You have module Clock_Generator.v 0 X; Q `+ W0 n& F
with port input [31:0] key_value0 P7 B: v5 c, K8 o: Z) B8 [# `# D' T
and you set a instance of
3 X/ ~0 X) o$ W0 ckey_scan_jitter key_scan_jitter_inst9 w @3 }& Z9 ~. u/ Y5 ]
(, o1 r8 J( l. Q: U& |
.clk(clk),4 _% Q; t, Z/ o
.rst_n(rst_n),
7 A$ ?4 q8 Z9 N; T .key_data(key_data),
7 X. v4 V+ ^% m! g1 f .key_flag(key_flag),
4 ?! s6 k7 q# h .key_value(key_value), }, ?3 l+ Q* f1 m
* ? n% J2 T( J4 ^! k+ i3 \In module key_scan_jitter.v8 u% g9 y5 H7 J8 a
you have output[31:0] key_value) [" t0 {& b4 `0 U: q
$ W% e7 U# x$ ]; m' Z, g9 f) D
So module have to source of key_value:
) e* l. |% P1 o. |* T1. From input port (may be 32 pins of chip)
$ S; W P, h) H6 Q8 }/ o/ O2. From internal instance key_scan_jitter
8 ]! H, B7 o0 V! l9 v# n& Z% ^- N. i; i& o; H0 I; L/ v
Altera can-t to do short circuit in your module.
% n+ |' s' F1 L. W |
