查看: 2552|回复: 0
pads2005导入网表错误
发表于 2009-5-13 01:26 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
打开一个示例的pcb文件,然后导出 .asc文件,然后再导入此 文件,就会出现一堆错误 如下:
- \% J, y/ K2 M6 R  L0 V0 G" F0 \6 J, i  y2 K; o: w
; H9 C/ |- t& f3 w: Y9 ]3 }; Z# V0 ?Reading file --  F:\pads Projects\Samples\test.asc- e! S$ B9 S, p2 J% K) C  C6 L
Bad Lines item type name <BOARD> , r* y! L  A2 s
D6970            BOARD    -625   875    1  + X* l) `' C: N" f; M0 G; ]
*Bad *LINES* ascii data line format
; L, f2 D9 C8 }% u3 vCLOSED 11  10  0
# k; f: h' F& U+ b5 I0 c; F7 @4 ) Z- N7 ~5 l& M- U3 Q
. u+ K7 X. o9 `, J0      0
; i  a2 t# T7 @  f2 0 t) j- o' s" w& X$ {7 k
8 ~& G4 h! [. \350    0     - H/ J: E; w1 H* G* R
2   }9 ?: f0 [; t& E. m
*Bad *LINES* ascii data line format/ ~  f( Y) c/ f' p0 m
350    -1050 - Y# ]) C6 a. [+ B; h- ^- ~- [* ?* d
" w) _" P! O; u5 [3 N2 ^1 g/ j; M- D*Bad *LINES* ascii data line format5 K7 j  b8 H6 B
2425   -1050
% L9 o, a2 `* W2
+ A3 i7 l5 ?6 e*Bad *LINES* ascii data line format3 `% k+ ^; E1 Q( X7 `
2425   1600
6 Q7 M5 X; R8 c: c5 k2 ' U6 N/ E' d. F& H& Y, h! S
1 V$ z3 _! n# ^+ e& X/ Z  L$ ]2275   1600  9 \& Q1 I; Z5 j% X) |% }
2 0 C. L/ z; f* R6 \0 c0 Y
; K. v1 s5 d& J, M6 y8 t2275   1725  ! P* ~  R+ J1 g( Y; d
5 ]" v3 f$ n2 X) E" `
* Y: ?5 c3 T( G# H' n% w. c$ i*Bad *PARTDECAL* ascii data line format. l! ~$ p( @# v, g8 `/ \
-50    250
+ a- v( ?, I# N0 h# X( m*Bad *PARTDECAL* ascii data line format. G0 f( b' ?0 i" E& s
-50    175
9 m) L) l1 R9 f* r' q*Bad *PARTDECAL* ascii data line format' w6 U6 u& @* L7 ~3 Y
0      175   3 n9 W; h2 @+ A! M' Q8 o
*Bad *PARTDECAL* ascii data line format3 _$ p1 d, E) X
0      125
( o9 x( R: Y6 ]: l: V. [4 R. O*Bad *PARTDECAL* ascii data line format
. ~& B* w1 f  X+ J) l1 @* S, D-50    125   5 z" ]2 S9 y! J) G0 u
* F$ n" j# C. V9 h- j* s, Y0 }; \-50    50    . C3 d. Q2 _3 A7 ~# z& s8 m
*Bad lines piece data line format VALUE         220         175   0.000  1         100          10 N   LEFT   DOWN
, y9 t8 C1 a; ~1 XREGULAR <PADS STROKE FONT>1 ?$ g0 J* i8 P2 ?: ~
*Bad *PARTDECAL* ascii data line format/ o0 e: s: `0 \: a6 j, h* n+ h" j
REF.DES.
GMT+8, 2025-11-26 23:42 , Processed in 0.140625 second(s), 25 queries , Gzip On.
