查看: 383|回复: 1
求教定时器通道单独关闭???
发表于 2019-7-18 17:26 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
, g' ^4 i( E' `1 o0 }  w
( Y' j. r" c1 t$ j8 H$ Tvoid TIM4_Configuration(void)
- V$ r6 A1 K  l5 K{
) J7 Z4 _' x- ]% ?1 v        u32        temp;
7 V) I3 m& o* Y% G! v. s& m        TIM_TimeBaseInitTypeDef        TIM_TimeBaseInitStruct;& B, i+ N4 t0 W+ t5 O' V5 S, J7 i# P
        TIM_OCInitTypeDef TIM_OCInitStruct;7 P; {, v: k! c
, D" E! `9 r  V
        temp = SystEMCoreClock / 1000000;
8 K7 {* G6 l) _: S- g5 q        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);                        " j9 |# m, ~  v4 X0 Q$ h2 W
        TIM_DeInit(TIM4);1 H+ ?1 _# f& m
        if(SystemCoreClock > 36000000)2 r4 t5 H9 X: {! L- S) r  B& }$ J
3 b( I/ q7 o+ }, I- L( S7 I                TIM_TimeBaseInitStruct.TIM_Prescaler = 1;  t0 n: m3 O* o% f4 ?
                TIM_TimeBaseInitStruct.TIM_Period = PWM_Period * temp / 2;
6 W8 ?! ^# ]' k3 `" h                TIM_OCInitStruct.TIM_Pulse = PWM_Recharge * temp / 2;
* E' K' O: N8 j7 i        }
! W8 S. Z$ U* j2 a8 N        else- i3 L8 v. F7 G( V
8 o* @8 H. _9 y7 V. s4 G5 `                TIM_TimeBaseInitStruct.TIM_Prescaler = 0;! {: n( @3 P5 j( V( [
                TIM_TimeBaseInitStruct.TIM_Period = PWM_Period * temp;
3 p2 }( T' o5 ?0 w- i/ F9 K2 V                TIM_OCInitStruct.TIM_Pulse = PWM_Recharge * temp;% S. t3 |! t4 u# }
        }0 [, _9 _- P! u' y. B# P4 r
        TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
% J- y! l8 U7 e" F        TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;4 t) d8 ?: w. g2 p) n. U7 U* f. Q8 O- U
        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseInitStruct);
$ C  ^- C7 I! G
' ^$ ^7 ^& k! R) H; f: ?, _        TIM_OCInitStruct.TIM_OCMode        = TIM_OCMode_PWM1;4 u) A! t1 h! p8 T0 E) `* f0 c
        TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Disable;
9 L3 {+ V* |& B" k        TIM_OCInitStruct.TIM_OCPolarity        = TIM_OCPolarity_High;1 I3 h- w2 Y4 c/ R2 A
        TIM_OC1Init(TIM4, &TIM_OCInitStruct);/ x: `: I$ \/ d
        TIM_OC2Init(TIM4, &TIM_OCInitStruct);
* k+ i' y. A5 _" _$ P        TIM_OC3Init(TIM4, &TIM_OCInitStruct);
) T" d# U. y( ?8 i        TIM_OC4Init(TIM4, &TIM_OCInitStruct);
0 W5 v4 s9 t( d; i' c# V( t0 H: C$ ]3 n' r" u
        TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);9 E) Q0 P% B: r9 ?7 S% G0 }% h3 W
        TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);* T$ i. c. j& ~. u) q5 K' [  B
        TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
6 d. i8 W( _4 a; U$ @        TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);/ p& m1 J1 a2 }5 l  ~, w) u/ F
        TIM_CCxCmd(TIM4, TIM_Channel_1, TIM_CCx_Enable);! c  G! h8 A! Y" t- J, z
        TIM_CCxCmd(TIM4, TIM_Channel_2, TIM_CCx_Enable);
+ p) f" `$ h% T$ G  ^        TIM_CCxCmd(TIM4, TIM_Channel_3, TIM_CCx_Enable);$ l* C4 X& z; T* g. o$ ?
        TIM_CCxCmd(TIM4, TIM_Channel_4, TIM_CCx_Enable);
2 ^4 ^4 G0 w" y1 _% Z2 \# U        TIM_ARRPreloadConfig(TIM4, ENABLE);
0 d, f: s( b2 ~5 U% f* }* ?. Y* f6 n. X+ ?
        TIM_CleaRFlag(TIM4, TIM_FLAG_Update);  l7 s0 B  T$ g7 |0 s+ p
        TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);2 N# s) ?. F( d; k& P% l. j6 {% h
        TIM_Cmd(TIM4, ENABLE);
1 C1 E1 C- W9 a& d4 l; ]1 |1 p        ( n0 ?; x0 q6 z) A
        TIM_CCxCmd(TIM4, TIM_Channel_2, TIM_CCx_Disable); //放在这里面起作用$ q3 W7 f# q' L# D8 i' }/ s
  c8 D0 p) G8 R3 k( m& e; h' f% z! D# h4 [; r5 W
# T) m0 w+ k3 ?+ D; C
3 U1 ?  V& ^* C; ]        。
+ j. C3 I- `# S( J  F# L. V# @        。
# r/ {% r2 d6 x: z
$ A8 V' @' [9 s# Q        TIM4_Configuration();7 W6 Q8 I  K( U, q6 q. e
2 C! g9 U# W# O//期望随时单独失能某一通道,但这样不起作用:
0 G! o8 k' {$ ~        TIM_CCxCmd(TIM4, TIM_Channel_2, TIM_CCx_Disable);7 b5 s& u' }4 ^9 a) b0 W
# e2 G+ M( l8 i2 r% p$ e; z/ H  x1 U, p8 O$ \6 i4 ~
& `8 P& P8 Y6 y- j1 [
发表于 2019-7-18 18:42 | 只看该作者
建议仔细阅读数据手册,每个定时器都有一个CCER位,看看它的作用。
GMT+8, 2025-11-24 21:23 , Processed in 0.171875 second(s), 24 queries , Gzip On.
