查看: 435|回复: 1
#技术风云榜#基于非支配排序的多目标PSO算法MATLAB实现
发表于 2020-11-12 13:35 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
#技术风云榜#基于非支配排序的多目标PSO算法MATLAB实现; S! E* d$ ]9 y# Y" s8 ~
, j- a9 O0 Z% D- C9 f4 G
这一篇是Xue Bing在一区cybernetics发的论文,里面提出了两个多目标PSO特征选择算法,一个是NSPSO另一个是CMDPSO。5 n& K9 |; Z  e% ~4 e* d
3 Q/ N  p/ l7 T伪代码
$ V7 p+ `9 e& c8 v3 C' _; z$ B# W7 C- f4 [5 T! d6 r
. @, w' I& |$ {
( T7 }  n$ _+ i& z
: o* q! c% D  q1 [具体流程
, c1 d% U6 v# ?2 E% F; B9 u# l
  • ①划分数据集为测试集和训练集
  • ②初始化PSO算法
  • ③迭代开始
  • ④计算两个目标值(论文中是特征数和错误率)
  • ⑤非支配排序
  • ⑥拥挤距离度量并排序
  • ⑥对每个粒子从第一前沿面选择一个粒子作为gbest,更新当前粒子
  • ⑦调整粒子群
  • ⑧迭代结束返回- v8 ~/ ^2 I# J$ b& H0 {. D) m* @- G6 A
8 p% a; x2 B8 E" U. w- L7 _MATLAB实现:  Y% y/ h. ^. k. D
NSPSO:. S# C. {! i2 q7 [) p# g
. j- }. D2 O* v$ I- r( x
注意其中FSKNN是我的问题的评价函数,包含两个目标值,都存入到pfitness中
, R0 K" ^( ?( q1 i: d7 G9 }/ O$ B; c: _
  • function [solution,time,pop,pfitness,site,LeaderAVE] = NSPSO(train_F,train_L)
  • tic
  • global maxFES
  • dim = size(train_F,2);
  • FES = 1;
  • sizep = 30;
  • pop = rand(sizep,dim);
  • popv = rand(sizep,dim);
  • pfitness = zeros(sizep,2);
  • LeaderAVE = zeros(1,2);
  • while FES <maxFES
  •     Off_P = zeros(sizep,dim);
  •     Off_V = zeros(sizep,dim);
  •     ofitness = zeros(sizep,2);
  •     for i=1:sizep
  •         [pfitness(i,1),pfitness(i,2)] = FSKNN(pop(i,:),i,train_F,train_L);
  •     end
  •     Front = NDSort(pfitness(:,1:2),sizep);
  •     [~,rank] = sortrows([Front',-CrowdingDistance(pfitness,Front)']);
  •     LeaderSet = rank(1:10);
  •     solution = pfitness(LeaderSet,:);
  •     LeaderAVE(1) = mean(solution(:,1));
  •     LeaderAVE(2) = mean(solution(:,2));
  •     for i = 1:sizep
  •         good = LeaderSet(randperm(length(LeaderSet),1));
  •         r1 = rand(1,dim);
  •         r2 = rand(1,dim);
  •         Off_V(i,:) = r1.*popv(i,:) +  r2.*(pop(good,:)-pop(i,:));
  •         Off_P(i,:) = pop(i,:) + Off_V(i,:);
  •     end
  •     for i=1:sizep
  •             [ofitness(i,1),ofitness(i,2)] = FSKNN(Off_P(i,:),i,train_F,train_L);
  •     end
  •     temppop = [pop;Off_P];
  •     tempv = [popv;Off_V];
  •     tempfiness = [pfitness;ofitness];
  •     [FrontNO,MaxFNO] = NDSort(tempfiness(:,1:2),sizep);
  •     Next = false(1,length(FrontNO));
  •     Next(FrontNO<MaxFNO) = true;
  •     PopObj = tempfiness;
  •     fmax   = max(PopObj(FrontNO==1,:),[],1);
  •     fmin   = min(PopObj(FrontNO==1,:),[],1);
  •     PopObj = (PopObj-repmat(fmin,size(PopObj,1),1))./repmat(fmax-fmin,size(PopObj,1),1);
  •     % Select the solutions in the last front
  •     Last = find(FrontNO==MaxFNO);
  •     del  = Truncation(PopObj(Last,:),length(Last)-sizep+sum(Next));
  •     Next(Last(~del)) = true;
  •     % Population for next generation
  •     pop = temppop(Next,:);
  •     popv = tempv(Next,:);
  •     pfitness = tempfiness(Next,:);
  •     fprintf('GEN: %2d   Error: %.4f  F:%.2f\n',FES,LeaderAVE(1),LeaderAVE(2));
  •     FES = FES + 1;
  • end
  • [FrontNO,~] = NDSort(pfitness(:,1:2),sizep);
  • site = find(FrontNO==1);
  • solution = pfitness(site,:);
  • toc
  • time = toc;
  • end
    ! A5 i8 h( ~/ {' Y" n0 I
, j2 P3 Z+ ?: x) G( n8 U) A
" X8 Y( b: I5 d+ k* c- N- `
拥挤距离代码:
1 f' X2 u9 [4 W* ?9 C- {# Z
, R7 ]6 x7 t& g6 X. v) E% a% `
  • function CrowdDis = CrowdingDistance(PopObj,FrontNO)
  • % Calculate the crowding distance of each solution front by front
  • % Copyright 2015-2016 Ye Tian
  •     [N,M]    = size(PopObj);
  •     CrowdDis = zeros(1,N);
  •     Fronts   = setdiff(unique(FrontNO),inf);
  •     for f = 1 : length(Fronts)
  •         Front = find(FrontNO==Fronts(f));
  •         Fmax  = max(PopObj(Front,:),[],1);
  •         Fmin  = min(PopObj(Front,:),[],1);
  •         for i = 1 : M
  •             [~,Rank] = sortrows(PopObj(Front,i));
  •             CrowdDis(Front(Rank(1)))   = inf;
  •             CrowdDis(Front(Rank(end))) = inf;
  •             for j = 2 : length(Front)-1
  •                 CrowdDis(Front(Rank(j))) = CrowdDis(Front(Rank(j)))+(PopObj(Front(Rank(j+1)),i)-PopObj(Front(Rank(j-1)),i))/(Fmax(i)-Fmin(i));
  •             end
  •         end
  •     end
  • end) M# U' |5 k5 P) I# P$ \, p
4 N  `% b1 R# Z4 V, d
- {* ~  W/ L+ t; j2 `7 a    Truncation.m代码:
+ ?. b' V" d9 H& a6 ~: Z/ o" a
% \$ A$ Q9 j& v9 p' U, O2 u, m" b" p
  • function Del = Truncation(PopObj,K)
  • % Select part of the solutions by truncation
  •     N = size(PopObj,1);
  •     %% Truncation
  •     Distance = pdist2(PopObj,PopObj);
  •     Distance(logical(eye(length(Distance)))) = inf;
  •     Del = false(1,N);
  •     while sum(Del) < K
  •         Remain   = find(~Del);
  •         Temp     = sort(Distance(Remain,Remain),2);
  •         [~,Rank] = sortrows(Temp);
  •         Del(Remain(Rank(1))) = true;
  •     end
  • end
    : }( ^! @) V2 f- k  r
" s2 S* n' y! x7 A2 I9 w# ]/ g
% W1 [9 M" l5 q, R
6 r' C; _8 T5 l
发表于 2020-11-12 14:19 | 只看该作者
GMT+8, 2025-11-24 08:00 , Processed in 0.203125 second(s), 38 queries , Gzip On.
