一,FPC设计基本介绍8 m, Z& ]7 j7 e* I* k; N
1.Flex dimensional stability is known to be poorer than its rigid PWB counterpart. The material (Polyimide) is flexible and is more susceptible to moisture absorption. One simple technique to minimize this dimensional instability (expansion or shrinkage) is with effective use of copper. More copper means more stability% _; @* w. [+ s2 a
2..FP容易被撕破,因此在外形设计的时候得注意:外框要尽量简单,不要太复杂,并且内部弯折的地方要有比较大的直径,另外FPC上尽量少有cutout) S! p$ z( I2 E7 Q
3.Square corners are not recommended. 不允许出现方形的corner.机构设计的时候要注意不得在fpc上产生任何不受控制的压力,不得出现非常尖锐的corner.- m3 ]' P c$ ?
4.To improve adhesion of copper, all conductors should have rounded corners , not mitred or right-angled, especially in dynamic or bend areas.FPC走线的抗剥离的能力比FR4要弱,并且弯曲会增加剥离压力,使更加危险。为了增强copper的粘附能力(adhesion),所有的route在拐弯的时候都必须是弧形。
/ W3 E/ R+ N' ]9 G6 W! h- F. k$ _' t+ d
5.为了避免那些走在COVERLAYER/COVERCOAT的route断裂,必须让从PAD开始到coverlayer/covercoat下的一部分走线宽度至少为250um,并且这部分长度至少有400um。对于0402等小尺寸器件尤其推荐如此,可以说是必须。也就是说从pad出发到coverlayer下的一部分线是加宽的,然后再渐变到实际的ROUTE WIDTH" r2 X2 `9 @: a2 s$ M7 `
6.Copper hatching is recommended for the following reasons:对于有些NET的铺铜最好做成筛子状,有以下几条理由% d" K! G) a o" q* }( K
6.1Enables coverlayer adhesive distribution to minimize thickness variations6 v, l0 e Z5 K# R! M4 s, d, s
6.2Assists copper balancing of conductor layers
* D. H5 G- Q5 V( P$ R' D+ C7 E 6.3Provides flexibility and reduces springback force in bend areas增强弹性,减少弯曲区域的弹力
3 Z8 ]0 }. V8 i4 Y; ^" j# O8 k; X+ [5 G$ O) s* z& |3 Q
6.4改善 dynamic FPC的大面积铺地的动力学性能* G( [' Q- D& `; p: }- s q4 a
6.5增加加强材料的站附能力,主要是因为这样做气泡会很少。0 Y3 q8 a! u) }. ^4 q/ u" q% I
7.Teardrops should be used always when possible (not only in via hole pads). Especially important they are where thin conductor leaves a large pad e.g. for keypad interconnections,. In this case also note that through hole vias are not in the middle of the key dome pad. .
" m8 g" q: n$ P5 M2 A8.所有route的宽度改变都必须是渐变的,用泪滴或者neck-down,不能变化得太尖锐,这样能够防止在尖锐corner的地方出现短线的情况。另外就是使用泪滴或者延长PAD,例如可以延长在同一PAD上再走一小段wire到COVERLAYER之下。0 Q s; z- z8 z' G, H- o
5 H' `) w' }( I7 y( w& U9.FPC材料容易撕裂,尤其是在象corner,定位孔这些动态的区域。CUTOUT内部的CORNER和外框的CORNER应该是弧形的,并且至少1.0MM的半径,并且要COPPER进行加强。/ g0 H; A: x% k
10. Minimum tooling hole / guide-pin hole diameter is 0.6mm 。没有使用加强措施的区域的定位或者安装孔必须要用一cooper做的圆环来支撑。
: T/ Q5 D- {, x4 X" w7 v& W c7 ~4 d2 z# O0 Y Z" I; f
+ U% Q2 k2 B3 `5 M8 ]: M
6 E: F' C$ }! o4 |4 ]* d. D2 z0 Q3 U3 G5 i* w! J' K1 U+ a
[ 本帖最后由 Iric071 于 2008-10-10 16:44 编辑 ] |
