查看: 312|回复: 1
快来了解一下CentOS内核源码的安装方法
发表于 2020-3-20 09:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2 R% s' y' H3 s9 z( f
不完整的内核源码:; Z% f5 q4 e5 q% a. g2 I: ~# j
/ m! C+ g/ F7 n/ h6 @
安装:' @- U7 Y' u% p" L! L* Z
     * kernel-devel (both 32- & 64-bit architectures)+ J) a( {# i: @1 l+ v, k
     * kernel-xen-devel (both 32- & 64-bit architectures), }$ W3 d3 M# V% |1 p) _  Y
     * kernel-PAE-devel (32-bit architecture only)
  Q8 `; ?. S* M! W% G+ h执行:( f2 i8 n6 g# R( q8 E
ln -s /usr/src/kernels/2.6.18-238.19.1.el5xen-x86_64  /lib/modules/$(uname -r)/build2 p* e: F( \, _
" Q& T5 p; B- d5 ?2 R  y
" j* [0 \1 P$ B4 I8 \8 n完整的内核源码:
3 X  |: |8 t: w1 Myum install rpm-build redhat-rpm-config unifdef  ?. ]2 G. ^9 b2 D2 v
wget http://vault.centos.org/5.7/upda ... 274.7.1.el5.src.rpm' e1 n3 v- ]. i- p5 x7 @% t6 z$ N7 i' `
rpm -Uvh kernel-2.6.18-274.7.1.el5.src.rpm
* a$ }& e, t! c5 \& p" U; J9 _% G% M
' [  r8 i$ O1 q8 Q6 a; R# {cd /usr/src/redhat/SPECS% }1 g% a3 X! k& \
rpmbuild -bp --target=`uname -m` kernel.spec" K: v( W8 U: X' F1 P+ V
最终源码在/usr/src/redhat/build目录中:/usr/src/redhat/BUILD/kernel-2.6.18/linux-2.6.18-274.7.1.el5.x86_64/
    2019-11-29 15:37
    发表于 2020-3-20 17:39 | 只看该作者
    CentOS内核源码的安装方法
    GMT+8, 2025-11-26 01:14 , Processed in 0.140625 second(s), 23 queries , Gzip On.
