查看: 229|回复: 2
Basic Concepts in RF Design__
发表于 2022-8-17 11:09 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Basic concepts in RF Design
4 X0 M4 C. P0 U3 t7 ~Overview# j; l% V& w  \
System Theory  c1 K$ b9 y9 x* M
Effects of Nonlinearities, Q, k0 e# T! |# b( ~+ I5 @6 p( M% Q/ U8 o- I
Gain Compression' _: `2 F9 f2 i& Z/ ]. M
Desensitization and Blocking6 q$ U1 f# ^2 n, I6 Z
CroSSModulation% M8 y# U* v7 K/ g
Intermodulation
- C" @0 L6 G6 SAdjacent Channel Power Rejection
7 x2 l! @) v. R9 `# PRandom Signals
. ], p: e6 b. Q, s+ X7 ~Noise and Noise Figure
& j5 Y" S2 w9 G+ c" t4 iInput Referred Noise( `9 u2 e- r: I+ c% X
Noise Figure of Lossy
) e; V4 z' @% r/ D1 m: p! b
0 x3 }1 m5 i& ^8 [
( F) ^+ Q5 F: @# g5 a! O. TSystem Theory (1)# {& l: [+ W  k
Linear Systems7 f3 S+ n$ j1 s' e% l
1 1 x ® y 2 2 x ® y3 c3 t& \$ }$ _; N
1 2 1 2 ax + bx ®ay + by
  M. J2 W0 b( F7 l; w, FIf inputs x1 and x2 generate outputs y1, y2
( R- f0 e9 m3 ]For a linear system output can be expressed as a linear combination of inputs
0 G: E1 l6 k, c. E. s( K) Mfor all values of the constants a and b$ D7 X* `+ S5 E( j) n
Time Invariant Systems. ?8 a9 W" p! s! B8 R; w3 _( X* U, O
For a time invariant system time shift in input results in the same time shift in output  M/ b+ X. X3 {! A) H# O
x(t )® y(t ) then x(t -t )® y(t -t )
  L: V2 \& t0 L  k3 ~Any system that does not satisfy this condition is nonlinear
- J1 t# V  B8 dObs. A system is nonlinear if it has nonzero initial conditions
) g4 r3 ^% T; i6 t) @. b9 Gfor all values of t* V/ Y2 p) j* p9 i, A
8 j7 j/ d* M  j% o5 @3 k. S
% g: ^  d2 v4 F  C
0 C  O) U0 D2 G+ N6 D
Rf Design.pdf
1.37 MB, 下载次数: 0, 下载积分: 威望 -5
发表于 2022-8-17 11:47 | 只看该作者
谢谢楼主,实在是好东西啊,学习了
发表于 2022-8-17 13:53 | 只看该作者
谢谢楼主分享,哈哈哈
GMT+8, 2025-11-22 14:02 , Processed in 0.171875 second(s), 26 queries , Gzip On.
