ?, y7 `) I( ?! B" w6 \6 w
: G6 {8 a( l! s. j Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be
; {- c' M' m, t# ]7 E) q% e: E, ? sure not to use these modes or the corrections will be lost.
7 d/ c6 r! i& } The PDB supply data has 2 errors., i# }9 w8 w% ]# H
Please update the Parts DataBase to provide this information
: o2 b/ M6 Q$ c and then run DataBase Load. If a Parts DataBase other than5 z, B( f% {7 j9 j
the local one is corrected, please be sure to run DataBase1 n, v* f! T0 u- j( a8 m
Load in the 'Replace Local Parts' mode. Otherwise, be sure
9 p* ?( ^ [2 }& W7 j4 x. D not to use this mode or the corrections will be lost.
3 [% l f# j/ H: x x DataBase Load is being terminated with 2 errors and 0 warnings.
( u k' y# t4 x" r4 S Logic Data has NOT been Compiled.! g9 X, b7 _4 w6 L0 K1 l5 o
_7 G, |% j* ]/ r( F8 `
L+ m. N* z: F求助:是我的PDB有问题还是那里出了问题??先谢谢各位老大! |
