pads layout link 时出现以下txt文档?? 请问各位大概是什么意思? 怎么解决。。。
4 o7 m+ W& C6 O//////////////////////////////////////////////////////////////////////////////////////////////////5 ]# m( K# ?4 _8 p9 d
$ L c1 G. Z: w8 Q5 ?PCB Net List Errors Report - A10-EBOX08-0615 .sch - Tue Aug 21 20:50:53 2012
5 C3 }9 |, n! @9 } ----------------------------------------------------------------------------- p" c& |5 d; t- {* S/ n
Design to Library Part Consistency Check: d1 ]! p* T" t5 w$ v
----------------------------------------& k2 L# ~0 u h0 G
Part Type CVBS has the following gate pins that do not match to the Library part:: t8 c" |1 |; v; @
(6 1) (4 2) (2 3) (1 4) (3 5) (5 6).
* ?& U$ D( ^5 g" k) { Non matching Part Type CVBS is used by the following parts:. t! b) g2 Y; H: |. n0 n% Q+ a- c
J6./ c- ]9 s5 ^: P8 t$ C6 t
Part Type NJM4580/SO_0 not found in Library - not able to check following parts:7 `) I) f. g9 k' W2 d0 v& K
U4.* o! o7 b. n7 P9 E2 A& O$ f
Part Type C0603 has 1 gates in the design and 0 gates in the Library., C* i; ^0 d1 @6 O2 Q' g
Non matching Part Type C0603 is used by the following parts:
; J, q. D; @2 @% a3 I1 H' J' ~ C63 C64 C65 C66 C72 C71.
/ F2 q6 Y+ s/ {0 C% p4 R7 B N0 Y+ p Part Type SH has 1 gates in the design and 0 gates in the Library.9 N$ ^6 |* J' v5 n: A
Non matching Part Type SH is used by the following parts:
6 ]0 m8 F. n. D) E! @ SH1 SH2 SH3 SH4.
5 q( k- ^+ f3 B7 N4 P Part Type IR_MODULE has the following gate pins that do not match to the Library part:8 a8 d1 D. M7 C/ |: V# p7 I" c
(3 1) (1 2) (2 3).6 C) g/ N4 z# y) p. m
Non matching Part Type IR_MODULE is used by the following parts:
& E8 z2 D9 g# _$ b G3 K U9." b. g+ O$ s& v& k
Part Type R0402 not found in Library - not able to check following parts:9 f% S9 b, O4 U8 T" q
R10.
$ N+ E# H: y8 x( B7 @+ w( ^$ O Single/Zero Pin Net Warnings$ y5 Z2 B0 c4 [; f: h; t
5 |* t. a0 A! [" q: q Net LRADC0 has less than two pins in PCB net list file.
0 L" m6 d! J2 `4 E8 u1 }* d( H Net SD3-D3 has less than two pins in PCB net list file.
v g8 }2 L$ ^7 N ] Net SD3-CMD has less than two pins in PCB net list file.$ J! s0 x" Q5 C3 ?! H
Net SD3-CLK has less than two pins in PCB net list file.
) J6 `* J7 ?/ H) X Net SD3-D0 has less than two pins in PCB net list file.
: @+ ~ y: a4 d) B Net SD3-D1 has less than two pins in PCB net list file.$ _! _8 C; p4 `# }
Net SD3-D2 has less than two pins in PCB net list file.
8 z. c7 e0 g) D/ }: x+ ^ Net $$$7141 has less than two pins in PCB net list file.
, Z6 q% f6 ^) E1 h. F; Q Schematic Connectivity Errors
4 d5 m6 L' o( k9 T. P# h" C -----------------------------! F: F: m) C! h9 b+ ^( w
Floating Connections or Subnets+ ~& R) z0 {% D' E( ^( G5 o2 J
ECOL
& B" F7 {( s3 @0 O, h: R 14_EMAC X1700 Y7680 . w/ o% x3 e+ S/ w" o' K
ECRS
$ T, N7 q" h8 [$ r0 t 14_EMAC X1700 Y7880 * U) ~' ? B, K
EMDC6 I' `7 l w1 q. d
14_EMAC X1700 Y8680
6 H$ Z' p8 X. PEMDIO
6 U5 d1 F$ E, t( R1 U, r 14_EMAC X1700 Y8480 5 q3 O7 ^( d8 j/ w$ p5 U% Z% Y
ERXCK
, t' U8 C1 t4 X+ O% m4 B 14_EMAC X1700 Y9280
/ x& Q3 ~1 M4 s) i$ K9 @ERXD07 L) e1 m6 @8 s2 I! I' K a
14_EMAC X1700 Y102801 r# E3 U; E- N6 w# A5 i
ERXD1
: B; A' e# L. I 14_EMAC X1700 Y10480
* `: F/ |% d3 ?4 O ERXD29 x$ Q( r; d( I6 P/ y! m
14_EMAC X1700 Y106808 C* _3 s3 a" T
ERXD3
8 a9 l: S0 G. J1 T/ Y$ S; a 14_EMAC X1700 Y10880
; s/ B+ E0 Z- y* f# ^ ERXDV" T4 d- q2 Q. \5 U( {
14_EMAC X1700 Y9 n6 Z4 Z+ r4 K# R0 {% w+ c0 d
