查看: 666|回复: 1
Not all pins could be reached on the net. Check connections
发表于 2017-5-25 10:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Not analyzed: $ u1 u# T0 L# x8 U* d9 K
6 e' ]0 a) \, h: N* v; R3 HClass    Document    Source    Message    Time    Date    No.
% [% u0 n: @8 D, N' Q& O% r$ _8 n+ a! w0 Q
[Warning]    PCB1-20170524.PcbDoc    Signal Integrity    CLK1: Not all pins could be reached on the net.  Check connections.    10:04:09 AM    5/25/2017    335
" u5 a1 a' P% ?$ t. M
# `% A% a- F+ u- m* t  q
2 d0 Y$ h' \% b$ k5 `& C
 楼主| 发表于 2017-5-25 10:09 | 只看该作者
这几个红色区域是什么意思? Not analyzed??
GMT+8, 2025-8-24 00:47 , Processed in 0.125000 second(s), 27 queries , Gzip On.
