查看: 956|回复: 6
Mechanical via split into Stacked via?
发表于 2018-3-8 13:42 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
We proposed the stcakup to manufacturer is  4 layer stack up with laser vias from layer 1 to2 ,2 to3 and 3 to 4 , mechanical via from layer 1 to 4.
: l0 j9 j* v( d# g' K' ?8 X
& x) q0 ]% c& k but Manufacturer splitted the mechanical vias from layer 1 to 4 in to stacked vias My Question is why manufacturer changed mechanical via to stacked via? cost also increased increase while using stacked vias?
# @( o* E" t; ~8 \+ Q ! [6 I0 v# @( @
. f9 x* Z: S, \6 g
/ ?3 P6 [) p0 O9 l% p9 g9 x* t# g/ c( d3 {. Y/ G- N
6 ^4 R, y- x2 L- S
4 ?- f* x  Z/ {+ [% {; S
I think laser technology can obtain smaller hold size by stack laser via compairion to mechanical drill  发表于 2018-3-14 06:12
发表于 2018-3-17 21:46 | 只看该作者
那是因为钻孔时,孔尺寸小于100um时,必须使用激光钻孔。
/ V' P' c3 b& @6 W( B2 l1 A而激光钻孔时,不能钻太厚的板子。    所以要分开钻。) F, L1 |' e1 f) ]
- G, Q8 \8 T4 l* J' m. J3 y. b2 }钻孔尺寸大于等于100um时,就是用机械钻孔,就是一次性从第1层钻到第4层。
发表于 2018-3-8 15:55 | 只看该作者
各位都是外国人么,装逼都说英语
GMT+8, 2025-11-24 19:07 , Processed in 0.234375 second(s), 29 queries , Gzip On.
