查看: 1305|回复: 6
出gerber出现以下warning怎么办
发表于 2013-10-16 17:01 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
出现有warning,但是gerber文件能出来,cam350打开检查也没问题
. h* I7 _- n% y1 p% b9 b# O  b/ Q" }8 f8 C1 J9 O8 Y
怎么回事啊{:soso_e115:}
  u1 [- G$ ]* t1 `/ S/ y! E% O$ a2 f( v9 T7 v! z1 o9 ]9 [
Results from parameter file ...0 C  O4 N* z  T6 X9 E
    DEVICE-TYPE           GERBER_RS274X/ @$ ~! N8 S2 D6 S- C* f
    OUTPUT-UNITS          INCHES
# H( N. ~' i' W/ w% }    FILM-SIZE             2400000 1600000# t' Z$ e/ S8 `. R- ~8 j: J" `+ e
    FORMAT                3.5
7 U5 ~, J$ X: R/ x% G( p% V    ABORT-ON-ERROR        NO
: ?" W' _9 H' R$ z3 H    SCALE                 10 x5 a. `7 y: h/ p: Y
    SUPPRESS-LEAD-ZEROES  YES
3 m7 O/ ?! h7 f  l4 X5 ^    SUPPRESS-TRAIL-ZEROES NO9 P0 r1 Q" U+ V5 Q' I+ j( a- T
    SUPPRESS-EQUAL        YES
. \% S- T  k: }8 F( P; E    UNDEF-APT-CONT        NO
' E2 {* m) `: l; o2 z& _! a! v2 y
" y3 [+ K5 J. n) |; E
4 {, i& n- j* ?  O================================================================* @7 @# i. O5 \3 N
     PROCESSING FILM < BOTMASK >2 p$ Q+ ^2 r7 R) n  l
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTMASK.art > ...4 j  M& K1 r% D8 T8 m
================================================================/ Y. A- {3 b6 l7 x
7 l- K9 l8 k2 G7 C4 z
  FILM PARAMETERS :
( M1 l- W- v6 M6 t* R  ---------------------------------------------------------
% q/ e2 D& r; X7 n. d7 ]/ U  Undefined line width                6.00
# D0 p. A6 ?; o  Mirror code                         NONE
+ C' M) J$ T; I0 K: t: O& \  Rotate angle                        NONE5 w6 C0 p. h% ]' [/ J; {% ~
  Offset x:                           0.005 ?7 \0 t5 E# f7 o& f/ V
  Offset y:                           0.00( P3 ?- M) N2 S$ c6 ~3 N
  Plot negative                       NO& O0 W9 v4 K1 {
  Suppress unconnected internal pads  NO
% X* `2 v% V5 F! [! B5 T) P  Draw holes only                     NO
' c* h1 K+ ?  ^, A( U- r1 j+ D8 R" J1 U: A' ]4 A
    WARNING: 0 width line found at (-1198.89 1386.00)
  ~' R2 _8 u2 x: Z0 e           ... using undefined line width of 6.004 L' W' F7 _+ V" I' q0 v
2 a# d8 f5 f9 {7 e# b6 v* D: ~
2 O& l$ `5 m# M- |" A
. T! }1 C' c, ^( z0 R+ Q  APERTURES USED:8 h0 B. C5 m- I6 {  C* Q0 |- e
' m4 g4 ^! I: P6 w+ s1 {  TYPE       SIZE/NAME                   ROT   MIRROR MODE
# X! b2 M: n7 y9 H7 m% E% ]  ---------------------------------------------------------! @6 {# M! F& h5 T- }; X" x5 s
  CIRCLE     0.00600                                  DARK
5 k4 }7 ?8 Y* I! A. W+ M  CIRCLE     0.06500                                  DARK
4 a8 v6 S; Z) K" U8 P2 H3 P3 S; l  CIRCLE     0.08500                                  DARK
0 S) P  Y- C. Z5 y& D  RECTANGLE  0.03000     x 0.05100       0.000 NO     DARK
# }7 @+ T, o' \7 i3 a  G4 o  RECTANGLE  0.03800     x 0.04600       0.000 NO     DARK
! l0 _% `# `3 r9 e  RECTANGLE  0.06500     x 0.10400      90.000 NO     DARK ! l$ i2 z8 R9 I) k! K: J
  RECTANGLE  0.10400     x 0.09700       0.000 NO     DARK # |3 I) }* M* t: ]/ A5 Y8 L
  OBLONG     0.02000     x 0.06700      90.000 NO     DARK
5 d4 N) L3 I& F! t  OBLONG     0.03000     x 0.06700      90.000 NO     DARK
8 i1 F' U1 t  b  OBLONG     0.03000     x 0.07600       0.000 NO     DARK
- f5 P) A9 w) L7 v. ?; z$ `# V  OBLONG     0.04000     x 0.07600       0.000 NO     DARK
3 |1 t( l- I" e+ a% D% w, @+ L  PAD SHAPE  SHAPE32X35                  0.000 YES    DARK
8 k  J0 ~7 V- F* C1 s( W4 w8 J  PAD SHAPE  SHAPE32X35                 90.000 YES    DARK
; Y. i. e! w) s1 ]5 v- z( Q$ |  PAD SHAPE  SHAPE32X35                180.000 YES    DARK ; c7 X& d- ]& e! v, l% h5 N
  PAD SHAPE  SHAPE32X35                270.000 YES    DARK % M% ?  z. K8 w3 P
" v$ U- n2 i& _$ k
     BOTMASK created with warnings. o, N& r5 q' b! _
  x* X7 P+ t4 }- ?/ w! A5 H% _
  `& Q4 D# ~+ _- ]2 F% @5 ~
' L* m2 F  k; `( }) V5 }     PROCESSING FILM < BOTPST >
! Q1 q# ?* D- @' \( G) d. K8 M     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTPST.art > ...
7 a. L" v" ^9 Z4 Y; G/ w================================================================
! k1 n9 h! C+ O/ ]3 X4 |+ g
) v! H' w! ^6 V& s  FILM PARAMETERS :
+ {% e, e$ D# ~; Z; e  ---------------------------------------------------------  z. o* R, f1 r
  Undefined line width                6.00) L& {2 w, o/ K9 l9 D5 a3 \6 C
  Mirror code                         NONE
+ b; g. h  R* X) B5 K  Rotate angle                        NONE
: v4 T: W9 p- T  @" A6 ]1 H" V  Offset x:                           0.00
* k4 ]! d3 C& V; b  Offset y:                           0.00
8 S" b, k/ M; |7 s, w& D3 t# y2 J5 ]  Plot negative                       NO
! y' j7 K! x1 h8 {! f  Suppress unconnected internal pads  NO
0 D4 [4 P" S, Q  Draw holes only                     NO
& l6 k0 n, Z' D/ K9 Z. @. i2 Z& l* [, |& Z( i& S$ u
    WARNING: Multiple 0 width lines; all will be treated the same as the first.
* Q4 [5 q3 |/ i& }           ... using undefined line width of 6.00/ S' Z* E6 J! J, y8 D
" h: W. s9 n( ?* C6 G; I
3 b% k8 P$ j6 Z" B8 q
3 T# t7 T3 w% b) w$ p; d  APERTURES USED:& T1 g' N" \1 i8 O; \
  ---------------------------------------------------------8 z9 E. F. j. O, R5 e* g  W  g' \
  TYPE       SIZE/NAME                   ROT   MIRROR MODE ; k, `( j5 r/ R+ q* @8 `/ a* V
, C, P* e, W- k+ O; _! M$ i, a  CIRCLE     0.00600                                  DARK
8 l6 [3 d2 @- M5 i7 |6 }  RECTANGLE  0.02400     x 0.04500       0.000 NO     DARK 9 n! [6 r( y; U. g3 R1 w2 e' F' X
  RECTANGLE  0.03200     x 0.04000       0.000 NO     DARK % W0 j& m/ u- z
  RECTANGLE  0.05900     x 0.09800      90.000 NO     DARK ; p  A# H% P, E+ B" D0 h  f( a
  RECTANGLE  0.09800     x 0.09100       0.000 NO     DARK
  X, {: g1 J# ^7 k' Q  OBLONG     0.01400     x 0.06100      90.000 NO     DARK . g7 p1 Q  q7 N
  OBLONG     0.02400     x 0.06100      90.000 NO     DARK
0 Y6 ?% n# N% ~$ v  OBLONG     0.02400     x 0.07000       0.000 NO     DARK
6 F  U3 A' D: c  E  OBLONG     0.03300     x 0.02900       0.000 NO     DARK . b: I0 N5 G" Q6 C; e
  OBLONG     0.03300     x 0.02900      90.000 NO     DARK 4 U/ _0 e- y# a6 s
  OBLONG     0.03400     x 0.07000       0.000 NO     DARK
3 L0 h( h/ H+ }5 N$ k
  N+ v: S! [' R     BOTPST created with warnings# h  q$ ?- o$ a" C+ M8 b# G6 F
8 ^4 _3 B; `. l8 @! E& Q7 ]8 b" d+ L+ r: t
================================================================8 s0 i  j3 N$ z; x
     PROCESSING FILM < BOTSILK >
/ J) {0 S$ k2 R- @; D7 F     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTSILK.art > ...
; Z6 H& P5 p3 g5 u5 O- x1 \================================================================$ Y+ r$ D2 U" d) ^1 ]
8 ^) g2 A9 S2 u- @+ ]
  FILM PARAMETERS :# H- {5 T  E8 d# M( Q- |; E
  ---------------------------------------------------------$ |1 o; q8 E1 V5 {2 |: x( N
  Undefined line width                6.00  h/ i' M0 e9 `: v, R
  Mirror code                         NONE
3 U* d' ?  W- X/ g  Rotate angle                        NONE
3 ?4 o9 z6 E: a" v. G5 e  Offset x:                           0.009 Z( Z' ~" S7 {4 }) k( T; l0 Y
  Offset y:                           0.00' o2 s0 X/ k8 e9 `0 \& p' K; E
  Plot negative                       NO# m: A+ G* ?5 S
  Suppress unconnected internal pads  NO4 B( ~/ m1 P: p5 ^2 [+ W
  Draw holes only                     NO1 v6 u; ~  f2 G& Z2 b+ [- }$ g4 W) w# @
' m6 r: _; u( Y, Z; y% T% y/ m: t. G7 f; C
% V" s8 \7 i! D: [1 n7 V
  APERTURES USED:
8 A# a" y  v' \' p* v, p  ---------------------------------------------------------
2 b, `. Q0 d+ P# r. H) ]; L. T' }  TYPE       SIZE/NAME                   ROT   MIRROR MODE
* l( m' w- a. Q$ f  ---------------------------------------------------------$ `7 o* A' h; s5 o3 O9 W' f
  CIRCLE     0.00500                                  DARK
; F* {- D, S/ q) y4 Y) h  CIRCLE     0.00600                                  DARK 3 r# o" ]* i+ s
5 Y) d8 u4 O# @8 K4 o! j, C; S2 E     BOTSILK created with warnings
' g3 X7 Z- s3 t2 k+ {
+ K8 {4 X; W/ L5 A  o, y* J) C7 T6 h0 H1 w, I, h8 z2 V* t
# d1 ~4 t/ c5 j     PROCESSING FILM < BOTTOM >4 b! m8 l/ K# h
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/BOTTOM.art > ...
9 k0 t8 K  g7 m( O$ n& A) Q================================================================& U3 P3 f2 F3 w, v; p; d4 b5 C
! ?& F- e- d2 ~4 K4 n
  FILM PARAMETERS :
5 E6 ~/ T) o* X$ N. U  ---------------------------------------------------------
: R3 o( e+ q1 U$ O1 B4 g) y/ T8 G  Undefined line width                6.00: m. f8 @* L# x6 H" `# W2 v3 ^
  Mirror code                         NONE
/ `/ |& Z0 p$ A* ~' K4 u  Rotate angle                        NONE
4 ?0 k; u: X* ~- @0 e% q  Offset x:                           0.00( L3 z  L$ ?6 E6 y
  Offset y:                           0.00
4 K* u9 E; N5 `  Plot negative                       NO
3 y) c$ R; w3 @$ U  Suppress unconnected internal pads  NO
  l5 a+ ~: O4 u5 c  Draw holes only                     NO
" D4 {) x& w- X
% K+ @; W& Q  c6 W) `
  J% j) z7 H/ q) i: B. [6 v0 |
% _0 }* Z! k, _( b; V9 ?  APERTURES USED:7 q2 r* O; M( b% i  j* Y# @
0 n/ o! a9 B& _& t6 A: `  TYPE       SIZE/NAME                   ROT   MIRROR MODE 3 G+ G/ V6 J6 ^1 a, \) D' s# F
6 Y) o4 ]% {, t) G) D! Q  CIRCLE     0.00600                                  DARK
1 t' t3 ^# y5 O; _+ \. A, q  CIRCLE     0.01200                                  DARK
7 G5 m% z/ Q8 ~5 D0 u" N$ z. s  CIRCLE     0.02000                                  DARK
6 l1 }1 f% v6 |  CIRCLE     0.02200                                  DARK
/ ]; Q( c& q9 z0 A0 s7 ]  CIRCLE     0.02500                                  DARK
: k- J# {# U( m4 t: s: Y: Q  CIRCLE     0.05900                                  DARK
7 @, G/ B9 m8 w! v  CIRCLE     0.07900                                  DARK % I( U1 g: L, S" h) p
  RECTANGLE  0.02400     x 0.04500       0.000 NO     DARK / N- \3 B- U- C
  RECTANGLE  0.03200     x 0.04000       0.000 NO     DARK   P, I  w( p& |# }
! \& }$ H, V1 P& @( ^  RECTANGLE  0.09800     x 0.09100       0.000 NO     DARK
$ _1 j4 t* I8 ?6 X  OBLONG     0.01400     x 0.06100      90.000 NO     DARK ' q6 Q3 }, A  {2 E+ D- \! G7 ]! `5 S
  OBLONG     0.02400     x 0.06100      90.000 NO     DARK * _/ V, {7 E5 m; x) G; W/ H. W3 v
  OBLONG     0.02400     x 0.07000       0.000 NO     DARK 6 ]9 y3 n" v$ Y- D
  OBLONG     0.03300     x 0.02900       0.000 NO     DARK $ A6 e$ b4 s7 s' E& G. p
  OBLONG     0.03300     x 0.02900      90.000 NO     DARK 0 n: E* C4 Y3 P" o2 H( b, }/ E
  OBLONG     0.03400     x 0.07000       0.000 NO     DARK . G& A5 T6 b4 W# l1 B* c
/ i! `) v! p# f( Z3 p' s/ u
     BOTTOM created with warnings# Z5 ], l: G' r# @8 ]6 }0 o3 r# _
( {/ L; u$ K* {$ G0 m; a
+ w/ ~6 D* ~  m7 c3 b================================================================2 ?- M5 Y9 `1 D3 l6 X5 Y
     PROCESSING FILM < DRILL >
+ G" D, `) p3 z9 ]# ]# h     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/DRILL.art > ...
9 d1 N. K8 f; |! S. }. U================================================================: {/ q  N0 B: d
& W$ M" R+ t6 w1 x. S: G7 F
  FILM PARAMETERS :+ w) b# Z$ d1 j7 J' a+ p$ N
+ R" v3 ]% h; |$ R. T) l  Undefined line width                6.001 `( I: a7 M6 h1 D1 w( F2 v0 z
  Mirror code                         NONE2 f7 X6 a. b1 |
  Rotate angle                        NONE
5 S7 B8 j" }9 H. I0 p  Offset x:                           0.00, a, X6 j3 Z$ t
  Offset y:                           0.00' |! K$ T( M$ E" }) F  C# W& ]
  Plot negative                       NO
9 w( X1 A& [4 P1 U4 k3 o! l5 F  Suppress unconnected internal pads  NO$ j8 k& [1 i2 {1 C. \
  Draw holes only                     NO
5 b) S/ K# t( N
% L, G; R0 k. @    WARNING: text composed 0 width line found at (-771.80 2586.30)
( `6 r7 w$ O3 P0 J6 `           ... using undefined line width of 6.002 W1 q5 z8 V2 }, J' N+ p! ^& N* ~
/ `+ d" p7 c# E1 J" Z4 F. m6 z' _4 J    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.( A' u2 U/ r6 G, {- M* A; `
           ... using undefined line width of 6.00  b( ?- c* w/ N, j  g9 i+ d& l
$ u# H; U$ e, T: X& Y9 W: C) A/ ]! Y
! y& }+ ]8 g7 J, Y7 C
4 i1 C2 M' v3 z6 _! {  APERTURES USED:
7 U& W) i  [; K$ J% I  ---------------------------------------------------------& Q/ N! f" J' O  X
  TYPE       SIZE/NAME                   ROT   MIRROR MODE ' A, v+ R( {! B+ s/ B
* `( U7 Z& `$ Y9 R4 `  CIRCLE     0.00600                                  DARK 8 I1 T7 L$ ^0 f& C) \& U) ?
8 j- |0 @$ I# y$ ^* K
     DRILL created with warnings( T8 L0 P$ y9 K+ Y8 n
3 P( A9 P, M5 U: z1 `; n
4 `) x2 z) Z6 Q: O( Q* G4 }
================================================================2 h1 |+ ?5 Y7 A$ k4 r
     PROCESSING FILM < TOP >  `! q+ K' n, W. e% ^; o) r
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOP.art > ...9 W  m! B: C0 c( }+ }' B
================================================================) D/ _2 p! H: l) I
% U& g/ i3 W$ y) s( e$ T  FILM PARAMETERS :
, T9 t4 G, t& Q4 j2 M+ {; s% y  ---------------------------------------------------------' o" {: g+ g" w# R
  Undefined line width                6.00+ O2 x' D8 ]' s# [0 D, i7 C
  Mirror code                         NONE% \8 D3 e" R5 w' a
  Rotate angle                        NONE$ ]' f; E% j/ m8 A: l, X
  Offset x:                           0.00. Y( C" y0 U) w6 `4 f
  Offset y:                           0.00
+ }5 |: I( w2 e* c2 }8 y. k  Plot negative                       NO# L$ M( G# T* p5 f1 Y: `: L! T7 P
  Suppress unconnected internal pads  NO- Z; g9 b3 Y7 R# v: q7 Q+ V: u0 R
  Draw holes only                     NO( Q, w: y3 p" T! t8 J* T, a
8 n: k5 |% K5 U$ k' j9 i6 z
9 X3 s2 n1 Y4 P. {( G
( V+ x0 e. r5 p, Z" A7 N* M1 A  APERTURES USED:  ]( _0 H  l6 B0 T5 \" E7 I6 y: h
3 j, k7 `) S. q& b( }* `5 z  TYPE       SIZE/NAME                   ROT   MIRROR MODE 7 M7 t9 z( u; w9 Z( N
  ---------------------------------------------------------1 h4 T& d+ w6 B8 V9 I8 ~
  CIRCLE     0.00600                                  DARK / b& M! p( `) g* @. J
  CIRCLE     0.02200                                  DARK
. o  L8 i3 h7 B7 W) ?2 T$ P$ G  CIRCLE     0.05900                                  DARK 1 m# |+ I7 h7 q, j
  CIRCLE     0.07900                                  DARK
( C$ o+ g1 K- D- Z0 _" N6 m& ?4 P  RECTANGLE  0.03500     x 0.07000       0.000 NO     DARK
( X& a' w( z6 |; a; o& y, s2 L9 z  RECTANGLE  0.04000     x 0.03500      90.000 NO     DARK : c6 k+ g7 X: n" ^2 O
9 V: Q' M* N( ^# V: @; r  a     TOP created with warnings
% B- a  r  F. g: [) S/ A! k6 P& k4 V9 \4 v- X! z" R, |
7 r- q) J: w. J: l" q  q================================================================, K9 z0 X) L+ a% M# O8 v
     PROCESSING FILM < TOPMASK ># f4 i: i! o* [
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPMASK.art > ...
! A1 W0 _0 i) P2 }) A+ s7 h================================================================
( J6 i! \  ~, n
7 x* ?$ I) M% J: H3 a, g* O8 v( S  FILM PARAMETERS :
9 E" ~& k9 [% Z% h& ]2 q! X# k  ---------------------------------------------------------
4 \- n% {  h& ~: N  Undefined line width                6.00! D+ W$ d% |7 x) o( }% W4 @! u# g5 \  v( Q
  Mirror code                         NONE9 W4 M) f+ C6 a  Z/ j2 S! `1 i
  Rotate angle                        NONE& f: o( p( S' {8 C* [" T1 i* i
  Offset x:                           0.00
* ^+ a: q8 l+ W& P* t, a) Y7 q  Offset y:                           0.00
( B6 T! [4 a4 T  Plot negative                       NO
& z9 u0 H( |3 ]; E- j$ N. `  Suppress unconnected internal pads  NO
. V$ P, Z) j8 @- R+ u, L4 V3 M  Draw holes only                     NO! k" h; N0 ?6 |2 w* \! b/ {
. i4 ~/ Z8 M2 ]* h. ^, e" L
3 ~; ?: }, ]$ h$ F3 {: r2 u. i# w9 t' L! h! @  }) S( r
  APERTURES USED:
5 A8 V$ T. v1 A2 W  ---------------------------------------------------------+ W  |: Y3 I, L+ W, N& x' R0 {
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 3 w( i* w+ F, N) a% Q* a
, X# Y& P& o+ Y: K7 A  CIRCLE     0.00600                                  DARK % y! [$ n, c+ o* V. \; U
  CIRCLE     0.06500                                  DARK
% o, ^& I* p4 W7 O" x8 ]  CIRCLE     0.08500                                  DARK $ R3 m: i2 F3 \" e# S( @0 Z
  RECTANGLE  0.04100     x 0.07600       0.000 NO     DARK
3 w5 ~3 O) M! V! X: T+ _  RECTANGLE  0.04600     x 0.04100      90.000 NO     DARK . d8 w6 M' e. F: l, Z
3 ~  Y8 ^" c: T/ z& |     TOPMASK created with warnings. y* C6 d" G8 H% ^) f3 V
" ~; f; E5 p& p( X
$ W% I( W8 T4 D4 b0 S  `
0 m7 k. ^5 f+ _, C. P     PROCESSING FILM < TOPPST >6 J. D, r3 x8 C" G% h) i
     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPPST.art > ...6 c7 ~& q4 R  f7 j' g
. D) [% V# ^) I: w: _$ Y( E+ l& M4 I. F8 P. [# b. d" z* {
  FILM PARAMETERS :+ w# D' h0 K0 T$ Z$ t
  ---------------------------------------------------------( s# V2 P& a0 B, Z3 i! f
8 Y/ b/ P' n6 U, l  Mirror code                         NONE. u& L3 E7 \( V8 }
  Rotate angle                        NONE( R$ Y3 t% ?1 i2 q3 C% t! |# K
  Offset x:                           0.006 [% Z7 u' }/ u
  Offset y:                           0.00, _$ d( `7 G, U( g- M- Q* d
  Plot negative                       NO; B" ?5 V4 P6 P% Q/ C* h6 i6 l- t& m
5 p) V& k/ E2 d( h/ Y& c  Draw holes only                     NO4 P+ _; I) i! c* j! H9 B! C
3 A) m( t& t! l' ?3 |' q, [/ p% _
2 r7 Q, \; z: w5 v9 |$ f" ^0 S' t" F% M) r/ y6 |, |6 l1 e& [
  APERTURES USED:7 o& y: P# P: C2 X  j1 K
  ---------------------------------------------------------) C" d" P, Q5 N7 l- u% y2 i; v% N
  TYPE       SIZE/NAME                   ROT   MIRROR MODE " y, n- m& s# m; x# w, S! L8 l$ H8 {
% E2 t# f6 V4 U  CIRCLE     0.00600                                  DARK / a  {5 B) J: W  J' K+ l
" z' B5 {3 O/ L& h9 l4 H+ C+ o  RECTANGLE  0.04000     x 0.03500      90.000 NO     DARK $ W" }- P2 v) b/ |) Q3 ]5 j
4 ?9 i3 D- z1 [: \  P* H6 l0 G
     TOPPST created with warnings
7 T8 \8 M' `- K2 p7 N  j9 s  s* @; L2 x* P
# B. K- k+ z  |$ N( u  d2 ~================================================================  S; R& Z& J+ s
     PROCESSING FILM < TOPSILK >
) u# @: p. E5 a, v, G/ E: L" U     TO FILE < G:/LED/apple_led/1.1/BRD/gerber/TOPSILK.art > ...
" b% d. }: _; ~( g8 [) i, u7 Z5 r================================================================
( Z5 A; e7 x8 d1 p9 E2 g# o  ~9 x% w
  FILM PARAMETERS :
. \7 l( y/ O- _0 q  r/ n  ---------------------------------------------------------
6 J1 {! ]* G$ _" |  Undefined line width                6.00% Y+ [  J' R# O4 Q5 o
  Mirror code                         NONE
/ E1 n. Z5 |7 V  Rotate angle                        NONE# p( \: q& X3 `, g5 M
  Offset x:                           0.00/ A0 ]$ ~. E+ F) k% n1 t1 x6 B
  Offset y:                           0.00
1 I  ~/ f( T0 G+ Z* H' n9 Y/ @# H. M  Plot negative                       NO
6 o! Y4 Q2 b' N1 ^4 f# `' A# R# b  Suppress unconnected internal pads  NO
- }1 i( D. C( L- i, X; V) `  D4 {% n  Draw holes only                     NO; ~; Y; k  p( V( Y+ E
$ L8 l/ D$ Z9 u$ P% H2 Y
( |+ \/ r) u6 R% {! @2 a4 H7 R% C$ r* @2 L
  APERTURES USED:
9 Q4 q4 r4 r7 C8 E! l# t  K  ---------------------------------------------------------( M" v* k) @  R0 e' \7 R# m/ _
* N9 \' @8 Y1 Y, `0 m; }  ---------------------------------------------------------
! o" ^" r) U6 r9 M$ `, V  e  CIRCLE     0.00600                                  DARK
8 r2 D! P6 m6 B8 H5 e( S* ^: A9 H9 b3 J8 R* T
     TOPSILK created with warnings0 m1 m; C& g- L3 M2 r) S& p4 F
8 }$ j2 J9 u7 H( G8 n: d/ s) V
9 }/ I( G2 E/ @2 N) x0 p0 @( H
------------------------------------------------------) n8 a+ S+ `. N8 q( H
SUMMARY:
( u$ |  r' ~% s! A; }- f5 h# Y8 x        BOTMASK created with warnings
( f; W3 }7 B* z4 j+ z        BOTPST created with warnings
7 ~% l. k- g( L3 E# R! O% L# g        BOTSILK created with warnings0 H4 Z7 d5 Y2 S; z. j7 t) k
        BOTTOM created with warnings* A8 ~8 O+ U& }7 \: Y+ G8 n: ?
( E# [8 m  ^, d# U  I  K        TOP created with warnings& B2 Y! x' h5 h; Z; }( Y
& Y$ _1 v% F. _6 m! K* z        TOPPST created with warnings) F# ^) Z- r1 N0 X2 w$ @' F
        TOPSILK created with warnings8 W- n; @' d9 p* o$ y, J- l
  E0 r" S1 E% ^
ARTWORK had warnings
  q; d% @; o) J- m
 楼主| 发表于 2013-10-17 16:19 | 只看该作者
procomm1722 发表于 2013-10-17 13:39
6 c3 D: @6 M/ `要說有沒有影響 , 一般應該是沒有影響.
  u& p$ K2 T( _! L; E+ H但是心裡應該會覺得毛毛的 , 不踏實.% v+ `( o9 O" }% b  v
但你只要把零線寬的資料( li ...
9 t) X/ z% q  D% A& @: x9 n谢谢{:soso_e100:}
发表于 2013-10-17 13:39 | 只看该作者
要說有沒有影響 , 一般應該是沒有影響.( G: f& X4 z/ H4 V7 t$ z8 J% e0 z
但是心裡應該會覺得毛毛的 , 不踏實.
1 o& y  \- n9 p8 {1 I* q1 F+ f但你只要把零線寬的資料( line , text )補上寬度(width , photo width ) , 自然就不會有這種訊息出現.
 楼主| 发表于 2013-10-17 09:24 | 只看该作者
procomm1722 发表于 2013-10-16 21:54
3 B/ C5 c5 q; a5 z4 G2 d樓上的猜測不對.
5 b8 n9 e) e) v- F. i: y9 {這很單純的是因為要被產生成gerber 的底片資料裡面有一些線條是沒有給寬度的.. E! e* w! S6 u& V) ^% [9 X3 ^6 b
沒有實體 ...
, t1 y- a; @* e
请问出现这个问题有影响吗,或者说如何解决呢
发表于 2013-10-16 21:54 | 只看该作者
樓上的猜測不對.# ]7 d3 x( p5 d' ^% O
這很單純的是因為要被產生成gerber 的底片資料裡面有一些線條是沒有給寬度的.  R( O% z& W7 f: v/ H
沒有實體大小的資料是無法被產生出 Gerber , 因此系統這時候就會引用 undefine line width 這個設定值來代用 , 幫然因為也不知道這些資料套上undefine line width 這個設定值是否合理 , 因此系統一定會給出警告的訊息 , 讓使用者注意
发表于 2013-10-16 17:05 | 只看该作者
如果像这样每一层都有warning,最大的可能是你的画布>24000*16000,调小点。7 \5 i" _" {" Y
然后再把0宽度的线改一下就ok.
    奋斗
    2025-11-21 15:48
  • 签到天数: 135 天
    [LV.7]常住居民III
    发表于 2013-10-16 17:04 | 只看该作者
    1 |% h8 B1 I5 v, x* {& z7 j, F           ... using undefined line width of 6.00, ~' O. p* k+ H+ I% M% u& o; A" H$ a
    2 R0 S# A1 a% t. `, y
    * {5 Z+ ]$ p  e* K# _* s6 l    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.$ U$ w+ e( M# h/ Y4 ]: {+ j4 N$ _  c" e: {" i. n, I  r
    GMT+8, 2025-11-22 09:01 , Processed in 0.156250 second(s), 24 queries , Gzip On.
