序列 x(n)的奇偶分解的公式为:
- m; j' i4 V( a8 K
# n- D5 c5 G% J
/ w. U% V% u) D9 v
4 Y t+ w1 s8 R$ d. t3 f; K. c6 D
4 f$ Z- e, _' i; F4 `) z8 {
, _) y0 d2 P7 [5 a1 p. e
编写一个序列 x(n) 的奇偶分解式 xe(n) 和 xo(n),需要考虑的问题是序列长度,下标的变化。
1 F# v8 `8 J, i2 K
+ g$ c5 n) e3 N0 @3 C/ P; L这里必须做个声明,下面的程序中用到了前几篇博客中的几个函数,这里给贴出来:
2 L, d( m' u+ s7 |1 Q: F! j N% K) ^* X
信号相加:
X' U4 W0 |- [- u* E9 T4 t7 O, n& ~- C1 e7 K
function [y,n] = sigadd(x1,n1,x2,n2)- x# @' O) b8 V/ `# {( B9 B
% implements y(n) = x1(n) + x2(n)/ ~' s) V2 [' D2 y
% [y,n] = sigadd(x1,n1,x2,n2)8 J+ J* C& N/ A& `5 }
%____________________________________! B" t/ ?7 O5 }9 a
% y = sum sequence over n, which includes n1 and n20 L, _) f5 @$ g
% x1 = first sequence over n1) i1 `8 x: R9 Z/ o, A0 j Z
% x2 = second sequence over n2( n2 can be different from n1)) Z* ^$ o! G' A7 z
. |1 J9 W/ s& o2 ^; Nn = min( min(n1), min(n2) ):max( max(n1), max(n2) ); %duration of y(n)2 u% v/ D" Y2 i, r
y1 = zeros(1,length(n)); y2 = y1; %initialization
- B# U/ Z3 W0 m% O {6 X2 `y1( find( ( n >= min(n1) )&( n <= max(n1) ) == 1 ) ) = x1; %x1 with duration of y1
4 r; w* W# ?! Oy2( find( ( n >= min(n2) )&( n <= max(n2) ) == 1 ) ) = x2; %x2 with duration of y26 p! B! {+ y" L
y = y1 + y2;1 ^' R7 M( p' d6 |* l
* I# U0 N% \& f, [2 u
( Z7 E X0 E7 i# E信号移位:
& g6 Q9 S4 h7 u" e$ I0 g# R+ K$ l/ w: K2 W$ }% k9 e7 Z( a6 G- R
function [y,n] = sigshift(x,m,k)
* F: U% [ D4 H" s; o8 I4 V%implements y(n) = x(n - k)
0 P X/ m k+ @ a1 V- j4 j+ H9 b( f: v* ^%_________________________. z4 b( m; K0 F ^
%[y,n] = sigshift(x,m,k)& |, p# \4 | b+ y
% H- r" D. C8 ^* e+ C. s9 P1 D5 u
n = m+k;( R6 u! ^, ~4 Y* m5 F6 x' E
y = x;9 o6 _- f$ W' D. v( I
6 k, y p1 g( \- R: N8 y
* S% L5 i2 K' `0 v单位阶跃序列:( ^5 l) b8 T# ]. _' _* L) t. K
* o, p. O# d, d+ tfunction [x,n]=stepseq(n0,n1,n2);3 ` x2 h+ H: L3 |: X) a
% generate x(n) = u(n - n0); n1 <= n <= n2, f) e) m. A$ ~3 @0 o
%_____________________________________________5 o0 _% H. U9 B9 d+ J: |' Q- b
%[x,n] = stepseq(n0, n1, n2);1 t. }: z3 g9 z$ F
%/ @0 ^$ Z9 D* T
n = [n1:n2];* b& x( B2 V& V6 N
x = [(n-n0) >= 0];
$ I$ N' P& k7 j# F5 l# ^( y$ K# Q( b) u4 |
6 R4 K+ I0 M0 A. g6 ^
下面给出函数程序:7 Z' O) Z9 z2 `1 y" j6 m( v
/ H, ?# ~* J! W6 P) s2 Yfunction [xe, xo, m] = evenodd(x, n)
# _6 i1 g) ?, v' x& u1 S% Real signal decomposition into even and odd parts" B. X+ J* w) M+ K
%__________________________________________________
4 D3 W! {. b) c0 i: b%[xe, xo, m] = evenodd(x, n)1 ]0 D, p/ E0 l" u
% ^0 q) ?5 R6 |if any( imag(x) )
2 Y; l9 n" ~4 {: X$ a- B' J error('x is not a real sequence!');
: e- S6 }2 s& r$ i. s6 v" ?# Cend4 |& x7 _# b# Q, h7 U
* k" \, m/ s: D6 f- j- ]' S- W M
% Ensure m of xe and xo; L7 R: Y4 D$ Y9 ?- N- F1 ^& k
m = - fliplr(n);1 m) r7 A7 t. j3 Q M6 b
m1 = min([m,n]);
4 x; {( ^" x. E7 S$ O0 A" sm2 = max([m,n]);2 Y; x; D+ o3 B! K
m = m1:m2;$ O7 E: Y3 j, x2 N
7 `" d- R1 B5 u% Ensure x over m
0 o$ h! |$ \0 w9 ?# X3 [nm = n(1) - m(1);& u. y" Y' n, v
n1 = 1:length(n);: u, C: ?; V. B& B3 e
x1 = zeros(1,length(m)); % initialization% A# G- [ c% C( j/ E1 Z
x1(nm + n1) = x;8 A9 A+ ~* X6 S$ t4 Z" [; t
x = x1; % new x which enlarge index n2 a4 V6 u1 h; s' q6 O7 O' R
; q" A; R6 F7 E% H5 s$ M
% xe and xo
* r3 f" y% o# |- ^+ w! jxe = 0.5*(x + fliplr(x));+ F: s: {/ k; g, r# s/ |
xo = 0.5*(x - fliplr(x));- T1 ]; L+ L+ k% a/ v3 w+ f1 x
, K- f. N3 H" O! g$ q
; a! U6 b8 Q7 [7 B: K
序列和及其位置分别装入 x 和 n 数组。首先确认是否已知序列是实序列并在m数组中确定偶部和奇部分量的位置,最后将所得奇偶分量存入xe和xo数组中。& M1 J1 i: Z! z
% v" w* L) m4 I, u, X下面以一个实例来验证上述函数:
$ L9 l% r' G: _ G! m( J2 I8 l5 c) @# H, m4 X# T* l
- i3 P! e* _; ?3 _* X: A7 z0 T( o
7 Y6 _6 E# ]6 G; ~将x(n)分解为奇偶分量。
8 n* R5 s7 X! x) Q& m s( S
, i- i$ Z$ @/ N1 |+ D! t3 dclc
* H. z1 N. i( V- p7 ^- Z! Pclear
/ T2 K4 ]) y' T' n. Vclose all
0 M! Z5 K6 O( Z" O2 y& t3 c( w) ]& I8 i* G6 ]! k1 V& i
n = 0:10;
8 m3 h8 U( N7 O$ }3 O: Ix = stepseq(0,0,10) - stepseq(10,0,10);
* i+ P- L0 B0 J+ t$ L[xe, xo, m] = evenodd(x,n);
) U/ D# T" w/ y5 e( l
! H3 ^/ f! |" [$ E4 bsubplot(2,2,1);
5 ]( [" ]( m2 ^# W. Vstem(n,x,'filled');" B# t7 ]4 _- Q4 ]( I
title('Rectangular pulse');
: w. u# }) Z1 D- P; axlabel('n');ylabel('x(n)');
3 @" i7 h- a; d2 d: M# S. Y' qaxis([-10,10,0,1.2]);2 X2 N1 G* V1 U7 ?- M' X& }
) q- |0 `) K' _- b( \5 B2 Msubplot(2,2,2);
; ]# P4 L: |6 G+ C$ estem(m,xe,'filled');& C* |0 x1 ]3 M( u" S: N/ R% A, t
title('Even part');4 N, S$ u) ?$ L1 j7 ~
xlabel('n');ylabel('xe(n)');
- p* F+ R0 i; w& V9 ~8 n7 Y. ~/ oaxis([-10,10,0,1.2]);2 H$ i* g Q$ j* Q( N, Y1 b
$ P7 ^! I1 g+ O! G( L P$ r/ W( Jsubplot(2,2,4);
; N& K; g* p, h- X' [stem(m,xo,'filled');- i9 h, G2 B. ~9 a- [0 v/ e
title('Odd part');0 N/ l/ \2 Z3 D* J$ t% A/ Z
xlabel('n');ylabel('xo(n)');
" [6 N. N( S1 @- z8 v+ ]* taxis([-10,10,-0.6,0.6]);
' F' R/ H V- }& v+ p8 \7 d
- i: \9 m" ]+ K! U
0 |0 p5 O- Y. v4 x! t* s3 A9 G/ h2 y. K
事实上,这篇博文到这里已经结束了,那我还想看看序列x(n)= u(n) - u(n-10)的合成过程:
K$ i$ [5 o4 m2 x8 ]0 A
; {2 I7 ` h; y* ^, l aclc
! e+ ]4 h, y# G4 k* P* g) Fclear
; h$ d: `2 u! U" N) Lclose all
0 u: T, G, D1 R2 B- L# z0 \5 {6 }$ N/ l0 @" }. ^
[u1,n1] = stepseq(0,0,10); K9 k2 Q0 h3 l( O6 q' v
' }6 c* b/ U Z; g0 K; }/ D! b1 G) I
subplot(3,1,1)& C, @$ K! H5 \7 U6 I, g5 _
stem(n1,u1,'filled');1 o+ z2 j o" b" C& {' [: n
title('u(n)');
( h- h& {! f. j' y: e1 j$ m% m: G' ]* Nylabel('u(n)');xlabel('n');6 e( u9 w# E/ ~, _. f
6 G8 R8 W2 ^0 p9 n0 ~$ {$ m; |; f, G5 U: j! x
[u2,n2] = sigshift(u1,n1,10);: H9 ^( Z- W9 \$ c
subplot(3,1,2)
' N# L. n" A) A9 S3 l2 Cstem(n2,u2,'filled');0 [ N' i# G' z0 Z8 S
title('u(n-10)')
" B' i- q& f9 I" Zxlabel('n');ylabel('u(n - 10)');! s9 T; g& ~; [; S( X0 I9 _" M
axis([0,20,0,1.2]);/ g. O: Q+ z5 H/ O1 ~
# W: g. |! Z( x4 Y0 ^[x,n] = sigadd(u1,n1,-u2,n2);" z, |/ ]" T, i/ e9 x
' M: X/ Q' u6 d! Q
subplot(3,1,3)$ p }- r8 g# G- _8 ?3 z5 e
stem(n,x,'filled');3 k7 g2 ]7 H% k; i4 S+ A
title('Rectangular sequence');
# C+ Z+ s8 l) Cxlabel('n');ylabel('x(n)= u(n) - u(n -10)');
* l( B& ?% z+ V& Q; i5 Uaxis([-10,10,0,1.2]);
& l" {( A* X! [7 l( z6 O5 q' ?
, l$ s$ \1 Q9 j" V
8 I. b$ q: I! ^" n6 a
. I* T; t+ p% I8 l& q/ I0 V
8 p# V/ [0 D( V1 l; C& S
