查看: 2918|回复: 7
分享:Cadence OrCAD and Allegro 17.20.020 Hotfix
发表于 2017-6-13 10:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fixed CCRs: SPB 17.2 HF020. e. w- ?" w0 `1 V1 H" S2 y) _
05-21-2017+ `9 p; E) P; J2 m, m
========================================================================================================================================================: H' p$ C. M& x- l
CCRID Product ProductLevel2 Title
" p$ K& A# q' X- D3 I========================================================================================================================================================
9 X+ O5 Q+ c2 g! Q; `1737443 ADW DBEDITOR Revising the schematic model classification for one category causes all parts in the library to be revised8 w" |, V; H; W/ ~& C  l4 }5 r
1734123 allegro_EDITOR 3D_CANVAS Interactive 3D canvas crashes Allegro PCB Designer in 17.2 S016
- X2 q* E' |5 j1 E' ?1 {& }1742084 ALLEGRO_EDITOR DATABASE Running DB Doctor on DRA files with custom pad shapes resets some of the custom padstack shapes in release 17.2/ m$ x1 N' \: B. c* i8 r9 \* w
1739397 ALLEGRO_EDITOR INTERACTIV In release 17.2, running the skill function axlImportXmlDBRecords causes Allegro PCB Editor to crash
) ^5 V, ]7 p: ^9 u' ]( F) H1724588 ALLEGRO_EDITOR MANUFACT Backdrill Route keepout suppressing existing Route Keepouts
% E% Q. A. ~/ d+ H! k7 O1740036 ALLEGRO_EDITOR MANUFACT Generating the cross-section chart does not provide information about the overall board thickness& r+ C! a* @0 Y. y4 w+ j7 j& C0 V
1743726 ALLEGRO_EDITOR OTHER IDF file export: In release 17.2, only one design outline is exported as against multiple board outlines in release 16.6
9 R  G' `# ~- u* j. H0 X% _' W1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor
3 Z' g1 b: e$ C1729350 ALLEGRO_EDITOR REPORTS Net loop report is not working.
, E; v6 B! h& }9 l, s1 f1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations
' O4 B. u7 r! w8 i5 E2 {, J1739870 ALLEGRO_EDITOR SHAPE The artwork is different from the PCB in release 17.2 Hotfix 17
: e  B% I- Z, n1 t5 e4 \/ ~' M1698869 ALLEGRO_EDITOR SKILL PCB Editor crashes when trying to open another .brd file after running SRM on first .brd file8 P! e4 [* N2 w
1739307 ALLEGRO_EDITOR SKILL axlCNSDFAExport fails after first run; M5 a+ X) L' I3 h
1743385 ALLEGRO_EDITOR SKILL SKILL APIs for STEP model mapping are not available in release 17.2 Hotfix 17 or 18
/ p4 m/ [( I& o1685826 ALLEGRO_EDITOR UI_GENERAL Reports when opened from Status Form disappear behind PCB Editor canvas when clicking on canvas
" M' G# ?9 ?6 u) l  O% L1687797 ALLEGRO_EDITOR UI_GENERAL Cannot open two HTML windows, one after the other, while using SKILL function
1 K0 T5 U- w4 y3 R4 r/ {3 X1696229 ALLEGRO_EDITOR UI_GENERAL Setting the 'allegro_html' environment variable in User Preferences Editor overwrites existing popup text windows
, a) |$ N- x- V" ]% W1708636 ALLEGRO_EDITOR UI_GENERAL In SPB 17.2 release, keyboard focus automatically shifts to the newly opened dialog box$ r0 k3 w# I+ X* W
1711367 ALLEGRO_EDITOR UI_GENERAL Launching two report windows using SKILL is not working in 17.2( c1 A' T9 W& M# e" u' t
1742856 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor crashes if Project Manager is open for a design in release 17.2 Hotfix 18: ~- r- Q" {4 Q; M
1729519 APD SHAPE shape degassing does not generate all voids to cover entire shape7 `0 f4 [) \  L& i8 P" U
1711375 concept_HDL CORE Copy-paste of schematic between two instances of DE-HDL is not working as expected# a: F/ B$ R0 r1 B
1737230 CONCEPT_HDL CORE On the Linux platform, copying of schematic objects does not work between designs of releases 16.6 and 17.2' t6 U1 O7 E, e+ f7 I
1741375 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol1 k6 T0 X: m& r; v
1743992 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol" W) J5 G/ Y7 m& p
1736093 CONSTRAINT_MGR CONCEPT_HDL Incorrect topology extraction and mapping errors related to MUX parts* U" G4 [/ f, U- N, \( M$ ]! w
1743518 CONSTRAINT_MGR CONCEPT_HDL Lag observed in expanding and collapsing the net classes in Constraint Manager
( u( j; H) c- V1730159 FSP ALLEGRO_INTEG FSP diff engine does not read PF Thevenin connections in FSP$ Y% m4 S, C$ t
1664070 ORBITIO ALLEGRO_SIP_I Display pads of SMD components on correct layer
8 N  Y8 p, c- H  Q9 I" m, v" ~1709319 ORBITIO USABILITY OrbitIO issues an error about Device template while importing brd with Bundles
  F4 p8 ~' I4 Q& h3 I2 d1741150 Pspice ENVIRONMENT Need a way to prevent the 'pspSimSetting.js' file from being overwritten by a hotfix installation in 17.2+ U4 {$ A) W# P. A
1735354 PSPICE SIMULATOR Access to custom nom.lib is not working as expected5 K) o5 l+ H( \! @- j
1716523 SIP_LAYOUT COLOR Tool crashes on using the PageUp, PageDown, and Tab keys in the Color dialog box.
5 |( E9 l8 x8 m; f' I  B* ~$ r
下载:http://www.dongeasy.com/hardware-design/pcb-design-guidelines/13192.html
- v$ B. S, b2 w# d  k" o
发表于 2017-6-13 15:08 | 只看该作者
已经出021了  希望LZ分享!
发表于 2017-6-14 11:08 | 只看该作者
多谢分享,我也分享一个,Allegro软件速成100讲* y, y' d" m4 e& ^" {5 i/ u5 s
链接:http://pan.baidu.com/s/1jI1GSEa 密码:wq5t
发表于 2017-6-14 21:08 | 只看该作者
多谢分享,更新很快啊
发表于 2017-6-18 18:28 | 只看该作者
求教,这个软件怎么安装?4 D' L7 \2 i1 u( J8 y1 b
GMT+8, 2025-11-28 19:41 , Processed in 0.171875 second(s), 26 queries , Gzip On.
