, D4 T* o9 `4 Z* |- U1 G- start-stop-daemon
- BusyBox v1.26.2 (2018-08-02 17:42:03 CST) multi-call binary.
- Usage: start-stop-daemon [OPTIONS] [-S|-K] ... [-- ARGS...]
- Search for matching processes, and then
- -K: stop all matching processes.
- -S: start a process unless a matching process is found.
- Process matching:
- -u,--user USERNAME|UID Match only this user's processes
- -n,--name NAME Match processes with NAME
- in comm field in /proc/PID/stat
- -x,--exec EXECUTABLE Match processes with this command
- in /proc/PID/{exe,cmdline}
- -p,--pidfile FILE Match a process with PID from the file
- All specified conditions must match
- -S only:
- -x,--exec EXECUTABLE Program to run
- -a,--startas NAME Zeroth argument
- -b,--background Background
- -N,--nicelevel N Change nice level
- -c,--chuid USER[:[GRP]] Change to user/group
- -m,--make-pidfile Write PID to the pidfile specified by -p
- -K only:
- -s,--signal SIG Signal to send
- -t,--test Match only, exit with 0 if a process is found
- Other:
- -o,--oknodo Exit with status 0 if nothing is done
- -v,--verbose Verbose
- -q,--quiet Quiet
9 E2 k8 }7 H: _6 R& D# N, I: e, K
2 I( z7 b8 |+ ^2 p5 b5 H4 R T9 S5 a0 R
- chad@ape:/$ start-stop-daemon --help
- Usage: start-stop-daemon [<option>...] <command>
- Commands:
- -S, --start -- <argument>... start a program and pass <arguments> to it
- -K, --stop stop a program
- -T, --status get the program status
- -H, --help print help information
- -V, --version print version
- Matching options (at least one is required):
- --pid <pid> pid to check
- --ppid <ppid> parent pid to check
- -p, --pidfile <pid-file> pid file to check
- -x, --exec <executable> program to start/check if it is running
- -n, --name <process-name> process name to check
- -u, --user <username|uid> process owner to check
- Options:
- -g, --group <group|gid> run process as this group
- -c, --chuid <name|uid[:group|gid]>
- change to this user/group before starting
- process
- -s, --signal <signal> signal to send (default TERM)
- -a, --startas <pathname> program to start (default is <executable>)
- -r, --chroot <directory> chroot to <directory> before starting
- -d, --chdir <directory> change to <directory> (default is /)
- -N, --nicelevel <incr> add incr to the process' nice level
- -P, --procsched <policy[:prio]>
- use <policy> with <prio> for the kernel
- process scheduler (default prio is 0)
- -I, --iosched <class[:prio]> use <class> with <prio> to set the IO
- scheduler (default prio is 4)
- -k, --umask <mask> change the umask to <mask> before starting
- -b, --background force the process to detach
- --notify-await wait for a readiness notification
- --notify-timeout <int> timeout after <int> seconds of notify wait
- -C, --no-close do not close any file descriptor
- -m, --make-pidfile create the pidfile before starting
- --remove-pidfile delete the pidfile after stopping
- -R, --retry <schedule> check whether processes die, and retry
- -t, --test test mode, don't do anything
- -o, --oknodo exit status 0 (not 1) if nothing done
- -q, --quiet be more quiet
- -v, --verbose be more verbose
- Retry <schedule> is <item>|/<item>/... where <item> is one of
- -<signal-num>|[-]<signal-name> send that signal
- <timeout> wait that many seconds
- forever repeat remainder forever
- or <schedule> may be just <timeout>, meaning <signal>/<timeout>/KILL/<timeout>
- The process scheduler <policy> can be one of:
- other, fifo or rr
- The IO scheduler <class> can be one of:
- real-time, best-effort or idle
- Exit status:
- 0 = done
- 1 = nothing done (=> 0 if --oknodo)
- 2 = with --retry, processes would not die
- 3 = trouble
- Exit status with --status:
- 0 = program is running
- 1 = program is not running and the pid file exists
- 3 = program is not running
- 4 = unable to determine status
3 n( ]0 ^5 d" i0 A+ I
8 K/ D/ ]* O! l! G) B% s3 H5 C& H& P8 s T
# z A" Z3 k! _$ pNAME
, o2 t5 O0 @: _; @ S C2 [ start-stop-daemon - start and stop system daemon programs2 B- x0 V' G- Q* u
& H$ u& \( U7 JSYNOPSIS# M3 o+ C& e; K: O
start-stop-daemon [option...] command- S4 N( w+ U. Z/ S5 ?8 a# p" K
. e, l. ]5 I- g" x, ?+ B
DESCRIPTION; @5 z0 ]! E" b ^2 g. e7 B
start-stop-daemon is used to control the creation and termination of system-level processes. Using one of the matching options, start-stop-daemon can be configured to
. S; u( s' @1 s8 L find existing instances of a running process.
9 @7 n- N( t- @7 p$ @$ v- W. O/ `7 u9 B
Note: unless --pid or --pidfile are specified, start-stop-daemon behaves similar to killall(1). start-stop-daemon will scan the process table looking for any processes
3 [1 S( \# D, g2 y3 F, B which match the process name, parent pid, uid, and/or gid (if specified). Any matching process will prevent --start from starting the daemon. All matching processes will$ d# o$ ]6 t' [0 _
be sent the TERM signal (or the one specified via --signal or --retry) if --stop is specified. For daemons which have long-lived children which need to live through a: O9 c- F, Q6 Z5 i
--stop, you must specify a pidfile.
8 z8 w* v& U `9 p+ ]
! _$ H, l! D* v( ]4 GCOMMANDS+ o$ X* S8 T7 Y+ ~* ?$ U/ R
2 S! V# R' w1 o. v- b% E2 n+ c1 f' G7 B! @4 a5 N6 v
-S, --start [--] arguments8 s9 R3 ]. H* p
Check for the existence of a specified process. If such a process exists, start-stop-daemon does nothing, and exits with error status 1 (0 if --oknodo is specified). If such a process does not exist, it starts an instance, using either the executable specified by --exec or, if specified, by --startas. Any arguments given after -- on the command line are passed unmodified to the program being started.! [7 Q% b5 o) Y; q/ M6 E8 [2 @
% a, M' g: L' ?9 O) y; U
-K, --stop
9 x! Z1 Z" f- d% ~. i Checks for the existence of a specified process. If such a process exists, start-stop-daemon sends it the signal specified by --signal, and exits with error
& P3 L/ g( n0 _+ C status 0. If such a process does not exist, start-stop-daemon exits with error status 1 (0 if --oknodo is specified). If --retry is specified, then9 T( f1 t( N* }8 G( o' E
start-stop-daemon will check that the process(es) have terminated.
8 a8 Y: j4 Y; g/ T8 L! A, ?( z% ?% A- T2 J7 q; A a- t: h
-T, --status
+ Q( c, N$ B* V J! U2 l6 D Check for the existence of a specified process, and returns an exit status code, according to the LSB Init Script Actions (since version 1.16.1).
. i3 w8 ]" S5 J4 ]5 A0 e3 Q
" Q4 }0 ]7 j$ ]& Z( d -H, --help
3 N! E8 R" _% P- f+ w+ q1 ? Show usage information and exit.( z$ N0 d3 i- a$ H
1 o* _' Q5 Q0 e. N4 ^5 [0 K
-V, --version
M: r/ X9 B! H: Z, ? Show the program version and exit.6 `5 ~: V1 u; }7 H* g
. J8 a1 v) ]5 R7 t/ ]4 C/ T
OPTIONS
* x% z [5 p* U Matching options
, o: Z7 v" _3 ^1 T# L- J8 q% B
8 [3 B4 H& c2 ~" x+ W1 ?7 i% v0 m --pid pid7 z1 S8 u! q/ ]( ^
Check for a process with the specified pid (since version 1.17.6). The pid must be a number greater than 0.4 L, W8 v6 K, i5 o& w9 ]
: i% j, u" E6 O( z7 h" `% h --ppid ppid
- ~( X- q5 s0 t' k ?" H Check for a process with the specified parent pid ppid (since version 1.17.7). The ppid must be a number greater than 0.
$ z9 h9 _8 }# m0 R5 C
7 B1 Y. f5 c7 T% r -p, --pidfile pid-file
) b/ _/ J$ C0 Y8 o4 p, ~. ^# X Check whether a process has created the file pid-file. Note: using this matching option alone might cause unintended processes to be acted on, if the old process
; o: t" [3 @6 ?2 }, P! Z terminated without being able to remove the pid-file.
6 }; q: R7 r# F: r8 J$ c0 J. W1 k1 Q7 |5 b) ]0 w/ l2 z N
-x, --exec executable! r& _2 [0 ~7 \+ l
Check for processes that are instances of this executable. The executable argument should be an absolute pathname. Note: this might not work as intended with interpreted scripts, as the executable will point to the interpreter. Take into account processes running from inside a chroot will also be matched, so other match restrictions might be needed.
! M6 g3 e8 k8 a: H0 Z V
. u' L3 f: M9 J" [ -n, --name process-name
+ W' F, J$ I4 Q. j Check for processes with the name process-name. The process-name is usually the process filename, but it could have been changed by the process itself. Note: on1 U7 s& ]* Y$ V0 r% `7 s4 ~
most systems this information is retrieved from the process comm name from the kernel, which tends to have a relatively short length limit (assuming more than 15) V, H) |7 g6 {7 s4 |
characters is non-portable).
$ B/ P( _* D R, O _' ~! h* I! }6 h0 _% @
-u, --user username|uid9 n& z* V6 \$ H
Check for processes owned by the user specified by username or uid. Note: using this matching option alone will cause all processes matching the user to be acted# u" ^& Q( ]% D% i& V
on.
9 M# e; Y6 C4 g; @4 J7 o8 X+ ^; ~5 p% D
Generic options: K3 U5 M: m2 E1 P! P: u4 {
-g, --group group|gid" T. @+ q9 `3 `, _7 ^
Change to group or gid when starting the process.
7 B, _. e( V; `/ @
5 C7 w9 t- _ i+ | -s, --signal signal. I; r: H8 v6 I
With --stop, specifies the signal to send to processes being stopped (default TERM).7 m7 ]# r8 b8 e1 M1 q+ ~( A8 f2 R& k
% M1 W" R/ m7 R( y
-b, --background- s/ u2 P) e4 N1 Z" P
Typically used with programs that don't detach on their own. This option will force start-stop-daemon to fork before starting the process, and force it into the# |3 M+ U" h* z- k
background. Warning: start-stop-daemon cannot check the exit status if the process fails to execute for any reason. This is a last resort, and is only meant for& K' H y7 x5 f7 E3 i0 M
programs that either make no sense forking on their own, or where it's not feasible to add the code for them to do this themselves.8 z( W/ R4 W3 e# D/ d& k
$ W1 b1 _! u3 L8 B8 `( V -C, --no-close
. n! I2 m1 l+ z ~ Do not close any file descriptor when forcing the daemon into the background (since version 1.16.5). Used for debugging purposes to see the process output, or to& X' f% \) t+ Y4 A( m$ T4 i- `
redirect file descriptors to log the process output. Only relevant when using --background./ D6 a+ l/ v! O: ]: s* n
+ K1 P: f9 Z2 b3 @; p
-N, --nicelevel int9 B( `8 M. p" |/ i% F
This alters the priority of the process before starting it.
! W X4 \# p& k0 m
, w) I% `# Q4 C5 C -P, --procsched policy:priority
: J9 O/ F' G ]& z! M2 C/ V) m This alters the process scheduler policy and priority of the process before starting it (since version 1.15.0). The priority can be optionally specified by9 \- ] J/ Y2 W. e
appending a : followed by the value. The default priority is 0. The currently supported policy values are other, fifo and rr.$ a! F. r0 @8 N$ [
( E- n; i, l7 J) E& w -I, --iosched class:priority
8 f, _3 S; v7 F( `- F This alters the IO scheduler class and priority of the process before starting it (since version 1.15.0). The priority can be optionally specified by appending a _0 x$ d7 [2 e7 b1 [2 r
: followed by the value. The default priority is 4, unless class is idle, then priority will always be 7. The currently supported values for class are idle, best-
5 H" K/ _0 f5 s; `$ _# x effort and real-time.! Y3 i, _& X2 g6 G, |+ S; q
/ t z% G' O- M8 s' G+ ^$ s+ A" c0 l
-k, --umask mask
, m2 r J5 R/ O8 G8 S7 W+ h/ g This sets the umask of the process before starting it (since version 1.13.22).
3 X' \4 x3 A8 C3 Z# D) ?
% j6 `3 n! R& Z6 O' v/ f* D, R, F6 c -m, --make-pidfile
* r5 y& U U0 X- ^ Used when starting a program that does not create its own pid file. This option will make start-stop-daemon create the file referenced with --pidfile and place
! h8 E' f4 |/ j' d: m6 y/ c the pid into it just before executing the process. Note, the file will only be removed when stopping the program if --remove-pidfile is used. Note: This feature3 x7 x3 N7 r s1 D' `, @
may not work in all cases. Most notably when the program being executed forks from its main process. Because of this, it is usually only useful when combined with
4 t8 _8 P# e- f the --background option.+ C: f+ `% B ]2 m1 ?
5 z; O4 Y* |" U" A5 X$ p1 C
