查看: 367|回复: 3
Digital Signal Processing World Class Designs 2009
发表于 2016-11-17 14:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Edited By - b# C# R% @( t, N+ Q
Kenton Williston, Site Editor, DSP DesignLine7 O' W! Y. X' f% ^, p9 j
: p  `% y0 R; u7 Q: E' ]; |. I
% D; z6 N/ }: ^% l
Paperback: 456 pages
6 I( g8 _  _5 ?Publisher: Newnes (March 12, 2009)
  F" y) D4 i; ~4 a6 ]! W/ b) \Language: English
, p5 x# @' A- @9 e! d2 p/ UISBN-10: 1856176231- t2 s: e7 G- u0 s+ a3 f" V( M0 W
ISBN-13: 978-1856176231
) e# D  }* i" C. \! M; Y5 h* QProduct Dimensions: 9.1 x 7.4 x 1.3 inches
9 O- t  t8 T- J7 M. s4 M
$ c6 m+ g  N. p1 l. G4 d! c! f3 N) F4 J' }
Included in series " R, j" g: M! ]+ w$ w
World Class Designs, 5 Q2 [/ V. x* n9 s
4 R) o7 c# e' _9 }; ODescription - T3 z1 C- Y. {
All the design and development inspiration and direction an digital engineer needs in one blockbuster book! Kenton Williston, author, columnist, and editor of DSP DesignLine has selected the very best digital signal processing design material from the Newnes portfolio and has compiled it into this volume. The result is a book covering the gamut of DSP design?from design fundamentals to optimized multimedia techniques?with a strong pragmatic emphasis. In addition to specific design techniques and practices, this book also discusses various approaches to solving DSP design problems and how to successfully apply theory to actual design tasks. The material has been selected for its timelessness as well as for its relevance to contemporary embedded design issues. CONTENTS: Chapter 1 ADCs, DACs, and Sampling Theory Chapter 2 Digital Filters Chapter 3 Frequency Domain Processing Chapter 4 Audio Coding Chapter 5 Video Processing Chapter 6 Modulation Chapter 7 DSP Hardware Options Chapter 8 DSP Processors and Fixed-Point Arithmetic Chapter 9 Code Optimization and Resource Partitioning Chapter 10 Testing and Debugging DSP Systems
6 q, R8 T4 \6 Z; D& @9 D" U- ~3 z$ k5 a3 \: b! L) F
Audience 4 ^* Y! M! U# b* b
Digital Signal Processing Engineers and Programmers; Application Engineers; Hardware Engineers; Software Engineers
. X, ?7 g0 h. h2 R" V; t2 z& l: P( h, C0 `7 S# K' f! b
Contents
( v" I$ }4 B8 j8 uChapter 1 ADCs, DACs, and Sampling Theory 1.1 Coding and Quantizing 1.2 Sampling Theory 1.3 Data Converter AC Errors 1.4 General Data Converter Specifications 1.5 Defining the Specifications Chapter 2 Digital Filters 2.1 CHAPTER PREVIEW 2.2 ANALOGUE SIGNAL PROCESSING 2.3 AN ALTERNATIVE APPROACH 2.4 THE COMPLETE DSP SYSTEM 2.5 RECAP 2.6 DIGITAL DATA PROCESSING 2.7 THE RUNNING AVERAGE FILTER 2.8 REPRESENTATION OF PROCESSING SYSTEMS 2.9 FEEDBACK (OR RECURSIVE) FILTERS 2.10 CHAPTER SUMMARY References Chapter 3 Frequency Domain Processing 3.1 Discrete Fourier Transform (DFT) and Fast Fourier Transform (FFT) 3.2 Short-Time Fourier Transform (STFT) 3.3 Discrete Wavelet Transform (DWT) 3.4 Signal Processing Toolset 3.5 Bibliography Lab 3: FFT, STFT, and DWT Chapter 4 Audio Coding 4.1 Overview 4.2 Introduction 4.3 MPEG Audio Coding 4.4 MPEG Advanced Audio Coding 4.5 Dolby AC3 (Dolby Digital) 4.6 Other Standards 4.7 Summary Chapter 5 Video Processing 5.1 Rounding Considerations 5.2 SDTV-HDTV YCbCr Transforms 5.3 4:4:4 to 4:2:2 YCbCr Conversion 5.4 Display Enhancement 5.5 Video Mixing and Graphics Overlay 5.6 Luma and Chroma Keying 5.7 Video Scaling 5.8 Scan Rate Conversion 5.9 Noninterlaced-to-Interlaced Conversion 5.10 Interlaced-to-Noninterlaced Conversion 5.11 DCT-Based Compression 5.12 Fixed Pixel Display Considerations 5.13 Application Example References Chapter 6 Modulation 6.1 Radio carrier 6.2 Amplitude modulation 6.3 Modulation index 6.4 Frequency modulation 6.5 Modulation index and deviation ratio 6.6 Sidebands 6.7 Bandwidth 6.8 Improvement in signal-to-noise ratio 6.9 Frequency shift keying 6.10 Phase modulation 6.11 Phase shift keying 6.12 Minimum shift keying 6.13 Quadrature amplitude modulation 6.14 Spread spectrum techniques 6.15 Frequency hopping 6.16 Direct sequence spread spectrum 6.17 Orthogonal frequency division multiplex 6.18 Bandwidth and data capacity Summary References Chapter 7 DSP Hardware Options 7.1 DSP THEORY FOR HARDWARE DESIGNERS 7.2 THEORY, APPLICATIONS, AND IMPLEMENTATIONS 7.3 DSP APPLICATIONS 7.4 DSP IMPLEMENTATIONS 7.5 REVIEW OF PROCESSORS AND SYSTEMS REFERENCES Chapter 8 DSP Processors and Fixed-Point Arithmetic 8.1 Digital Signal Processor Architecture 8.2        Digital Signal Processor Hardware Units 8.3        Digital Signal Processors and Manufacturers 8.4        Fixed-Point and Floating-Point Formats 8.5 Finite Impulse Response and Infinite Impulse Response Filter Implementations in Fixed-Point Systems 8.6 Digital Signal Processing Programming Examples 8.7 Summary References Chapter 9 Code Optimization and Resource Partitioning 9.1 Introduction 9.2 Event Generation and Handling 9.3 Programming Methodology 9.4 Architectural Features for Efficient Programming 9.5 Compiler Considerations for Efficient Programming 9.6 System and Core Synchronization 9.7 Memory Architecture?The Need for Management 9.8 Physics of Data Movement Chapter 10 Testing and Debugging DSP Systems 10.1 Multicore System-on-a-Chip 10.2 Software Architecture for SoC 10.3 SoC System Boot Sequence 10.4 Tools Support for SoC 10.5 A Video Processing Example of SoC References + ?+ T7 t2 w( v" l8 ^; p- N
Digital Signal Processing World Class Designs.pdf
3.61 MB, 下载次数: 5, 下载积分: 威望 -5
发表于 2016-11-19 15:00 | 只看该作者
支持楼主!谢谢分享!' A& G' ^( r% O( R* n' q
发表于 2016-11-19 15:27 | 只看该作者
真的谢了,提供这么好资料啊!- r: z6 I1 w$ `: c
GMT+8, 2025-11-24 01:07 , Processed in 0.171875 second(s), 26 queries , Gzip On.
