6 x! U9 m# b$ q& |9 Ctools->compare/eco 是和PCB比较了,不是在原理图设计初期的检查,明白?
5 m, A, G" z9 neie 发表于 2010-6-15 13:50 ![]() 1 H3 N7 S5 @. f8 \, O
0 E/ G+ `+ m" z1 r1 Q
, h0 Z0 o0 n8 p4 _; [2 x1 S 也可以查错的,我用过,感觉不好用而已。这个是我随便拷pads例子里面的原理图,运行compare/eco后提示的错误信息PCB Net List Errors Report - previewstart.sch - Thu Jun 17 10:00:12 2010
8 @$ @% F4 M0 Z* \-------------------------------------------------------------------------
. A9 L; I) S. B7 o8 O5 KDesign to Library Part Consistency Check
, e& ]) Z- B! S) Q----------------------------------------0 q: z8 w1 C( J! G5 O; z
Part Type LED has the following gate pins that do not match to the Library part:
" A! W& i, H# i( g0 T (A K) (K A).
% i% s; M4 R" ^Non matching Part Type LED is used by the following parts:
6 j* S- _0 ]* K) @ D1 D2.
2 Y d1 W1 X T! t4 u
5 K5 ? W4 @. i: d/ r2 M- USingle/Zero Pin Net Warnings5 o9 T% l3 T% m6 ~
/ x0 e4 Z' M1 [% b# V- a2 nNet D00 has less than two pins in PCB net list file.
6 C# I: M4 E# j# vNet D01 has less than two pins in PCB net list file.
4 z* `+ A1 s4 H8 v! gNet D02 has less than two pins in PCB net list file.
( H# N% ]. ]+ U/ g& Q5 C5 D& _. GNet D03 has less than two pins in PCB net list file.7 h, m: A% h2 A9 i( {) x
Net D04 has less than two pins in PCB net list file.) ?$ x2 y3 D* H1 X- z
Net D05 has less than two pins in PCB net list file. `" b/ x& W9 D9 o V% W( G h
Net D06 has less than two pins in PCB net list file.2 p u, z$ p5 B3 c
Net D07 has less than two pins in PCB net list file.
, i/ v+ n* p0 C/ a3 C, \7 J7 M, t; ]7 Z5 f
Schematic Connectivity Errors
/ o; `/ m0 ^ ^* {' K3 ?-----------------------------; w2 P: s- i0 ~+ r/ ]* B% {' c
No connectivity errors or warnings. |
