TA的每日心情 | 开心 2025-10-31 15:44 |
签到天数: 17 天 [LV.4]偶尔看看III
CCRID PRODUCT PRODUCTLEVEL2 TITLE
6 ]: T g$ K. F) x4 b; j===================================================================================================================================
1 j) F g. U4 i8 j2 A1597787 CONCEPT_HDL MARKERS Save As in Marker dialog causes DE-HDL to crash5 c. {( Q- u" Z* ?* S2 O
1623832 ADW COMPONENT_BROWSE Incorrect part placement on schematic in Design Entry HDL 16.6-S0735 j4 ~( _! {) J/ ~' I# {
1659030 RF_PCB LIBRARY Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols9 ^$ D: a; Q# ]! f1 Q
1662799 ADW SRM Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager
5 u7 t& t$ F& O4 f7 s- Y" I* r1667056 ASI_PI GUI Power Feasibility Editor does not list capacitors connected to selected nets/parts
0 f* e/ T( J. `; J+ p1669707 CONCEPT_HDL CORE Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property, w! P6 g% P! H8 F# g
1671728 CONCEPT_HDL CORE Option requested to reload preferred_projects.txt without re-opening DE-HDL
3 U8 @# L8 _8 p& x
2 g9 p) L3 d+ N$ w5 U& \DATE: 11-25-2016 HOTFIX VERSION: 0822 M) d5 [9 F& D) O4 I- y
$ I" m( D: W) @CCRID PRODUCT PRODUCTLEVEL2 TITLE- a) q$ ], ?: j" B% Y% I
5 V' s9 ~5 G' T( C5 l& ^. |1651925 ALLEGRO_EDITOR ARTWORK Creating artwork in GerberRS274X causes AMMACRO total count issues in 38-139057-B04_L20.art
. y$ T7 l1 {% A) L1656357 CONCEPT_HDL CORE Copy-Paste of signal names across pages overlaps it on the wire segment
' N l2 E9 @" i1657346 CONCEPT_HDL PDF User is difficult to recognize as dash-dot-dot line in PDF.- E" A; H7 e8 R$ N# k2 H; J/ q
1658874 CONCEPT_HDL CORE About the "Insert(n) Pages" command with CONFIRM_WRITE directive1 A% O. _" [6 T& v8 S- [9 ~
1663422 ALLEGRO_EDITOR INTERFACES Shape loses group membership after importing through sub-drawing
b* V; I* g' [, j' R! L" W8 Z1663641 CONCEPT_HDL COPY_PROJECT copy project creates 2 designs if there are dashes in the design name$ W. n: \! u {$ H3 J' O- C1 D
1664797 SIG_INTEGRITY GUI Unnecessary coupled interconnect models were generated during View Waveform.4 c. C, `6 u& e9 D2 {
1666723 ECW TDO-SHAREPOINT TDO login is not working with Site Minder because of incorrect html coming from Site Minder |
