作品名:[AD 15][12层] 三星S5PV210通信主板(SI4423+SN74AVC8T245+TPS2051BDBV )PCB源文件
2 X8 ?0 T. e- z" Z _# \2 Q
' \7 s' M9 g: B Z2 t/ j) |4 l* L6 V5 a' E8 E! B+ e/ R
文件描述+ a. e, y* s' k( q' `
1. 作品用途:通信主板
& H8 S' P' ~0 G1 f2. 软件版本:AD 15
, k0 h3 P n9 ~; k5 `3. 层数:12层板; n w% ^. U+ A. r0 o0 T6 j9 V" q) K/ n
4. 用到的主要芯片:SI4423+SN74AVC8T245+TPS2051BDBV
) o7 C- o v0 r; U( d, N5. PCB尺寸:130mm*125mm
" N6 f& q/ |4 k8 |" e5 a- l
$ m$ ?. y% z% I+ |8 M; t) h5 F2 u d2 q
作品截图如下:
6 h3 _. X8 _2 k* ]/ ~1 o, ] H顶层截图:7 Z( N+ G* H3 g w
$ j/ U) @* W6 b底层截图:
0 N& \( J4 E3 Y" J
# E' C6 _) B( f) ~8 i7 r
全层截图:
5 c: J3 K. E" B/ s
! d- h7 A7 V2 z8 A' }3 M叠层信息截图如下:
( y, R: L; Y3 g! ^" ^+ H: c
& r4 {$ F* [- w, j0 K- w8 LBOM:
" v1 p, b; t: Y* F2 ?* W% B& `( A# z| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | BATT_2_RB414-IV02N_RB414_IV02N( | BAT1 | RB414-IV02N | 1 | | C1005_C1005_1.8NF | C1, CB172 | C1005 | 2 | | C1005_C1005_47PF | C2 | C1005 | 1 | | SMALL CAP_C1005_100NF | C3 | C1005 | 1 | | C1005_C1005_1UF | C4 | C1005 | 1 | | C1005_C1005_1UF/6V | C5, C6 | C1005 | 2 | | C1005_C1608_4.7UF/X5R | C7, C8, C9, C10, C11, C13, C17, C18, C19, C20, C21, C22, C23, C25, C26, C27, C28, C29, C30, C31, C32, C33, C43, C44, C52, C53 | C1608 | 26 | | CT2012_0_T2012_10UF/6.3V | C14, CTB4, CTB5, CTB8, CTB9, CTB14, CTB15, CTB16, CTB17, CTB18, CTB25, CTB28, CTB29, CTB31, CTB32, CTB35, CTB36, CTB37, CTB38, CTB39, CTB40, CTB41, CTB42, CTB44, CTB46, CTB48, CTB69, CTB71, CTB72 | T2012 | 29 | | C1005_C1005_22PF | C16, C35, C36, C37, C38, C39, C40, C41, C42, C49, C56 | C1005 | 11 | | C1005_C1005_100NF | C24, C45, C51, C55, CB1, CB2, CB3, CB4, CB5, CB7, CB8, CB9, CB10, CB11, CB12, CB13, CB14, CB15, CB16, CB17, CB19, CB20, CB21, CB22, CB23, CB24, CB25, CB26, CB27, CB28, CB31, CB32, CB33, CB34, CB35, CB36, CB37, CB38, CB39, CB40, CB41, CB42, CB43, CB44, CB45, CB46, CB47, CB50, CB51, CB52, CB55, CB56, CB59, CB60, CB61, CB62, CB63, CB64, CB67, CB68, CB71, CB72, CB73, CB74, CB75, CB76, CB79, CB80, CB83, CB84, CB85, CB86, CB87, CB88, CB91, CB92, CB95, CB96, CB97, CB98, CB99, CB100, CB101, CB102, CB105, CB108, CB109, CB117, CB118, CB120, CB121, CB122, CB123, CB124, CB126, CB127, CB128, CB129, CB130, CB131, CB132, CB133, CB134, CB135, CB137, CB139, CB141, CB142, CB143, CB144, CB145, CB146, CB147, CB148, CB149, CB150, CB151, CB152, CB153, CB161, CB166, CB170 | C1005 | 122 | | C1005_C1005_1NF | C34, CB53, CB54, CB57, CB58, CB65, CB66, CB69, CB70, CB77, CB78, CB81, CB82, CB89, CB90, CB93, CB94, CB103, CB104, CB110, CB111, CB116, CB119, CB136, CB138, CB140, CB156, CB157, CB167, CB168 | C1005 | 30 | | C2012_C2012_22UF,6.3V | C46, C47, C48 | C2012 | 3 | | CAP_0_C1005_100NF | C50, CT1 | C1005 | 2 | | C1005_C1005_470PF | C54 | C1005 | 1 | | C3216_1_C3216_2.2UF/50V | CB6 | C3216 | 1 | | C1608_C1608_100NF/C1608 | CB18, CB30, CB49 | C1608 | 3 | | C1608_C1005_100NF | CB29, CB48 | C1005 | 2 | | C1005_C1005_2NF | CB169 | C1005 | 1 | | SW-SLIDE2_KHS02_KHS02_KHS02 | CFG1 | KHS02 | 1 | | SW-SLIDE2_KHS02_SW-DIP2 | CFG2 | KHS02 | 1 | | SW-SLIDE6_KHS06_KHS06_KHS06 | CFG3, CFG4 | KHS06 | 2 | | QSE-020-01-L-D-A_0_QSE-020-01-X | CON1, CON2 | QSE-020-01-X-D-A | 2 | | MD60-19P_1_MD60-19P_MD60-19P | CON3 | MD60-19P | 1 | | USB_SINGLE_A-TYPE_HOST_2_USB_CO | CON4 | USB_CON_A | 1 | | USB-MINIAB_0_USB_MINI_AB_USB-MI | CON5 | USB_MINI_AB | 1 | | AXK8L20125B_HEADER_0_AXK8L24125 | CON6 | AXK8L24125B | 1 | | AXT634124_AXT634124_AXT634124AW | CON7 | AXT634124 | 1 | | SD_HSMMC_TAISOL_4_156-100100090 | CON8, CON12, CON13 | 156-1001000901 | 3 | | A3B-10PA-2DSA_2_A4B-5PA-2DSA_A4 | CON9, CON10, CON11 | A4B-5PA-2DSA | 3 | | QSH-030-01-F-D-A_0_QSH-030-01-F | CON14 | QSH-030-01-F-D-A | 1 | | HIF3F-20PA-2_54DS_HIF3F-20PA-2_ | CON15 | HIF3F-20PA-2_54DS | 1 | | A3B-12PA-2DSA_A3B-12PA-2DSA_A3B | CON16 | A3B-12PA-2DSA | 1 | | CT2012_T2012_10UF/6.3V | CT2, CTB20, CTB22, CTB24 | T2012 | 4 | | CT2012_0_T2012_10UF/10V | CTB1, CTB2, CTB3, CTB6, CTB10, CTB11, CTB12, CTB13, CTB26, CTB27, CTB30, CTB33 | T2012 | 12 | | CT6032_T7343_330UF/16V | CTB7 | T7343 | 1 | | CT2012_0_T2012_1UF/6.3V | CTB19, CTB23 | T2012 | 2 | | CT2012_0_T2012_1UF/6.3V/T2012 | CTB21 | T2012 | 1 | | CT2012_0_T2012_10UF/6.3V/T2012 | CTB34 | T2012 | 1 | | B320_0_B320_B320A | D1 | B320 | 1 | | FUSE_MICROSMD150-2_FUSE3225_MIC | F1 | FUSE3225 | 1 | | BLM18BPG121_BEAD1608_BLM18PG121 | FB1, FB2, FB3 | BEAD1608 | 3 | | A2-6PA-2_54DSA-6P-2_54-MALE_A2- | J1 | A2-6PA-2_54DSA | 1 | | A4B-3PA-2DSA_A4B-3PA-2DSA_A4B-3 | J2, J3, J5 | A4B-3PA-2DSA | 3 | | A2-4PA-2_54DSA-MALE_A2-4PA-2_54 | J4 | A2-4PA-2_54DSA | 1 | | POWER JACK_0_DC-JACK_POWER JACK | JACK1 | DC-JACK | 1 | | QSS-075-01-F-D-A_4_QSS-075-01-F | JB1, JB2 | QSS-075-01-F-D-A | 2 | | A4B-2PA-2DSA_A4B-2PA-2DSA_A4B-2 | JP1, JP2, JP3, JP4, JP5, JP6, JP7, JP8, JP9, JP10, JP11, JP12, JP13, JP14, JP15, JP16, JP17, JP18, JP19, JP20, JP21, JP22, JP23, JP24, JP25, JP26, JP27, JP28, JP29, JP30, JP31, JP32, JP33, JP34, JP35 | A4B-2PA-2DSA | 35 | | LQH32C_0_COIL_3225_22UH (LQH32C | L1 | COIL_3225 | 1 | | LQH32C_0_COIL_3225_1UH (LQH32CN | L2 | COIL_3225 | 1 | | INDUCTOR_COIL_1005_BLM15HD102SN | L3, L4, L5 | COIL_1005 | 3 | | LQH32C_0_COIL_3225_2.2UH (LQH_1 | L6, L8, L13 | COIL_3225 | 3 | | LQH32C_0_COIL_3225_2.2UH (LQH32 | L9, L10, L11 | COIL_3225 | 3 | | CDRH6D28_0_CDRH6D28_CDRH6D28 (1 | L12 | CDRH6D28 | 1 | | LED-RED_SMD_LED-2012_LED-BLUE ( | LED1, LED2, LED3 | LED-2012 | 3 | | LED-RED_SMD_1_LED-2012_LED-RED | LED4 | LED-2012 | 1 | | LED-RED_SMD_1_LED-2012_LED-GREE | LED5 | LED-2012 | 1 | | CON60_GF056_GF056-60S-LSS-P2000 | M1 | GF056-60S-LSS-P2000 | 1 | | MTH_P1_D0.6X12_TH3_2S6_0_GND | MTH1, MTH2, MTH3, MTH4 | TH3_2S6_0 | 4 | | OSCILLATOR_SMD_SCO-103_SCO-103_ | OSC1 | SCO-103 | 1 | | MOSFET P DGS_2_SOT23_FDV301N | Q1 | SOT23 | 1 | | IRF4905/TO_0_SOT23_SI2333DS | Q2, Q3, Q4, Q5 | SOT23 | 4 | | NDC7002N_SOT23-6_NDC7002N | Q-1 | SOT23-6 | 1 | | R1005_0_R1005_100K | R1, R3, R5, R26, R82, R84, R86, R93, R96, R108, R127, R128, R129, R130, R131, R138, R140, R147, R159, R161, R173, R268, R270, R271, R272, R273, R274, R275, R277 | R1005 | 29 | | R1005_0_R1005_0 | R2, R7, R9, R10, R11, R12, R19, R20, R23, R24, R27, R34, R35, R49, R53, R54, R58, R59, R62, R64, R85, R95, R109, R121, R122, R123, R124, R126, R132, R133, R134, R135, R136, R139, R141, R143, R155, R170, R180, R183, R185, R186, R188, R192, R197, R200, R211, R223, R233, R257, R258, R260, R276 | R1005 | 53 | | R1005_0_R1005_10 | R4 | R1005 | 1 | | RESISTER_0_R1005_100K | R6 | R1005 | 1 | | RESISTER_0_R1005_17.4K, 1% | R8 | R1005 | 1 | | RESISTER_0_R1005_10K/1% | R13 | R1005 | 1 | | R1005_0_R1005_NC | R14, R15, R17, R18, R30, R32, R36, R40, R47, R50, R51, R57, R111, R112, R113, R114, R115, R116, R117, R118, R120, R125, R137, R144, R145, R146, R148, R149, R152, R153, R154, R157, R160, R269 | R1005 | 34 | | RESISTER_0_R1005_40.2K/1% | R16 | R1005 | 1 | | R1005_0_R1005_4.7K | R21, R22, R33, R263, R264, R265, R266, R267 | R1005 | 8 | | R1005_0_R1005_44.2/1% | R25, R39 | R1005 | 2 | | R1005_0_R1005_1K | R28, R29, R83, R94, R107, R210, R278, R279, R282, R283 | R1005 | 10 | | R1005_0_R1005_10K | R31, R52, R79, R89, R100, R240, R250 | R1005 | 7 | | RESISTOR_R1005_0 | R37, R45 | R1005 | 2 | | RESISTOR_R1005_10K | R38 | R1005 | 1 | | R1005_0_R1005_20K | R41 | R1005 | 1 | | RESISTOR_R1005_NC | R42 | R1005 | 1 | | RESISTOR_R1005_1.8K | R43 | R1005 | 1 | | R_R1005_NC | R44, R46 | R1005 | 2 | | R_R1005_0 | R48, R55, R56 | R1005 | 3 | | R1608_R1608_100K,1%/R1608 | R60, R65, R167 | R1608 | 3 | | R1608_R1608_20K,1%/R1608 | R61, R169 | R1608 | 2 | | R1608_R1608_44.2K,1%/R1608 | R63, R165 | R1608 | 2 | | R1608_R1005_249K | R66 | R1005 | 1 | | R1608_R1005_68K | R67 | R1005 | 1 | | R_R1608_0/1608 | R68 | R1608 | 1 | | R1608_R1005_150K,1% | R70 | R1005 | 1 | | R1608_R1005_100K/1% | R71 | R1005 | 1 | | R1005_0_R1005_330 | R72, R92, R106, R172 | R1005 | 4 | | R1005_0_R1005_51K | R73, R74, R75, R76, R77, R78, R80, R81, R87, R88, R90, R91, R97, R98, R99, R101, R102, R103, R104, R105 | R1005 | 20 | | R1608_R1005_100K | R110, R163, R166 | R1005 | 3 | | R_0_R1005_NC | R119 | R1005 | 1 | | R1005_0_R1005_10K/R1005 | R142 | R1005 | 1 | | R1005_0_R1005_5.1M | R150, R151, R158 | R1005 | 3 | | R1005_0_R1005_10M | R156 | R1005 | 1 | | R1005_0_R1005_20K,1% | R162 | R1005 | 1 | | R1005_0_R1005_10K,1% | R164 | R1005 | 1 | | R1608_R1608_91K,1%/R1608 | R168 | R1608 | 1 | | R1005_0_R1005_510 | R171 | R1005 | 1 | | R1005_0_R1608_453K,1%/R1608 | R174 | R1608 | 1 | | R1005_0_R1608_100K,1%/R1608 | R175 | R1608 | 1 | | RESISTOR_1_R1005_47K | R176 | R1005 | 1 | | RESISTOR_1_R1005_10K | R177, R179 | R1005 | 2 | | RESISTOR_1_R1005_12.7K | R178 | R1005 | 1 | | R1005_0_R1608_NC/R1608 | R181, R182, R184, R187, R189, R190, R191, R193, R194, R195, R196, R198, R199, R201, R202, R203, R204, R205, R206, R207, R208, R209, R212, R213, R215, R216, R217, R220, R221, R222, R224, R225, R226, R228, R229, R231, R235, R285 | R1608 | 38 | | R1005_0_R1608_0/R1608 | R227, R234, R284 | R1608 | 3 | | R_R1005_240K | R230 | R1005 | 1 | | R_R1005_300K | R232 | R1005 | 1 | | R1005_0_R1005_10K/1% | R236, R237, R238, R239, R242, R243, R244, R245, R246, R247, R248, R249, R252, R253, R254, R255 | R1005 | 16 | | R1005_0_R1005_10K/NC | R241, R251 | R1005 | 2 | | R1005_0_R1005_1.2K/1% | R256 | R1005 | 1 | | R1005_0_R1005_75/1% | R262 | R1005 | 1 | | R1005_0_R1005_1.8K | R280, R281 | R1005 | 2 | | RP_0_R-AR4_0 | RA1, RA2, RA3, RA4, RA5 | R-AR4 | 5 | | SW-TACT_SW-TACT-1105SMD-4_3MM_S | SW1 | SW-TACT-1105SMD-4_3MM | 1 | | SW-TACT_SW-TACT-1105SMD-4_3MM_1 | SW2, SW3 | SW-TACT-1105SMD-4_3MM | 2 | | TP_TP0_8-SMD_TP | TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8, TP9, TP10 | TP0_8-SMD | 10 | | TP_P0_0.8_D0_TP0_8-SMD_TP | TP11, TP12, TP13, TP14, TP15, TP16, TP17, TP18, TP19, TP20, TP21, TP22, TP23, TP24, TP25, TP26, TP27, TP28, TP29, TP40, TP41, TP42, TP43, TP44, TP45, TP46, TP47, TP48, TP49, TP50, TP51, TP52, TP53, TP54, TP55, TP56, TP57, TP58, TP59 | TP0_8-SMD | 39 | | TP_P0_0.8_D0_TP0_8-SMD_A_CAMDAT | TP30, TP31, TP32, TP33 | TP0_8-SMD | 4 | | TP_P0_0.8_D0_TP0_8-SMD_A_FIELD | TP34 | TP0_8-SMD | 1 | | TP_P0_0.8_D0_TP0_8-SMD_A_CAMPCL | TP35 | TP0_8-SMD | 1 | | TP_P0_0.8_D0_TP0_8-SMD_A_CAMVSY | TP36 | TP0_8-SMD | 1 | | TP_P0_0.8_D0_TP0_8-SMD_A_CAMHRE | TP37 | TP0_8-SMD | 1 | | TP_P0_0.8_D0_TP0_8-SMD_A_CAMD_1 | TP38 | TP0_8-SMD | 1 | | TP_P0_0.8_D0_TP0_8-SMD_FLASH | TP39 | TP0_8-SMD | 1 | | TP_TP0_9-TH_GND | TPH1, TPH2, TPH3 | TP0_9-TH | 3 | | SN74AVC8T245-DGV_3_SOP24P-0_4-5 | U1 | SOP24P-0_4-5X4_4 | 1 | | LT3591EDDB_1_LT3591EDDB_LT3591E | U2 | LT3591EDDB | 1 | | LTC3872ETS8_LTC3872_LTC3872ETS8 | U3 | LTC3872 | 1 | | LP3962_EMP_0_SOP8_W6_0_E1_27_SI | U4 | SOP8_W6_0_E1_27 | 1 | | PCA9517DGK_0_MSOP08P-0_65-3X3_1 | U5 | MSOP08P-0_65-3X3 | 1 | | RCLAMP0502B_SOT-523_RCLAMP0502B | U6, U7, U8, U9 | SOT-523 | 4 | | SN74LVC1G04DBV_2_SOT23-5_SN74LV | U10, U34, U36 | SOT23-5 | 3 | | TPS2051BDBV_0_SOT23-5_TPS2051BD | U11, U13 | SOT23-5 | 2 | | SDMP0340LT_SOT-523_BEC_SDMP0340 | U12 | SOT-523_BEC | 1 | | PCA9517DGK_0_MSOP08P-0_65-3X3_P | U14 | MSOP08P-0_65-3X3 | 1 | | SN74AVC8T245-DGV_2_TVSOP16_W6_4 | U15 | TVSOP16_W6_4_E0_4 | 1 | | MAX1818EUT33_0_SOP8_W6_0_E1_27_ | U16, U41 | SOP8_W6_0_E1_27 | 2 | | MAX1818EUT33_SOT23-6_MAX1818EUT | U17, U40 | SOT23-6 | 2 | | LTC3406ES5_SOT23-5_LTC3406ES5 | U18, U21, U42 | SOT23-5 | 3 | | LTC3406ES5_0_SOT23-5_MIC5319-3. | U19, U37 | SOT23-5 | 2 | | 54ALS32/LCC_1_SOT23-5_74LVC1G32 | U22, U23, U24 | SOT23-5 | 3 | | SN74CBTLV3257_TSSOP16P-0_65-5X4 | U25, U26 | TSSOP16P-0_65-5X4_4 | 2 | | SN74AVCA164245DGG_TSSOP48P-0_5- | U27, U28, U32 | TSSOP48P-0_5-12X6 | 3 | | SN74LVC1G11DBV_SOT23-6_SN74LVC1 | U29, U31 | SOT23-6 | 2 | | SN74LVC1G08DBV_SOT23-5_SN74LVC1 | U30, U38 | SOT23-5 | 2 | | MAX8698C_0_MAX8698C_MAX8698C | U33 | MAX8698C | 1 | | MAX16054AZT_SOT23-6_MAX16054AZT | U35 | SOT23-6 | 1 | | LM2832XMY_LM2832XMY_LM2832XMY | U39 | LM2832XMY | 1 | | SI4423DY_SOP8_W6_0_E1_27_SI4423 | U43 | SOP8_W6_0_E1_27 | 1 | | MAX6458_SOT23-5_MAX6458 | U44 | SOT23-5 | 1 | | LTC3406ES5_1_SOT23-5_MIC5219BM5 | U46 | SOT23-5 | 1 | | K4T2G084QA-HCE6_0_BGA68_W11_0X1 | U47, U48, U49, U50 | BGA68_W11_0X18_0_P0_8_PAD0_45 | 4 | | K4T1G084QQ-HCE6-DDR2_BGA60_W9_0 | U51, U52, U53, U54 | BGA60_W9_0X11_0_P0_8_PAD0_4 | 4 | | S5PV210_3_BGA584_W35_0_P0_65_PA | U55 | BGA584_W35_0_P0_65_PAD0_35 | 1 | | CRYSTAL_SX-8_SX-8_24MHZ (SMD,SX | X1, X2 | SX-8 | 2 | | CRYSTAL_CH-308_CH-308_32.768KHZ | X3 | CH-308 | 1 | | CRYSTAL_SX-8_SX-8_27MHZ (SMD,SX | X4 | SX-8 | 1 | | MBRS320T3_MBRS320T3_MBRS320T3 | ZD2 | MBRS320T3 | 1 | | 1SMB5920BT3G-6_2V_1SMB5920BT3_O | ZD3 | 1SMB5920BT3 | 1 | 附件:; R. o" L& ~2 f4 Q7 h; Z( U: U9 i
PCB源文件如下:
' m+ [5 O. I! A- q t$ _. E! `% ~' |8 h4 {" S
/ H8 |! J, Z# G' `% I5 J |
