Matlab电子电路分析(第三卷)
$ l. m( R8 i# P8 T3 v0 V2 i" {- PCHAPTER TEN
) f) G& w0 H0 m: S: }+ Z5 V! SSEMICONDUCTOR PHYSICS
4 P; ?6 X- o8 e& e) U6 ~5 EIn this chapter, a brief description of the basic concepts governing the flow of [size=9.96001pt]current in a pn junction are discussed. Both intrinsic and extrinsic semicon& l/ t, \: v8 e3 _
ductors are discussed. The characteristics of depletion and diffusion capaci[size=9.96001pt]tance are explored through the use of example problems solved with5 S e: \3 E# U u9 I' H5 P
MATLAB. The effect of doping concentration on the breakdown voltage of[size=9.96001pt]pn junctions is examined.4 I; ~- Y& n& _, @( W. ?8 v; ^
10.1 INTRINSIC SEMICONDUCTORS
: p! s% _/ d# A2 e2 }5 e0 L10.1.1 Energy bands0 F" i+ a) T7 S7 n! H5 w- I- R
According to the planetary model of an isolated atom, the nucleus that con[size=9.96001pt]tains protons and neutrons constitutes most of the mass of the atom. Electrons) w1 o$ w0 a ^4 \4 B4 N0 R+ A7 u
surround the nucleus in specific orbits. The electrons are negatively charged[size=9.96001pt]and the nucleus is positively charged. If an electron absorbs energy (in the# ?" S- i9 e9 n/ r! [0 C# x
form of a photon), it moves to orbits further from the nucleus. An electron[size=9.96001pt]transition from a higher energy orbit to a lower energy orbit emits a photon for" d( ]2 w8 m2 t/ V, ^. d H
a direct band gap semiconductor. ) J) t8 ?( q, D4 c
The energy levels of the outer electrons form energy bands. In insulators, the[size=9.96001pt]lower energy band (valence band) is completely filled and the next energy s! ~5 C# ]0 N& @" ^
band (conduction band) is completely empty. The valence and conduction[size=9.96001pt]bands are separated by a forbidden energy gap.
# M5 x' F* r! T4 p: H
0 Q( P4 \0 h$ z, r7 [0 P! c[size=9.96001pt]
% N4 f# O0 |. V
* J# _$ G( H, S, G1 s. `2 K# F$ Y3 G; Y
