查看: 3741|回复: 20
Hotfix_$PB16.50.013
发表于 2011-12-22 08:57 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
  F' j$ Y. y! K- j2 d
8 d% R6 w& P: u& Ghttp://kuai.xunlei.com/d/DGOHIFKLICUP
3 Y2 c' d% W+ Z, P" f% N: X$ U" `% H. i9 O* w$ D8 h
6 x& B6 @" R4 T, |DATE: 12-16-2011   HOTFIX VERSION: 013
4 @  {3 O" }3 T5 @! {===================================================================================================================================' g* U2 o9 T7 y9 k, }, R7 K: U
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE; o  p6 {4 Y$ K4 [$ a
" Y7 ^  z% l# A7 X/ V/ h6 J9 B875695  SIG_EXPLORER   INTERACTIV       Enforce Causality check box doesn't work., V$ \8 M5 @% U: c8 F9 M: w% X
927148  CAPTURE        PROJECT_MANAGER  Capture crashes on creating scehmatic folder with name which already exists in design
1 L$ P" L4 t. `6 U& J: ?938013  CAPTURE        NETLIST_OTHER    The netlist in RINF Format contained two identical lines for PCB FOOTPRINT
" M8 ]/ p2 {; m" C) a941409  Pspice         PROBE            BUG : Search accuracy wrong in new cursor window
0 t4 R+ Z; k/ A2 f: D945242  SIG_INTEGRITY  SIMULATION       Unable to select "shapes" in find filter for 'show parasitic ' command# d! H$ V# B" a& U
946293  concept_HDL    ARCHIVER         Archiver hangs if there is a whitespace at the end of the path of cref.dat( O/ i( F  `3 c
946770  CONCEPT_HDL    CORE             揤iew Design?function is missing in Windows Mode after reseting the menus.& y8 V1 e. f# b4 h6 B/ ?+ X
950994  CAPTURE        NETGROUPS        Problem in expanding the netgroup in Auto Connect to Bus function6 b; F! P: o+ Z: P& E0 g
953530  SIG_INTEGRITY  GEOMETRY_EXTRACT Display Parasitics is displaying wrong results for EMS2D Field Solver compared to topology extraction using Probe.
0 v, ]1 g3 ?4 S1 z* ^) {' Y953713  CONCEPT_HDL    PAGE_MGMT        Random page replacement/duplication in block
" h) g3 I3 ?8 P  d, ], I. w( J953917  CONCEPT_HDL    ARCHIVER         archcore should handle errors correctly
  S! t: a7 ~3 v3 o& T953971  allegro_EDITOR MANUFACT         NC Drill files not generated correctly when using the option "搒eparate files for plated/nonplatedholes?- }) y* d, `" h+ K/ d1 P) ]; t
954400  CAPTURE        NETGROUPS        BUS members of NetGroup are getting converted to Scalars in Export-Import NetGroup.8 D3 d" `  d5 E
954498  SCM            B2F              SCM crashes when importing physical
! W* h7 w% s$ G) p2 }/ L954623  ALLEGRO_EDITOR EDIT_ETCH        Unable to complete connection with Add Connect - related to soldermask to cline check?
, `6 n1 C) [! x; d954894  ALLEGRO_EDITOR MANUFACT         Dimensions disappear when opening database in v16.5 from v16.32 ^0 B  D; r: f: J0 t0 Z# R
955029  CONCEPT_HDL    CORE             custom text font size not recognized in symbol view
! z) W8 ~2 c2 c+ K& g8 w  n2 h/ F- {955133  SIG_INTEGRITY  FIELD_SOLVERS    The Field solver creates the differential trace model which is reversed T(D1) and T(D2) of bottom side.+ M3 R2 x: Z% Y! M. B5 n9 Y
955290  CAPTURE        DRC              Description for UPD0014 missing in the Browse DRC markers window. A0 U% q/ R% E) J2 Z
955299  ALLEGRO_EDITOR DRC_CONSTR       drc text to smd pin does not work any more on this database in 16.3 S039( I& g7 {9 X7 @$ z0 y- g+ {: L
955338  CONCEPT_HDL    CHECKPLUS        Need to change PART_NAME. X8 B, x0 w, b" @9 J0 a
955447  SIG_EXPLORER   OTHER            Model path set in DE HDL Model Assignment not used by SigXP from CM in DE HDL
+ j# r; H# O. i6 x6 @8 }955740  SIG_INTEGRITY  GEOMETRY_EXTRACT Crosstalk with Timing Windows does not work correctly
; ~! V3 r) a7 x# y955749  ALLEGRO_EDITOR MANUFACT         show element Info shows symbol dimensions on incorrect subclass
# {( a& V& h0 b' {; u. H; h7 R955912  ALLEGRO_EDITOR OTHER            Shapes with voids that are exported to PDF have gray filled area over the void) [3 w% p* ^. t# h' D( \0 n; Z
956129  CONCEPT_HDL    INFRA            DEHDL uprev hierachical design from 16.2 to 16.5 packaging failure.
- X4 Q4 q+ }, l( v956373  ALLEGRO_EDITOR NC               drawing name doesn't display in the log file2 Y, F+ A) F/ @7 ~! m# R& J7 a: q
956393  CAPTURE        PROJECT_MANAGER  "GENERAL" and "TYPE" tabs are missing from "Properties" dialogue box.. w( D9 a7 b! h  e0 Z8 |
956448  PSPICE         MODELEDITOR      Can not generate a DEHDL symbol from Model Editor, because no Capture license found
; E  @4 B2 N2 G& o956456  CAPTURE        NETLIST_OTHER    OrTelesis netlist not transferring user properties defined under combined, n9 g4 @' o8 n. ~8 @  R
956489  ALLEGRO_EDITOR MANUFACT         dimensions lost when symbol with diemnsions attached to symbol origin placed on board) L" X6 h3 K* |4 q2 a3 b
956603  CONCEPT_HDL    OTHER            Part Manager "has stopped working" after changing a component5 k  n+ ^) d) p/ }5 o# ]- }
956751  ALLEGRO_EDITOR ARTWORK          Import Gerber command does not work correctly, p9 G  |4 }+ @  S" C' X/ y4 ]! l8 [
956847  PCB_LIBRARIAN  METADATA         PDV - Partdeveloper symbol to function linkage broken/changed in 16.5
2 i( D; y( [4 |9 ~. O956987  CAPTURE        OTHER            Find from "Search toolbar" doesn't gives complete results! i- l  T9 r! A+ p' B4 h
956996  CONCEPT_HDL    INFRA            Correction to ERROR(SPCODD-7): Following Primitive instance causes CM to empty
9 W2 b& V$ u. C/ d* O4 N957009  CAPTURE        NETLIST_OTHER    Problem getting database property in mentor pads PCB netlist
8 d5 z" v' e7 }0 L! }5 a2 U: X. ~957137  APD            DXF_IF           DXF out  command dose not work correctly.
! y* b# l- Q1 Z$ K$ ~  \957167  APD            GRAPHICS         Highlighting for Static shape with display_nohilitefont environment variable.4 P' v& I! _1 K$ ]6 ]  g
957232  SIG_INTEGRITY  OTHER            Allegro crash during Model Assignment.3 f- i! @* [8 \3 a: Z
957267  CONCEPT_HDL    INFRA            Packager Error after Import Design$ U! g6 z5 U+ M# Y4 Z
957866  SIP_LAYOUT     DATABASE         Cavity outline is not getting deleted from symbol file
" |' ?% o  E: o# a% [958010  ALLEGRO_EDITOR REPORTS          Wants the ability to extract "Batch"  reports from Partition ".dpf" files.. T0 s# d6 `4 H/ Q- `! y
958252  ALLEGRO_EDITOR TESTPREP         Resequence testprep with the option - Delete probes too close crashes the design
  }( h! V( \  R9 O" j9 U958253  ALLEGRO_EDITOR REPORTS          Shape did not have thermal relief connected to pin but unrouted nets still shows zero.9 N6 I9 @0 R7 n( t) Z
958433  ALLEGRO_EDITOR DRC_CONSTR       False embedded component DRCs
% a' l# G) G* h7 f9 R958753  ALLEGRO_EDITOR SHAPE            Dynamic shape is getting corrupted in 16.5
+ y+ U9 c. R. l8 d1 w9 I959011  ALLEGRO_EDITOR OTHER            copy problem of via and cline* w( u" j+ {# d% Q
959101  ALLEGRO_EDITOR EXTRACT          Using extracta with excluding Thermal reliefs
- _* W, Y0 b3 s+ \0 y959253  CONCEPT_HDL    INFRA            Design will not open$ M% h4 G4 _3 h
959299  APD            MODULES          Getting ERROR(SPMHDB-279) when trying to update modules placed on the Top side
1 {" o+ c: h9 L* U, R959884  CONCEPT_HDL    INFRA            Design Uprev/concept2cm crashes with Application Error/Out of Memory Error.* C. O( z- H0 G/ E# m( c
959909  ALLEGRO_EDITOR SCHEM_FTB        Site level propflow.txt file is ignored property is transferred
: }8 Y5 \- b$ C1 O& V( k, a+ ^0 T960067  SIP_LAYOUT     PLATING_BAR      Creation of plating bar removes "NODRC_ETCH_OUTSIDE_KEEPIN" property from the clines.$ T9 _. r* @6 M9 B
960126  SIG_EXPLORER   EXTRACTTOP       Allegro PCB SI license is used automatically at Topology Extraction of Allegro Physical Viewer.
7 h* z: q) z$ |8 U# {! @960143  SIG_INTEGRITY  GEOMETRY_EXTRACT Running simulation in Bus sim happened crash while enable Coulpled Via model to S parameter; n) \$ t+ P  ~8 G: k1 C6 Q0 j
961349  CONCEPT_HDL    HDLDIRECT        Motorola designs have broken connectivity compared to 16.3; b( k+ u! N" r3 c3 R
961816  ALLEGRO_EDITOR INTERFACES       Normal Export > DXF fails and offsets  the pins of the BGA symbol
2 x- W9 G2 }* H6 K, O4 d2 v% w962519  SIP_LAYOUT     WIREBOND         Align option doesn't work for wb_tackpoint fingers
参与人数 3贡献 +16 收起 理由
轩辕浪 + 10 赞一个!
xzcpj + 2 很给力!
interrupt + 4 神马都是浮云
21#
发表于 2011-12-27 17:06 | 只看该作者
超酷,哈哈。太感谢了!
    慵懒
    2023-12-23 15:37
    20#
    发表于 2011-12-27 16:26 | 只看该作者
    十分感谢!
    19#
    发表于 2011-12-25 17:09 | 只看该作者
    无法下载啊!
    18#
    发表于 2011-12-25 09:31 | 只看该作者
    感谢分享!更新太神速了呀!
    17#
    发表于 2011-12-23 12:30 来自手机 | 只看该作者
    写的是下载链接已失效。。。
    16#
    发表于 2011-12-23 08:34 | 只看该作者
    谢谢分享,
    15#
    发表于 2011-12-23 06:51 | 只看该作者
    太感谢您了
    14#
    发表于 2011-12-22 16:45 | 只看该作者
    感謝分享{:soso_e179:}
    2025-11-22 15:53
  • 签到天数: 735 天
    [LV.9]以坛为家II
    发表于 2011-12-22 13:26 | 只看该作者
    楼主好人啊.
    4 H! s. k+ U) S  ^" g太感谢了.. O/ h0 i# a6 J' v0 [# \
    现在这cadence也太差了把
    发表于 2011-12-22 11:41 | 只看该作者
    说什么好呢
    发表于 2011-12-22 11:31 | 只看该作者
    ) i8 E, J* I& I感謝分享
    大神啊,顶, x! i2 ]" Y5 q4 G* W5 u& W- Z* n
    发表于 2011-12-22 11:01 | 只看该作者
    都更新些什么呢??
    2024-5-31 15:00
  • 签到天数: 1000 天
    [LV.10]以坛为家III
    发表于 2011-12-22 10:58 | 只看该作者
    感謝分享{:soso_e100:}
    GMT+8, 2025-11-22 22:49 , Processed in 0.171875 second(s), 27 queries , Gzip On.
