查看: 1168|回复: 19
PCB封装设计标准(SMD)
发表于 2020-3-26 13:41 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
封装设计规范(SMD)
" b) g1 O" n/ X& Z% K+ A  j
9 I% u$ M  U# {# S5 |% V、电阻(R)、电容(C)、磁珠(B)、电感(L)、
( y, L5 J6 V1 e9 _' A" e(D)........................................................................................2 , ?9 r5 J1 G) v7 U$ B5 g
、钽电容(TC).................................................................................2 9 u0 \1 s" a3 r2 w# |; {7 f" g
、排阻(RA)....................................................................................3 ; i% m! t) n; X9 M, V( p% o) D
、电感(L).......................................................................................3 ; j, V0 \, `3 X3 N' y
、二极管(D)...................................................................................5 7 t% o! u1 w8 ^/ c7 K
、晶体管(SOT)...............................................................................5 1 a1 B7 X0 _& V( E4 k& A# a
、保险丝(FUSE).............................................................................6 : |9 b+ ~3 K; J' a5 W" }
、晶振(X).......................................................................................7
' l! D5 G% [/ G、翼形小外形IC和小外形封装(SOP)..........................................8 7 \9 s, u# n! \9 z
、四方扁平封装(QFP)................................................................10
1 y( c4 i9 U* C' k; [' a( h、J型引脚小外型封装(SOJ)........................................................12 3 W3 U% w* D/ d2 D
、塑料有引线芯片载体(PLCC)....................................................13 , S( Z2 h' [% O6 F' k9 J% J: Z! z
、四方无引脚扁平封装(QFN).....................................................13
3 J! _" |% r8 L4 P0 p; L、球棚阵列器件(BGA).................................................................14 ( W$ \# I% z/ l' m, n2 r
3 g2 J- s/ E+ T3 p2 r$ v1 i6 N、电阻(R)、电容(C)、磁珠(B)、电感(L)、ESD(D) # x# ^( v0 t4 O, q+ ^8 D- P8 V& ~
矩形片式元器件焊盘设计 8 p" G% H3 p4 Q
、钽电容(TC)
: ^6 p0 c; V* v0 T2 R8 g4 x6 z* [3 W1 c" o9 }! g
$ O; U3 Z) r) N! u! t1 `! i 6 _3 }2 a8 {3 i  K( c, S
A=Wmax-K 0 u) I! u: I3 U  ~4 [2 p
, p2 ?& W: g  ^
/ O; K& e) b+ x. j
B=Hmax+Tmax-K
. p1 j: `9 e8 W& ?- A: kG=Lmax-2Tmax-K
; o/ u  O3 B" U- O' y! tL---元件长度,mm; . ~! t! n: Z4 x, ^3 k/ ^. R
元件宽度,mm; 8 n, m4 r: A0 ?" U# z+ `9 o
元件焊端宽度,mm;
% F0 o+ u2 b8 y! R2 }元件高度,mm;对塑封钽电容器是指焊端高度)
$ r4 w9 S: q5 {3 P; Z4 s8 F, l常数,一般取0.25mm. & M" I) @  F; e
、排阻(RA) & o4 e$ i5 R6 O, j
英制 公制 A(Mil) B(Mil) G(Mil) 0201 0603 12 10 12 0402 1005 20 20 15 0603 1608 38 38 22 0805 2012 51.18 47.24 32.76 1206 3216 70.87 51.18 66.94 1210 3225 100 70 70
! D( q4 h8 u( Q. t
游客,如果您要查看本帖隐藏内容请回复
; A( e8 p! L, _* h+ F, N
- [. g! Z% J& \; t9 W6 R' J; q& F7 \8 N2 B/ S/ ?* T# s
    擦汗
    2021-10-21 15:19
  • 签到天数: 46 天
    [LV.5]常住居民I
    发表于 2022-4-18 17:34 | 只看该作者
    是乱码了吗,怎么看着这么奇怪。。
    2025-11-24 15:14
  • 签到天数: 274 天
    [LV.8]以坛为家I
    发表于 2022-11-30 11:08 | 只看该作者
    what standard did you refer to?
    " g: ]9 [' v) n- i- x
    发表于 2023-7-6 15:04 | 只看该作者
    学习一下,谢谢分享!
    6 ?3 O* x; h5 F  k+ o6 k
    16#
    发表于 2024-5-16 14:05 | 只看该作者
    求封装设计标准$ [  M6 |+ G9 r( X' ~
    2025-5-19 15:52
  • 签到天数: 133 天
    [LV.7]常住居民III
    14#
    发表于 2023-6-19 15:21 | 只看该作者
    9 L" m) I8 N# E. k& W  e0 n. _学习一下,多谢分享
    发表于 2022-7-20 13:36 | 只看该作者
    借鉴一下优秀文档
    9 u+ p/ \+ @1 R2 O7 W9 W
    郁闷
    2022-10-28 15:05
  • 签到天数: 72 天
    [LV.6]常住居民II
    发表于 2022-6-27 10:10 | 只看该作者
    学习一下,多谢分享
    2023-3-15 15:21
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2022-5-17 16:33 | 只看该作者
    学习一下,谢谢分享!
    擦汗
    2021-10-21 15:19
  • 签到天数: 46 天
    [LV.5]常住居民I
    发表于 2022-4-18 17:31 | 只看该作者
    看一下,学习一下
    发表于 2021-8-5 17:36 | 只看该作者
    谢谢分享 啊,楼主1 Z# l! V5 C9 z, |: X8 A; p
    擦汗
    2019-11-14 21:22
    发表于 2020-5-13 10:28 | 只看该作者
    thank you very much
    GMT+8, 2025-11-24 15:30 , Processed in 0.234375 second(s), 29 queries , Gzip On.
